2nd gen DCLB with 235/85r16 tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beepboop, Jan 14, 2019.
  1. Jan 14, 2019 at 8:10 AM
    Beepboop
    Beepboop [OP] Member
    2011 DCLB 4x4
    Does anyone out there have pictures of DCLB trucks with the 235/85r16 tires? I'm considering doing a small bilstein 5100 lift and either 235/85r16s load e or 265/75r16 load c. I like what I've heard about traction with the skinnier tire, but I wonder if it looks too skinny. Thanks!
    lowtidejoe likes this.
  2. Jan 15, 2019 at 10:00 PM
    djaysmak
    djaysmak Well-Known Member
    I'm pleased with my switch to 235/85/16 tires. They are a bit skinny but I like the practical pizza cutter look! Also, I gained about 2-3 MPG after ditching the 285s I previously had.
    However, I haven't been wheeling enough to know how much better they are compared to wider tires.
  3. Jan 15, 2019 at 10:08 PM
    djaysmak
    Sorry, had a brain fart... these are 235x80x17
  4. Jan 15, 2019 at 10:26 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Do you have to run a lift with these?
  5. Jan 15, 2019 at 10:35 PM
    djaysmak
    Not 100% sure. Previous owner did the 5100 bilstein 3" lift and I still needed to trim a little plastic moulding on the inside of the wheel wells so they didn't rub.
  6. Jan 16, 2019 at 4:21 AM
    Beepboop
    2011 DCLB 4x4
    Thanks for the pictures! Looks like the 235/85r16 and 235/80r17 are roughly the same size. I dig it. Makes me think about going with a bigger lift....
  7. Jan 16, 2019 at 4:54 AM
    mangler
    mangler Well-Known Member
    Saskatchewan, Canada
    1998 Tacoma 4x4
    235 85 16 duratracs load e
  8. Jan 16, 2019 at 9:43 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Love the look of tall skinnys. Only cosmetic thing I'll note is they look better on wheels with a more aggressive offset so they don't sit sucked in on the truck. Other then that catch in personal taste, I've considered going to them instead of my 265/75 16s. I'd have to get different wheels though, they'd be too skinny for my 8" wide wheels.
  9. Jan 16, 2019 at 10:21 AM
    mangler
    1998 Tacoma 4x4
    I'd like to get some after market wheels with a bigger offset but they are hard to come by in anything narrower than an 8" wide wheel
  10. Jan 16, 2019 at 11:48 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    True...you could also go for the utilitarian look and get some FJ Cruiser steel wheels, I believe they're 7.5", which is the max "recommended" wheel width for a 235/85.
    There is a couple good threads out there with lots of 235/85 examples. Here's one: https://www.tacomaworld.com/threads/235-85-16-the-skinny.490070/
