2nd gen DJM help
Discussion in 'Street Trucks' started by franzcars, Dec 27, 2012.
  1. Dec 27, 2012 at 3:06 PM
    franzcars
    franzcars [OP] I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    How did you guys remove the rivits that hold the stop bump stops to the frame? Trie drilling which wouldnt work for the bottom ones and a cut off wheel didnt work either. Any ideas?
  2. Jan 2, 2013 at 12:56 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    What do i do if they just wont come out? I cut off one part of the bracket so that it's just the rivit and the frame, used a air hammer didnt work, used the bit and a fairly big hammer, not moved it, put a hole through it, nothing. What am i supposed to do now??
  3. Jan 2, 2013 at 1:09 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    what part are u talking about, i dont think i ever did this on my drop hmmm lol
  4. Jan 2, 2013 at 1:51 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    To cut the notch you have to remove the factory bumpstops in the rear. Well mine are riveted the the frame, which wont push out. Even hitting the rivet directly with a sledge hammer it dosnt move
  5. Jan 2, 2013 at 2:09 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    oh i see i didnt do the notch because here in hawaii they wont allow it. which sucks!!! i want mine slammed but without the notch its kinda impracticle. i reccomend getting after market springs that are stiff like somthing the xii performance sells. the front wont bottom out so easily with those
  6. Jan 2, 2013 at 2:20 PM
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Yeah and without the notch i cant sit all the way down, so im SOL right now
  7. Apr 14, 2015 at 10:12 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2016 TRD Off Road 4x4 DC/LB
    3" Toytec lift 16x8 Methods 285/75R16 Toyo Open Country M/Ts
    I drilled the side rivets out and left the ones in on the bottom. Just ground them flat. I had to drill the side ones out. I ground them flat and still couldn't punch them out with both a hammer and chisel and air chisel.
  8. Dec 20, 2016 at 1:17 PM
    Jroach23
    Jroach23 New Member
    2014 Black reg cab base lowered
    DJM 3/4 drop 20" kmc wheels black led tails
    The easiest way to remove the rivets is to use a cutoff wheel and cut an X into the head. Then use a chisel in an airhammer to break the pieces off. Then a punch in the air hammer to push the shaft out. If it is still hard to move you can use a torch to heat them up before punching them through.
  9. Dec 20, 2016 at 1:23 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    They will come out, hit the gym for a month and then grow stronger so you can punch them out lol. Nah but seriously its tough but they will come out. I ground then dowb then used a short sledge and a cold chisel punch, the blue ones. It took a toj of sweat f words and muscle. Air hammer would be helpful like someone said, but i didnt have one
  10. Feb 17, 2017 at 5:52 PM
    slickrick614
    slickrick614 Well-Known Member
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Performance clutch, aero turbine 2525 muffler, 6k hids, 5% tints, smoked tail lights
    Mine came out no problem just cut the heads off then use the air hammer with either a pointed tip or a small enough punch and they popped right out
