2nd gen drive line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bubbabud, Aug 12, 2015.
  1. Aug 12, 2015 at 3:52 PM
    bubbabud
    bubbabud [OP] Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Just a side note I am 75 years old and find it difficult to crawl under my truck to do my own service. This is my first Tacoma and probably be the last vehicle I will buy so I bought it mostly for reliability. talked with dealer service writer when I took it in for lube and oil change. The truck was purchased used certified and I was assured by dealer that it had been completely serviced by them at 30k at 35k I was told that U joints were sealed and not serviceable.
    After reading post on TW I started wondering so for shits and giggles I stopped at a Jiffy Lube and ask. They pulled the truck on the pit and allowed be to look low and behold 5 Zerks just as described in post. So much for dealer service. will probably use Jiffy lube in future unless its warranty or recall. Rant over just wish I could still do it myself.
  2. Aug 12, 2015 at 3:58 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The pre-runner has zero zerks. Only the 4x4 has the 5 zerks to lube (if I recall, 2 up front and 3 rear).
  3. Aug 13, 2015 at 3:42 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    The dealer is a idiot or perhaps he thinks U R or both.
  4. Aug 13, 2015 at 4:22 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    If you want accurate and reliable information on your truck, the dealership is the last place you should look. Tacomaworld is my bible on any questions or info about my truck. The owners Manuel is another accurate source of information. The service and sales department of your Toyota dealership is your primary source of MIS-information.
  5. Aug 13, 2015 at 5:28 AM
    Pigpen
    Dan
    Northwest Montana
    This it the truth.
    OP, glad you found out early enough to get grease in there before wearing out the u joints. I hope you find your Tacoma to be an enjoyable and stress free vehicle for many happy years to come.
