2nd Gen Driveshaft Whining
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmoney28, Dec 20, 2022.
  1. Dec 20, 2022 at 5:39 PM
    Cmoney28
    Cmoney28 [OP] Member
    Colby
    05 Tacoma
    Hey y'all, I'm hearing some whining under my truck when I drive in colder weather. I am thinking it is the driveshaft making the noise because it is coming from underneath the truck and the noise comes on when the truck gets around 40 mph. I put a GoPro underneath the truck to find where the sound was coming from and from three different videos I have concluded that the sound is coming from the carrier bearing or maybe near it. I have the video attached and you can hear the pitch of the whine increase as the truck speeds up, and the pitch of the whine decrease as the truck slows down. I just rebuilt the driveshaft last year because the u-joints were destroyed and went ahead and replaced the carrier bearing as well. Could it be a bad carrier bearing out of the box? Has anyone experienced this before? What do y'all think it is?
    https://youtu.be/bLjRwwQFcmA
  2. Dec 20, 2022 at 5:56 PM
    Blain
    Blain I ain't got time to bleed
    Tx
    OEM part?
  3. Dec 20, 2022 at 5:59 PM
    Cmoney28
    Colby
    05 Tacoma
    No, it was from Autozone. Don’t remember the brand
  4. Dec 21, 2022 at 8:41 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Unless it was a spicer carrier bearing... thats probably your problem.
    That stated, when was the last time you changed the rear diff fluid? (answer this and then ill explain)
    fb40dash5 likes this.
  5. Dec 21, 2022 at 8:47 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Voting carrier bearing but if it's the rear diff:bananadead:
    SR-71A and ToyoTaco25 like this.
  6. Dec 21, 2022 at 10:25 AM
    Cmoney28
    Colby
    05 Tacoma
    It was a duralast carrier bearing from autozone, and I have never changed the rear diff fluid
  7. Dec 21, 2022 at 11:33 AM
    nd4spdbh
    SoCal
    How many miles are on the truck? (and if you are not the original owner - how many miles have you put on it?)
  8. Dec 21, 2022 at 7:52 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    I'm having something similar happen. Check the play in the carrier bearing as well. Currently my driveshaft (in the bearing area) has an inch or so. A.k.a super not good. I'll be buying another oem one. Aftermarket one lasted maybe 25k miles.
    SR-71A likes this.
  9. Dec 22, 2022 at 5:02 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    My universals went out at about 110k. The rear one froze and caused a lot of what you are describing.
  10. Dec 22, 2022 at 1:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does the noise come and go as you accelerate/decelerate?
  11. Dec 23, 2022 at 5:11 PM
    Cmoney28
    Colby
    05 Tacoma
    Yes, you can watch that video I have and hear it as accelerate and let off the gas
  12. Dec 23, 2022 at 6:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Might be the diff
