2nd Gen Driving Vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PROBTO, Nov 21, 2023.
  1. Nov 21, 2023 at 6:47 PM
    PROBTO
    PROBTO [OP] Active Member
    Scoured the threads for possible answers but seems it may not be a simple one. Looking to hear everyone’s opinion!
    2005 Off-Road. Heavily modded. Vibration while cruising between the 40-50mph range. Tires are the Yoko G003’s paired with steel beadlocks from BattleBorn.
    A lot of things against making it a smooth ride but in my efforts to track the issue down I’ve tried a few things:
    -Multiple balances of the tires
    -2 alignments
    -Carrier bearing drop for driveline
    -Torquing everything in between
    Any feedback is appreciated. I know it’s tough to get a smooth setup on a truck like this but if I can make it more comfortable on the way to the trails I’ll take it!
  2. Nov 21, 2023 at 7:53 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If you think it's coming from the driveline, check out this huge thread: https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
    If you have any friends that also have Tacomas/4Runners/etc and can swap wheels & tires with them (assuming they have a less aggressive setup), you could do that temporarily to rule out the source.
    Good luck, vibrations are sometimes one of the most difficult things to chase down.
  3. Nov 21, 2023 at 8:02 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Front camshell needle bearing?
    AdamM likes this.
  4. Nov 22, 2023 at 5:16 AM
    PROBTO
    One thing from that article that I may try is the lead pack shims. I’ve already shimmed my carrier bearing so maybe I can double check my angles and shim the leafs.
    Swapping wheels is also another great idea. Time to hunt for a donor lol
  5. Nov 22, 2023 at 5:17 AM
    PROBTO
    Had that remedied when I regeared the truck. Solid concern though!
    Island Cruiser likes this.
  6. Nov 22, 2023 at 12:37 PM
    Burritopa
    Burritopa Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    Kinda have the same issue intermittent. Think its my rack, i know they go bad fairly easy
    Also the intermediate rack
    Tie rods
    (All things I need done and last on my list to correct it)
    PROBTO[OP] likes this.
  7. Nov 22, 2023 at 9:10 PM
    PROBTO
    I’ve contemplated the rack as part of the issue as well. Whenever I’m on a trail I feel like it makes the noises of a loose rack but I can’t find anything loose when I’m torquing things down in the garage. I’ve beefed up my tie rods with the war fab sleeves (can kind of see them in this photo) and everything seems tight with the inner rods so it’s a mind boggle.
