2nd gen dual exhaust..out sides or straight out the back
Discussion in 'Performance and Tuning' started by jrw100990, May 20, 2013.
dual exhaust out the side or the back
Poll closed Jun 19, 2013.
  1. side
    11 vote(s)
    73.3%
  2. straight out the back
    4 vote(s)
    26.7%
  1. May 20, 2013 at 5:53 PM
    jrw100990
    jrw100990 [OP] Member
    virginia
    AFE CAI, flowmaster 40 chopped after axle, window tint, blacked out badges, painted rims black, LCE headers
    anyone have an opinion on which looks better or if you have any pictures of what you have done...also will it make any difference in sound or will both sound the same
  2. May 20, 2013 at 6:07 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    both look stupid. keep it single or dump it
  3. May 20, 2013 at 6:09 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    Dump. Keep it clean looking.
  4. May 20, 2013 at 6:11 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    http://www.youtube.com/watch?v=Uuuu3ROeDAA&feature=youtube_gdata_player. This is how I did mine, would look much better I'm sure if a shop did it all one piece, but I did what I could without a bender. I don't think the sound is gonna be much different side or back. I originally thought u meant out the side infront of the tire for some reason, which would obviously make cab noise more, but shorter exhaust exit means a little better throttle response as well. Sorry to get off tangent since I assume thats not what u meant anyway.
  5. May 20, 2013 at 6:11 PM
    jrw100990
    virginia
    benefits of dumping?
    edit: and what will it sound louder
  6. May 21, 2013 at 3:21 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Benefit= looks 50 million times better
    One way won't be louder than the other. Dumping it will be a little louder inside the cab because if you go out the back the sound is aimed away from you.
  7. May 21, 2013 at 8:33 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Dump it. :)
    Then no one sees any exhaust at all. I just terminated mine behind the rear axle and added an angled tip to deflect the exhaust away from the spare. With a stock muffler there is no difference in sound.
  8. May 23, 2013 at 7:29 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    do duals swept to the same side exit. Looks much better on these trucks with smaller beds
  9. May 23, 2013 at 8:23 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    X2
  10. May 24, 2013 at 6:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Hmmm. To bad you couldn't do a dual setup and have each tip exit like RCfreaks'. Out of the ower side of the bed, near the cab.
