2nd gen frame box plate kit
Discussion in 'Automotive Group Buys' started by jeffz0rz, Dec 9, 2015.
  1. Dec 9, 2015 at 2:49 PM
    jeffz0rz
    jeffz0rz [OP] Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    I wouldn't go so far as to say that this is going to keep your frame from bending in the event of a rear-end collision, but this does stiffen your frame for everyday trail use and long-term abuse. As far as accidents go, I would not consider this at all to be a preventive measure in that aspect.
  2. Dec 9, 2015 at 3:12 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Acerwin likes this.
  3. Dec 9, 2015 at 3:43 PM
    jeffz0rz
    san diego
    Is there a problem @HomerTaco ? If so, perhaps there's a friendly p.m. in order unless it's easier to tag a moderator and have them contact me with any questions concerns or issues.
  4. Dec 9, 2015 at 5:54 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Not at all good sir! Tagged my buddy who does welding to check out your thread. Nothing more than that. :thumbsup:
    DCLBFTW and jeffz0rz[QUOTED][OP] like this.
  5. Dec 11, 2015 at 7:05 AM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    Fuck yes
    jeffz0rz[OP] likes this.
  6. Dec 11, 2015 at 7:43 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I am about to swap out my tired factory rear leaf springs with an OME Dakar set, do a U-bolt flip kit, and install extended Fox Shocks. I figure I will pull the bed off and stiffen up the whole rear with these frame boxing plates.
    I have not looked under the truck to determine if I have to pull off the rear high clearance bumper. Do you think the bed can come off without pulling the rear bumper? It has tire swing out and is heavy so I would leave it if I can.
  7. Dec 11, 2015 at 9:04 PM
    jeffz0rz
    san diego
    Should be able to pull the bed without pulling the bumper easily
    Desert Drifter likes this.
  8. Dec 13, 2015 at 7:23 AM
    jeffz0rz
    san diego
    1. Desert Drifter - paid
    2. glorifiedwelder - pending
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
  9. Dec 13, 2015 at 7:32 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Nice - I know this is like the dreaded "subbed" but I like this a lot.
    And with regards to crashes, calculated weakness is key. Plating your frame is for those that want strength and don't want as many cracks in their body panels :).
    Strength is good for wheeling. Weakness is good for crash tests. Look at the weak bumper mounts, thin sheet metal, crack-prone 'crumple zones, etc., as evidence the truck was designed and built for crash test results and low cost to manufacture. Look at reinforcements like this if you are trying to build something that can take a relative beating. :)
  10. Dec 13, 2015 at 10:39 AM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Where you able to snag any pics of your open style?
  11. Dec 13, 2015 at 10:50 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've been looking for a kit like this for our trucks for a while. I may possibly be interested!
  12. Dec 13, 2015 at 11:18 AM
    jeffz0rz
    san diego
    3. 12TRDTacoma - mabey might possible could be thinking about potentially being interested
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    Here is the windowed version. Allows access to the inside of the frame for cleanimg, or running fuel lines, power lines ect.
    SonnyBones, 12TRDTacoma and deadhed61 like this.
  13. Dec 13, 2015 at 12:02 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    You have my attention! Have these been installed on any trucks? It'd be nice to see them on a truck.
  14. Dec 13, 2015 at 12:17 PM
    jeffz0rz
    san diego
    Psst. Check the first post.
    12TRDTacoma likes this.
  15. Dec 13, 2015 at 12:21 PM
    #35
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    I'm referring to the open style
    AKK likes this.
  16. Dec 13, 2015 at 12:28 PM
    #36
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    This is an awesome idea, isn't it stronger if you stitch weld INstead on straight up welding the whole seam?
    Deff. Interested!
  17. Dec 13, 2015 at 1:29 PM
    #37
    jeffz0rz
    san diego
    Stronger ? No, not necessarily, but anything is stronger than the stock open channel.
  18. Dec 14, 2015 at 1:44 AM
    #38
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Have a 1st gen version and does it count in the gb? :pray:
  19. Dec 14, 2015 at 6:08 AM
    #39
    jeffz0rz
    san diego
    I will draw up a set as soon as I get ahold of a first gen
  20. Dec 14, 2015 at 8:07 AM
    #40
    Papa Taco
    Jared
    Socal
    I'm not able to get in on this group buy but I'll be picking up a set in January or February for sure
