2nd gen frame box plate kit
Discussion in 'Automotive Group Buys' started by jeffz0rz, Dec 9, 2015.
  1. Sep 11, 2018 at 7:37 PM
    #541
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    IIRC, the information isn't on the website. I sent them an email and got all the specs, photos (above) and pricing.
  2. Sep 12, 2018 at 5:35 AM
    #542
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    completely baffles me as to why anyone going through the effort to plate their frame would leave the weak OE crossmember in there ?
    Caboose117 likes this.
  3. Sep 12, 2018 at 6:03 AM
    #543
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    It offers strength in all directions. A few pieces of DOM in one plane is weaker.
    Edit: I’ve seen some beefy improvements, but at a cost of considerable added weight, ie. 3x4 square tube.
  4. Sep 12, 2018 at 1:14 PM
    #544
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Although I understand the premise of your statement my personal experience is the exact opposite. That OE X member is so weak you can literally twist it with your bare hands. With my OE member when I opened my swing gate the entire frame would twist, after removing the OE X member and replacing it with a simple tube X it drastically reduced that rear frame twist.
    In addition on a separate point...why go through all that work to leave the OE spare cross member unless you are one of the 1% that might be plating your frame and still running a tire size that would actually fit in there. Makes far more sense to get that useless thing out of there and fab a new cross member that would open up space or make the space usable for something else IE: air, water, fuel
    deadhed61 likes this.
  5. Sep 12, 2018 at 1:20 PM
    #545
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    A simple X with 1.5” tube would not weigh very much at all....
  6. Sep 12, 2018 at 3:21 PM
    #546
    Hawk373
    2012 TRD Sport DCLB
    When I did my frame box kit and DMZ install I recalled the complaints I had read about and paid close attention to its construction. I even bounced the idea of it being weak off of Tim. He expressed most of the “upgraded” x bracing he’d seen offered less rigidity and the work to duplicate its design wouldn’t net a lot of gain. My observation is people tend not to tie the tubes through both the plate and the frame as well. Admittedly, all of my knowledge is based off online photo espionage, Tim and an old career as a structural fabricator, but I digress. I’ve noticed the tubing crossmembers in Silverados pass through both sides of a boxed frame and look very strong.
    I can’t find the reference, but recall reading the newer crossmembers are more robust than past years. I have considered adding plate on the bottom just for your and other’s arguments sake, but hesitate because of all the crud and salt that may collect.
    I’d only remove it completely if I was caging the whole truck. The kit worked out good for me and I assume a lot of other trucks. I have no designs on water tanks and giant air tank expo stuff, but the transition wouldn’t be difficult if something like that started to appeal to me. It would have been less efficient (time/money) to cut out and redesign the diaphragm for a mod I don’t intend to do.
    With all that said, it’s likely Tim may have a solid plate kit or the resources to create one.
  7. Sep 13, 2018 at 7:02 PM
    #547
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    On his web site it's just and extra 25$ I think for dimples
    Hawk373[QUOTED] likes this.
  8. Sep 13, 2018 at 7:04 PM
    #548
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
  9. Oct 1, 2019 at 6:19 AM
    #549
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Anyone got any first hand experience with the DMZ fab frame boxing kit? Definitely interested in it just for the ease of installation, but I could buy a sheet of 3/16" for the same price and cut my own plates...
  10. Oct 1, 2019 at 6:24 AM
    #550
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    You could but you have to consider the value of your time. The DMZ kit fits REALLY well, and is designed to fit around the factory cross member left in place. I’d 100% buy that kit for the price over trying to make my own.
    My only complaint was the section where the gas tank was. You have to drop the tank and it’s tight with all of the fuel lines but there’s not many other options really. You could leave that section out and still serve your purpose
    Hawk373 likes this.
  11. Oct 1, 2019 at 6:28 AM
    #551
    Jerneyman
    Wes
    Huntsville, AL
    That's my thinking as well. Somebody else has already done the work of designing and cutting everything for me, I just get to weld. I'll probably save a bit and leave the holes not dimpled, I've got the right die at home to do it myself. I'll have to do a little bit of modifying to the plates since I added an additional crossmember to accommodate limit straps, but I don't think it would negate the time saved by buying these pre made.
  12. Oct 1, 2019 at 7:54 AM
    #552
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I have it
    I installed it
    Buy it
    End of thread
    :rofl:
    :welder:
  13. Oct 1, 2019 at 8:19 AM
    #553
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Do we know if the DMZ kits fit the 3rd gens?
  14. Oct 1, 2019 at 8:21 AM
    #554
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    @Tynan is working on a box kit, I believe he's going to test fit to his 3rd gen.
  15. Oct 1, 2019 at 8:21 AM
    #555
    desertjunkie760
    Shane
    Check My Sig.
    The dimples are really for cosmetics on this. I don't see how they can add rigidity to the plates. Save yourself the headache and buy the kit.
  16. Oct 1, 2019 at 8:22 AM
    #556
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    It does
  17. Oct 1, 2019 at 8:22 AM
    #557
    upTOPOverland_Drew
    Drew
    Littleton, CO
    thank you, sir!
  18. Oct 1, 2019 at 8:22 AM
    #558
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  19. Oct 1, 2019 at 8:26 AM
    #559
    Jerneyman
    Wes
    Huntsville, AL
    You know what the plate thickness is? I'm assuming its either 10 or 11 gauge.
  20. Oct 1, 2019 at 8:26 AM
    #560
    geekhouse23
    For those looking to ditch the factory crossmember and DIY a brace in the rear, I went with BCC plates from the great white north. The (un)official moose dollar to freedom dollar conversion is right around $100 shipped (freedom dollars) for their plates. Quality pieces and fast shipping. IIRC, it was about 4 days to the Midwest.
    http://bigcountrycustoms.com/product/second-gen-toy-taco-r-frame-plates/
