2nd Gen Frame Specs/Measurements - Tweaked frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ghardy, Oct 11, 2023.
  1. Oct 11, 2023 at 9:48 AM
    ghardy
    ghardy [OP] Well-Known Member
    Montana
    2013 Tacoma TRD Off-Road
    TRD Badged 5100 3rd Gen 2" Lift with ICON RTX Rear Leafs
    (SOLVED?) Hey again!
    Looking for 2nd Gen Double Cab Short bed Frame Specs/measurements as I think I have a minorly tweaked frame from where a previous owner had ran into a fence. Anyone have a DIY method to measure defects yourself? I’d imagine it will be super minor correcting 1degree of camber
    The problem: Les Schwab tells me that at JBAs specified alignment specs when I’m at 4.5deg caster I am 1 degree off on camber no matter what they do (lagging back on the drivers side where the vehicle was hit by the fence)
    -Alignment 1: N/A – 1.5” spacer on 5100s, stock UCAs… seized LCA
    -Alignment 2: N/A – TRD 5100’s 2” lift, stock UCAs… seized LCA… Tech folded Alignment tabs incidentally
    -Alignment 3: TRD 5100’s 2” lift, stock UCSs, straightened and welded alignment tabs, new greased alignment bolts (one side SPC one side NAPA greaseable…). This alignment concluded that they were having issues balancing caster/camber with stock UCSs
    -Alignment 4: TRD 5100’s 2” lift, good tabs/alignment bolts, JBA 1-4” High Cater UCAs. The Tech had my alignment worse than I had it with the stock arms when I left… *this was partially my bad I did not provide the tech JBA specs*. They told me I was 1degree out on camber when they met caster at this point
    -Alignment 5: TRD 5100’s 2” lift, good tabs/alignment bolts, JBAs, *attempting at JBA Specs. Same issue as before They said you need to pick between either camber or caster but we can't do both
    *I had a great conversation with JBAs support team. These guys are super helpful! He'd pointed me in the direction of correcting a potentially bent frame (attached if you're bored and like to read). Most notable quote from out conversation
    "Toyotas have a very uncommon and relatively weak single shear upper arm mounting format that`s quite easy to tweak. That`s the bad news, the good news is that which is easy to tweak out of whack is also easy to tweak back where it should be. ;) "
  2. Oct 11, 2023 at 10:00 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Why the psychological 4.5 deg of caster? Just run less caster if you need to. May in fact be better to have less caster on the driver's side to compensate for road crown.
    You're more likely to bend the spindle than the UCA mount.
    ghardy[QUOTED][OP] likes this.
  3. Oct 11, 2023 at 10:17 AM
    ghardy
    Montana
    My goal isn’t to get 4.5deg caster at this point. I really just want to be able to drive straight with a straight wheel without burning tires up. And I guess they were having an impossible time even doing just that.
    How would you know if your spindle was bent? I have it in at another shop today for a second opinion… so we’ll see
    In the accident where the guy hit the fence it snapped the drivers side strut too I guess (i believe this failure was due to a sharp vertical force when he dropped 3-6’ vertically off the road into the ditch right before he hit fense)
  4. Oct 11, 2023 at 10:33 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would think 2.5-3.0 positive caster would be sufficient.....caster want wear tires
    ghardy[OP] likes this.
  5. Oct 11, 2023 at 12:20 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Caster just affects the self-centering behavior of tires. FSM value for caster is less, like 2-3 deg. Higher caster can lead to higher steering effort. Priority is to get camber to 0 to minimize tire wear.
  6. Oct 11, 2023 at 12:39 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Have you went to a different alignment shop? Why don’t think the frame is tweaked? Is that your truck pictures in conversation with JBA?
  7. Oct 11, 2023 at 12:43 PM
    ghardy
    Montana
    Crisis averted! The second opinion was able to get the vehicle into JBA alignment specs no issues. The thing drives straight now too... 7 alignments later.
    Fun fact, the new shops initial readings of my alignment that les Schwab had left me with not even 15hrs prior didn't even hardly resemble the the results of the new alignments places initial readings
    Tire-Rama on 4th Ave in Billings Montana is the place to be apparently!!
    3JOH22A likes this.
  8. Oct 11, 2023 at 12:45 PM
    ghardy
    Montana
    Thanks again to everyone input! Certainly helps rest my nerves haha
  9. Oct 11, 2023 at 1:38 PM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Glad you got it solved.
    Les Schwab is the absolute worst. I regret it every time.
  10. Oct 11, 2023 at 1:42 PM
    ghardy
    Montana
    yes it is! Which made it very easy to imagine that the frame had been bent haha
