2nd Gen. Gauge Lens Replacement How To
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Runn0r, Jan 15, 2013.
  1. Jan 15, 2013 at 12:26 PM
    Runn0r
    Runn0r [OP] Well-Known Member
    NC
    07 Prerunn0r
    Hello All,
    The previous owner of my Tacoma decided it was a good idea to clean the gauge cluster lens with some sort of solvent, thus clouding up the plastic and scratching it to pieces. Luckily I found a replacement lens on Ebay for $20 and I thought I'd share the process. Images are numbered in order of steps.
    1) Remove two screws from above the gauges.
    2) Pull out kicker panel to expose lower bolt. Remove both lower bolts (10mm) socket.
    3) (somewhat gently) work the lower panel off to the floor.
    4) Work the upper panel off from around the gauges. Unplug dimmer switch when exposed.
    5) Gently press down on the rear of the tabs holding the gauge lens to the cluster.
    6) Gently press new gauge lens back into proper holes until the tabs (click) into place.
    7) Replace panels in same order. Be sure press up and back on top of upper lip of the gauge panel so that the grooves align and seat well.
  2. Jan 15, 2013 at 12:34 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Posting this on my led swap thread so people can not ask how to take it apart :anonymous: lol
    Good write up.
    reallifedog likes this.
  3. Jan 15, 2013 at 3:10 PM
    Runn0r
    NC
    07 Prerunn0r
    Those LEd swaps are cool. I may have to consider that in the future.
  4. Mar 21, 2013 at 4:35 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    Great write up!
    I was a dumbass today and managed to drop my airport parking stub down in front of the lens, where it promptly disappeared into the dash before I could grab it. Looked like I was going to have to pay the exorbitant maximum fee.
    But... armed with my phone, the pics in this post, and a leatherman tool I was able to disassemble the dash enough to get the ticket back.
    Thanks Runn0r! I owe you a beer, or several.
    Knudsen and Black97v6MT like this.
  5. Mar 21, 2013 at 4:43 PM
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    Thanks for the write up. I just bought a used Tacoma as well. The original owner did the same thing. Looks like he cleaned it with acid and a S.O.S pad. Was your lens an aftermarket or OEM that some one was getting rid of?
    Black97v6MT likes this.
  6. Apr 16, 2013 at 8:15 AM
    Runn0r
    NC
    07 Prerunn0r
  7. Apr 16, 2013 at 8:26 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    Haha! I see ASS METER ;P on the last pic
    Black97v6MT and DDD like this.
  8. Apr 16, 2013 at 8:30 AM
    TRDMike66
    TRDMike66 Well-Known Member
    so. cal.
    2007 TRD SR5 Package
    Bilstiens 5100's all the way around, wet okale seat covers, red led interior lights,Level 8 Guardians wrapped with Hankook Dynapro's 260/70/17 and 35mm caps/black gorilla lugs,sock monkey TRD So Cal Bedside Decals BANKS-Monster Cat-Back Exhaust, Light Racing Upper Control Arms, One of a kind satoshi grille thin lip by Homer Taco.
    great write up
  9. Jul 29, 2015 at 5:48 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Has anyone ever figured out what the part number is for the push-pins in picture #1 and 2 up there? I broke one of mine :(
  10. Jul 29, 2015 at 8:18 PM
    snowmanwithahat
  11. Jul 29, 2015 at 8:22 PM
    NmBeefTaco
    NmBeefTaco Well-Known Member
    Greg
    New Mexico
    18 TRD Off Road Access Cab
    Toytec Boss lift, AAL, Ride rite air bags, Daystar cradles, Total Chaos UCA, Icon 17 inch Rebounds, 285/70R17 BFG KO2s, Ruff country 30” LED light bar kit, ruff country tri fold bed cover. Interior LED lighting and lic./reverse LED lights.
  12. Jul 29, 2015 at 8:28 PM
    snowmanwithahat
    Also, since I'm bumping a 2 year old thread I'd might as well explain. I went through the same process on my 2013 because some idiot tried wiping dirt off with a highly abrasive cleaner and it etched the plastic. I ended up ordering the replacement glass from camelback toyota and broke one of the clips in the process.
    For reference, the glass is this....
    http://parts.camelbacktoyota.com/pa...L&subgroup=CLUSTER & SWITCHES&component=Glass
    jbaker1976 and delvin like this.
  13. Aug 2, 2015 at 7:36 PM
    snowmanwithahat
    Those clips in my previous post fit great!
    deanosaurus and REDdawn6 like this.
  14. Oct 14, 2020 at 10:18 PM
    jesusjones142
    jesusjones142 Well-Known Member
    none
    Subbed so I can reference later
  15. Oct 15, 2020 at 3:19 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Ive replaced mine twice now. The plastic scratches SO easy! I use compressed air first to clean then i saturate it with plexus cleaner and carefully wipe it clean
  16. Oct 15, 2020 at 3:40 PM
    jesusjones142
    none
    I accidentally got interior polish splatters on it and didn’t notice so it soaked over night. When I finally noticed it was already dry but seeped through the plastic leaving splatter stains that I cant get out. Cheap ass stuff.
  17. Dec 27, 2021 at 9:54 PM
    elperroverde
    elperroverde Well-Known Member
    2012 Tacoma Wine TRD 4x$
    Stock
    Hey guys. Taking alive old
    Post, have you ever try (or now if is possible) to replace bulb for light indicators as in older cars? .. I just found that my check engine light does not work in dash and thinking to take it apart to see if would be a blown bulb
    Or something like that, thanks
  18. Dec 28, 2021 at 5:21 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Your cluster has led chips (bulbs). You can still replace them but it’s not as simple as pulling the old bulb out of the socket and replace with new.
  19. Dec 28, 2021 at 9:31 AM
    elperroverde
    Stock
    dang, just what I though, Should be a led that need to be solder to the board I believe.
  20. Dec 28, 2021 at 11:13 AM
    Steelhead Bum
    Mitchell
    Eastern WA
