2nd Gen Grill/Front End Conversion Updated Info
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elk Lodge, Nov 1, 2015.
  1. Nov 1, 2015 at 8:02 AM
    Elk Lodge
    Elk Lodge [OP] Member
    Wanting to upgrade the look of my 2005 to the newer grills/front end/headlights. Please provide updated info on this subject, as it is difficult to find.
  2. Nov 1, 2015 at 10:56 AM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
  3. Nov 1, 2015 at 11:38 AM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    I used that guide above as reference but it was a missing a part here and there but for the most part it is super easy to do. Took myself about two hours start to finish with all the parts ready.
  4. Nov 1, 2015 at 11:41 AM
    Yoda's TRD
    David
    Haslett, MI
    nice job, looks great so far
    are you considering the "sport" style mirrors ?
  5. Nov 1, 2015 at 11:42 AM
    zeekevin
    San Diego
    nope, that truck was sold.
  6. Nov 7, 2015 at 11:10 PM
    Pre runner2011
    Pre runner2011 Jekyll 2 Hyde
    Tucson Arizona
    2011 DCLB Prerunner
    K&N air filter, Banks Monster exhaust, steel screen grille, off road led lights, 3" Pro Comp suspension lift kit, 33x12.50-17 mud hogs, 17x9 Pro comp Stryker Wheels
    Buy the one you like and take your time putting it in.
  7. Nov 8, 2015 at 2:17 PM
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
    Very nice, was thinking bout doin it. Cost?
  8. Nov 8, 2015 at 2:34 PM
    zeekevin
    San Diego
    1k-3k
  9. Nov 22, 2015 at 7:18 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    So I know it says you need the hood as well... Is it really necessary? If i'm going to be using an aftermarket bumper, do I need all of the little pieces you don't see? Ie. little brackets and mounts... I'm planning on just getting the headlights, little panels under the lights and grill then using an aftermarket bumper... would that work?
  10. Nov 22, 2015 at 8:45 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    if you are going to use a plate bumper instead it saves you about 1/3 the work and cost. go look at homertaco's build thread for an example of that. you can ask him what other parts he did and didn't use.
    you do need a new hood (also lock and arm), the new grill is wider and taller, and wont allow your old hood to lock down anymore. there are some additional fiddly bits and connectors that you will need.
  11. Nov 22, 2015 at 11:32 PM
    zeekevin
    San Diego
    simple answer yes. only thing you wouldn't need is the fender liners front bumper and front bumper crash bar and some of the smaller clips that hold the bumper on.
    the little panel under the headlight clip into the little bracket which also ties into the fender, the headlight leg clips into one of the other brackets and ties into the hood support bracket with the hood latch.
  12. Nov 23, 2015 at 8:30 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    The brackets under grill you will need because headlight one part mounts to brackets and head light filler one end mounts to brackets. Hood latch I thing will work got pic of comparison. Hood totally diferent so will need.
    Edit new pic #1 were headlight filler mounts on bracket
    #2 were head light mounts on bracket
  13. Feb 5, 2016 at 2:12 PM
    808tako
    808tako Active Member
    06 tacoma
    Hey bro I'm right about to do this and I am using rg11 thread as a reference also. But I noticed that it was missing parts also . Can you let me know what parts are missing and also if it is possible to use the existing reinforcement bar/crash bar on my 06 Tacoma instead of buying the new 2012 crash bar ?
  14. Feb 5, 2016 at 3:09 PM
    808tako
    06 tacoma
