2nd Gen Headlight Removal, pics
Discussion in 'Lighting' started by Chris(NJ), Dec 13, 2010.
  1. Sep 1, 2011 at 12:57 PM
    #81
    strikehold
    strikehold Member
    Hi, Hope this finds u well. I have a 2009 Taco 6 speed man. and I pull a three thousand pound travel tralier. I still only have under ten thousand miles on it.
    \\\\ Have you had any problems with the transmission?????????? Thanks
  2. Sep 1, 2011 at 3:48 PM
    #82
    Chris(NJ)
    Chris(NJ) [OP] Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    No problems at all, strikehold.
  3. Sep 7, 2011 at 7:31 AM
    #83
    Shaun8180
    Shaun8180 Member
    Shaun
    San Antonio, TX
    08' Taco 6" lift 35 mudders 4.0 V6
    black headlight mod, blacked out badges, 6" pro comp lift, 35" mudders on 17" rims, K&N drop in air filter
    blacked out the lights on my 08' taco. hardest part was gettin the damn lens assembly apart.
  4. Oct 1, 2011 at 3:29 PM
    #84
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    Just replaced my glazed over OEM headlights with new ones, no foo-foo / gaper light mods for this pro use truck. Peeling back the fender liner makes getting to the 4th bolt laughably easy. Besides that, I have my 10-15mm sockets and various drive extensions wrapped in Gaffer's tape for grip, makes this kind of around the corner stuff super easy. Nothing like a tiny 10mm driver to get most of the turning done without slipping off before you even get the wrench in there.
    And yeah, don't fight with the lights, just turn the driver side to 2:00 O'Clock and the passenger side one to 10:00 O'Clock, poof! they come right out.
    This took me about an hour including cleaning...
  5. Oct 2, 2011 at 7:31 AM
    #85
    JTFisher
    JTFisher New Member
    James
    Goldsboro, NC
    08 PreRunner
    16X9 ATX Artillery Wheels, 245/70 BFG All Terrains, Spyder Black Halo LED Headlights, JDM Black Altezza Tail Lights
    Put a set of Spyder HID headlights w/HALO's and LED's in my 08 PreRunner and it wasn't too bad an experience. Getting the old guys out was a pain, especially the one bolt on the bottom everyone fusses about. Putting the new ones in was really no problem since they already had a wire harness for plug & play into the stock headlight plug. Only had to wire in the HALO's and LED's. Hardest part really was finding a flat enough spot to park in front of a building to adjust the headlight beams since they were WAY off. Backside of a local Wal-Mart worked just fine ;)
  6. Oct 22, 2011 at 5:23 AM
    #86
    DocTaco
    DocTaco Well-Known Member
    Central, KY.
    17 TRD DC Off Road V6 Tow Pkg
    The OP painted his Blue to match his truck. My question is.... HAs anybody done this and color matched the Barcelona Red? Just wondering how it looks. Would like to see a couple of pics before I do mine.
  7. Oct 26, 2011 at 6:05 PM
    #87
    nharleydon
    nharleydon Member
    Don
    Connecticut
    06 SR5 TRD
    Tonneau Cover, Smoked Rear LED's tailights. 2" AAL, 5100's
    Very good job with the write up. I broke he tab that holds the clip and had to replace the whole assembly. The pictures were a great help, thanks. I used a gearwrench for that tricky screw. It was easier than using a socket.
  8. Oct 27, 2011 at 12:14 PM
    #88
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Thanks! Glad it was of help to you :thumbsup:
  9. Nov 12, 2011 at 7:05 AM
    #89
    Yugo2slo
    Yugo2slo Member
    Tony
    Arizona
    06 PreRunner
    Black Head Lights
    I installed my lights almost a year ago. (I bought blacked out lights, I didn't bake mine.) No problems at all. I sealed them and then yesterday one started to have moisture inside. So I am assuming I need to take the light back out. How do I get the moisture out? Then reseal? Any suggestions would be appreciated. Thanks!! :cool:
  10. Nov 12, 2011 at 7:52 AM
    #90
    Yugo2slo
    Yugo2slo Member
    Tony
    Arizona
    06 PreRunner
    Black Head Lights
    They are already black, I just want to get the moisture out.
  11. Nov 12, 2011 at 9:18 AM
    #91
    Kodachrome
    Western Colorado
    I am having the same issue of a leaky headlamp, but it is just a eBay OEM style one that is doing it. Problem I am going to have is that I now have a bull bar in the way:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/164975-bumpers-2nd-gens-only-9.html#post3984647
    Any opinions as to if I will be able to work around having to take the bumper off?
    #91
  12. Nov 13, 2011 at 6:39 PM
    #92
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    afaik, Headlights should be swappable from 2005-2011, since 2012 the headlights have be re-designed.
    The taillights should be swappable too. Unless the wiring harness has changed...
  13. Nov 21, 2011 at 11:15 PM
    #93
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    Just wondering how you got that clip released on the trimpiece below headlight. I started to do the headlight removal and stopped because I thought I was going to break that trimpiece, couldnt get it off. Your pic shows it without the headlight in. how do you do it when its in?
  14. Nov 22, 2011 at 12:05 PM
    #94
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    Very cool. Tnx for the pics. :cool: I bought HID headlights awhile ago and now am ready to install them. A lot of aftermarket sites say 6000K is white, but all the OEM Audi bulbs are 4300K...HID low beam and super bright Xenon high beams...I'm looking for HID fog lights that fit the stock fog light opening. Any ideas?
  15. Nov 23, 2011 at 9:33 AM
    #95
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Just take a long flat headed screw driver. once the inside is loose, you can pull it away enough to stick the head of the screwdriver in there and depress the clip. I only took that picture w/ the light out b/c it was easier to show the process. It would've been tough to capture the clip w/ the light still in.
  16. Nov 27, 2011 at 8:41 AM
    #96
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    So I'm assuming you have to remove the front grill to remove the headlights? how hard is that. I've never had to do that before.
  17. Nov 27, 2011 at 11:04 AM
    #97
    replica9000
    2019 T4R ORP
    The front grill has two bolts on top, and two clips at the bottom.
  18. Nov 27, 2011 at 12:48 PM
    #98
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yes, you do. Its extremely easy and should take no more than 5 minutes. 10mm or phillips screwdriver and you're good to go.
  19. Dec 8, 2011 at 7:21 PM
    #99
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    just replaced my headlights, thanks for the helpful pictures and info in this thread!
  20. Dec 8, 2011 at 7:37 PM
    #100
    Chris(NJ)
    08 Indigo 4x4 DC OR
    :thumbsup:
