2nd Gen heater hoses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taniwha, Sep 19, 2024.
  1. Sep 19, 2024 at 9:23 AM
    Taniwha
    Taniwha [OP] Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    I'm replacing the rad hoses on my '09 and was thinking of doing the heater hoses at the same time. They look kinda gnarly to get at. Anyone done this?
  2. Sep 19, 2024 at 9:28 AM
    Taniwha
    Dave
    Kamloops, B.C.
    NVM, WTF! Toyota parts Direct says around $200 bucks for each hose! Rad hoses were $60 apiece
    Steves104x4 likes this.
  3. Sep 19, 2024 at 9:31 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s like 42 million Canuckistikian pesos!
    joba27n likes this.
  4. Sep 19, 2024 at 9:34 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Fhat the wuck...what are they made of, platinum?
  5. Sep 19, 2024 at 9:36 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Straight/bulk hoses no good for heater core?
    It mite be expensive for OEM, but it’s a lot cheaper than dumping your coolant on the highway!
    O17297 and Steves104x4 like this.
  6. Sep 20, 2024 at 7:38 AM
    Taniwha
    Dave
    Kamloops, B.C.
    True story. It is a case of convenience to replace the heater hoses. They still look ok. I put a spool piece in the upper rad hoses for a temp. sender and it's not sealing great. Over time the middle of the hose where the spool piece goes has expanded quite a bit in diameter. Thought while it was drained I'd replace heater hoses. They don't 'look' that bad. Lots of sharp bends in them so bulk hose would be tough
    Knudsen[QUOTED] likes this.
  7. Sep 20, 2024 at 7:42 AM
    Knudsen
    Jon
    Too bad…
  8. Sep 20, 2024 at 3:44 PM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Search around for the part number. Granted there was a promotion going on but I got the "big" and little heater hoses for probably $150 combined. Still pretty crazy for a rubber hose; but the last ones held out for 200k so I'm buying in to the hype.
  9. Sep 20, 2024 at 7:56 PM
    ABA180
    East Bridgewater MA
    I ran into this long ago with a GM vehicle. Parts guy gave me some straight hose, elbows, clamps, fittings. Ugh. But it got done.
  10. Sep 21, 2024 at 1:44 AM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    I replaced my heater hoses with aftermarket parts the other year ... probably mostly 'Gates' brand.
    Perhaps Toyota hoses would have been better... but I think new aftermarket hoses are probably better than 15+ year old stock hoses. I honestly don't know. I probably spent more like $60 on all the heater hoses -- that's a guess, but no way it was $200.
    I was removing the heads though, so I had to remove all the hoses anyway. It made sense to replace all the hoses and gaskets along the way.
    Replacing the hoses just for the sake of replacing the hoses would be a pain in the ass, though... in my opinion, not warranted without signs of wearing out. Pretty sure you have to remove the upper and lower intake manifolds to get at them. If you're going to dig that deep for no reason, may as well also replace the marzlevane seals and rebalance the waneshafts.
    Another reason I went aftermarket: I couldn't figure out the Toyota catalog. To this day, they don't show actual pictures for most products, and their diagrams are consistently confusing, contradictory, and useless. I bought the radiator hoses from Toyota, but I gave up for the rest. What worked -- for all but one hose of the whole coolant system -- was to browse the Rock Auto catalog, and identify each hose by photograph... holding the old ones from my engine in my hand for comparison.
    Knudsen likes this.
  11. Sep 21, 2024 at 8:56 AM
    Taniwha
    Dave
    Kamloops, B.C.
    Torn about spending the money, but with it drained for the rad hoses and 225,000 kilometres on the truck, prolly prudent. I'll check around for prices.
  12. Sep 21, 2024 at 9:03 AM
    Taniwha
    Dave
    Kamloops, B.C.
    Got a guy on each shoulder whispering/yelling in my ears. One sounds like you ;-) and the other says replace it all just in case. Got time on my hands as it's not my daily driver, so I'll decide after hearing from the fine folk on TW
    mk5[QUOTED] likes this.
  13. Sep 21, 2024 at 5:56 PM
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    I spent a huge amount on dealer parts to refresh my '12, enough that adding $350 or whatever for $60 worth of hoses didn't really make the bottom line jump much. I got a bitchin' deal on the truck itself and there was also a 15% off deal at the time so I am splurging a bit and keeping it almost entirely OEM. If I were just doing it as a "while I am in there" thing and budget conscious; I think going 3rd party is totally legit. I'd argue harder on the value of dealer parts for things like wheel bearings where labor is high, and quality of components matters a lot.
    ABA180 likes this.
  14. Sep 21, 2024 at 6:20 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Jimmyh likes this.
