2nd Gen hood vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Waunderin Will, Mar 26, 2022.
  1. Mar 26, 2022 at 12:33 PM
    Waunderin Will
    Waunderin Will [OP] Active Member
    2017 White TRD Off Road
    So far just a tailgate light bar and replaced the backup lights with LEDsl Eventually I'd like to put a topper on it but not many options out there yet. I'm leaning towards a Hi-rise type just for the room. But then again it would be nice to keep the truck in the garage :)
    Has anyone figured out exactly why the hood vibrates/shakes and what has been a fix???
  2. Mar 26, 2022 at 12:36 PM
    Waunderin Will
    What I have personally figured is the 1) the latch can't be adjusted down; 2) the metal/cross support flexes
    I'm afraid that eventually something is going to give and have my hood go flying up while driving down the road.
  3. Mar 26, 2022 at 1:16 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Try to adjust the rubber bushings. If they are old and broken then try to see if you can buy some somewhere.
    wi_taco likes this.
  4. Mar 26, 2022 at 1:24 PM
    Waunderin Will
    So I've tried adjusting the bushings out at the corners of the hood to the point where it's pushing up the hood past the fenders (not flush) and the hood still vibrates a bit but better. However I shouldn't have to adjust them down that far just to stop the shaking hood.
  5. Mar 26, 2022 at 1:27 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Is the entire hood shaking like it's not latched properly or is the sheet metal itself vibrating from the wind/driving down the road?
  6. Mar 26, 2022 at 2:11 PM
    Waunderin Will
    It's like the entire hood shakes. I would keep thinking that I forgot to latch it but discover it was latched.
  7. Mar 26, 2022 at 2:29 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Love my 2nd Gen :)
    Waunderin Will[OP] likes this.
  8. Mar 26, 2022 at 2:45 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I think I'm lost,,, you have a 3rd gen but question is on 2nd gen hood?:confused:
    wi_taco likes this.
  9. Mar 26, 2022 at 4:37 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    just put some hood pins in it
  10. Mar 26, 2022 at 7:21 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The front bushings are adjustable, adjust them until it stops.
  11. Mar 27, 2022 at 5:55 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Your truck has the Elvis syndrome.
  12. Mar 27, 2022 at 6:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    If your latch is secure and the stops properly adjusted, the hood will not blow off. What you are likely seeing is the hood skin shaking.
    Guessing the bonding material between the hood skin and frame has spots detached or MIA.
    Verify that. If correct, easy to fix.
  13. Apr 2, 2022 at 4:10 PM
    Waunderin Will
    To All Tacos Float..... !st off I assume you're prior Navy .... Thank you for your service shipmate. To clear things I had a '17 DCSB (lease) but traded it for an '08 Tacoma DCLB. The hood vibrates/shakes as if I had not latched it down but it is. I've tried adjusting the dampeners down and it has helped but squelched it. Soooo I post my question..... in hopes of a solid answer. I see someone had suggested hood pins. I don't rule that out, but still I wonder if I'm the only one with this problem.
  14. Apr 2, 2022 at 4:12 PM
    Waunderin Will
    Also to continue from my last..... The confusion on my present Tacoma is the fact that I can't / have yet to figure out how to update my status/information. Any help on that????
  15. Apr 2, 2022 at 4:16 PM
    Waunderin Will
    To also help visualize the problem the hood raises up and down driving interstate speeds even with the adjustable rubber stoppers pushing the corners of the hood up.
  16. Apr 3, 2022 at 10:17 AM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    There are also 2 rubber dampeners in the fender channel where the right and left sides of the hood rests. When I bought my 07, it had a similar issue. Took me awhile of looking to notice something so simple, but after replacing the missing piece, the shaking is much reduced.
