Fox Coil Springs for 2nd gen Coilovers. Middle TN
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 14Tacos4me, Jan 22, 2025.
  1. Jan 22, 2025 at 7:45 PM
    14Tacos4me
    14Tacos4me [OP] Well-Known Member
    Daniel
    Hendersonville, TN
    2014 Blue Ribbon DCSB TRD OR 4x4
    -Fox 3 inch lift -SOS Streamline front bumper with Smittybilt x20 winch -Mobtown sliders -Mobtown IFS & Trans skids -DV8 Rear bumper - Look at the build thread
    Located in Hendersonville, TN (Nashville area)
    $100.00 Fox Racing coil springs 13” 600lbs/in 3” inner diameter for 2.5 inch shock
    [​IMG][​IMG]
    Feel free to reach out with any questions.
  2. Jan 23, 2025 at 4:49 AM
    kmbldr
    kmbldr Well-Known Member
    Kevin
    Nederland, CO
    Pm sent
  3. Jan 24, 2025 at 3:02 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I'll take the knobs. PM incoming.
  4. Jan 29, 2025 at 5:33 PM
    14Tacos4me
    Daniel
    Hendersonville, TN
    Bump, cleaned up the sliders.
  5. Jan 30, 2025 at 7:37 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    What is the point of the hubs with the NSK bearing? Is that just something you need when it breaks? Or do people replace them as an upgrade?
  6. Jan 30, 2025 at 7:43 PM
    14Tacos4me
    Daniel
    Hendersonville, TN
    Mostly replace when they wear out. If you’re running big tires, a lift, or doing other things that might put more wear on your hubs you want to get the strongest components that bolt right in. These also come with the bearings already pressed in which is typically a pain to do.
    I thought my hubs were beginning to show wear at one point but it was a combo of bad balancing and brake noise so I never ended up needing these.
  7. Jan 30, 2025 at 7:47 PM
    wdunnlee
    Will
    Tidewater VA
    Got it, and is that common per say that they wear out after a lift and bigger tires?
  8. Jan 30, 2025 at 8:36 PM
    14Tacos4me
    Daniel
    Hendersonville, TN
    They wear out in general especially if they have to deal with more weight, towing, lots of 4x4 use, things that put strain on them. Bearings especially are wear items, and in this case it’s usually easier to replace the whole hub assembly.
    Are you interested?
  9. Jan 31, 2025 at 12:50 PM
    wdunnlee
    Will
    Tidewater VA
    Just the front ones wear out?
  10. Feb 1, 2025 at 7:08 AM
    14Tacos4me
    Daniel
    Hendersonville, TN
    In the case of the Tacoma that mostly seems to be the case, probably due to having IFS. The easiest way to check your hubs is to lift the wheel off the ground grab either side of the tire and shake it to see if there’s play.
  11. Feb 18, 2025 at 3:20 AM
    wdunnlee
    Will
    Tidewater VA
    I’ll take the wheel bearings, PM me.
    14Tacos4me[OP] likes this.
  12. Feb 21, 2025 at 4:42 AM
    14Tacos4me
    Daniel
    Hendersonville, TN
    Updated to reflect what’s still available.
  13. Mar 19, 2025 at 4:29 AM
    14Tacos4me
    Daniel
    Hendersonville, TN
    Still have the power window bracket, and springs.
  14. Mar 31, 2025 at 10:39 AM
    14Tacos4me
    Daniel
    Hendersonville, TN
    Only a couple items left.
  15. Apr 2, 2025 at 6:26 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    Sending a message!
