2nd Gen Icon Lift Heights
Discussion in 'Suspension' started by Mitch, Nov 15, 2012.
  1. Sep 8, 2013 at 8:48 AM
    #41
    Dfm155
    Dfm155 Active Member
    2013 Tacoma Double Cab 4x4 TRD Off-Road
    None...yet!
    Year 2013
    Model DCSB TRD Off Road 4x4
    Engine 4.0L V6
    Measurement from Hub to fender (front) Driver 22 1/4" Passenger 22 15/16"
    Amount of lift gained Driver 2.375" Passenger 2.4375"
    Amount of thread showing on coil overs 1.5"
    Now my inner CV on my passenger side is pretty close to touching, if it isn't already, and was wondering if I lower my pass C/O will it help out the angle at all (aside from making the truck level)?
  2. Sep 9, 2013 at 12:04 AM
    #42
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Could you please expand on this "corrosion proofing" please?
  3. Aug 31, 2015 at 7:12 AM
    #43
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
    Year 2014
    Model DCLB TRD Sport 4x4
    Engine 4.0L V6
    Measurement from Hub to fender (front) Driver 21 3/4" Passenger 22 1/2"
    Amount of thread showing on coil overs Driver 1.625" Passenger 1.5"
  4. Sep 4, 2015 at 3:16 PM
    #44
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    2014
    Double cab, long bed, v6
    22 and 7/8ths driver
    22 and 5/8th passenger
    1 and 7/16 thread showing on both.
    Edit: I may have screwed up this measurement by not moving the truck between adjument and measurement. Or else they settled 1.5 inches.
    Patmac likes this.
  5. Sep 4, 2015 at 5:52 PM
    #45
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    how many rotations you end up doing? cv axles look bad?
  6. Sep 4, 2015 at 6:29 PM
    #46
    Arcticelf
    Gladiator
    6 down I think? It's about a 16th of thread exposed per turn. CV angle is okay, boot flanges barely touch, but I have a 1/2" diff drop.
    AE
  7. Sep 7, 2015 at 10:42 AM
    #47
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    i need to invest in a dif drop....
  8. Sep 7, 2015 at 3:42 PM
    #48
    Arcticelf
    Gladiator
    They are cheap, and easy to install.
    AE
    Patmac[QUOTED] likes this.
  9. Sep 22, 2015 at 5:31 AM
    #49
    Arcticelf
    Gladiator
    Update after three weeks:
    21 and 7/8ths driver
    22 and 1/8th passenger.
    Three more turns for 1 and 5/8ths thread showing. I hope I screwed up the first measurement, otherwise I lost 1.5" to settling.
    AE
  10. Mar 6, 2017 at 10:46 AM
    #50
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    This thread is from way back, but I was curious, several folks here are coming in at 24 inches hub to fender. I believe that's right around 4 inches of lift (I've read 20 inches is stock). Has anyone running that much lift encountered issues? I've read a bunch of time that you'll blow a CV boot, but there is a lot of hearsay on TW. So I would like to hear it from someone who has run that much lift for a long time. I ask because I am sitting at 23 now, and would like to come up another .75-1inch to come closer to level (4 inches of lift in the rear). I'm running extended travel icons with JBA arms.
  11. Mar 6, 2017 at 10:53 AM
    #51
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    2015 dclb 4x4.
    22.5" passenger
    22" driver
    Been running them 4 or 5 months.
  12. Mar 6, 2017 at 11:21 AM
    #52
    Arcticelf
    Gladiator
    droop out the front end and check for bind in your steering, ball joints and CVs. When you over-extend the CV and try to spin the tire (by hand) you'll know it binds and clicks.
    there is alot of TW talk about CV boots and letting the ribs touch, but I'm not sure how real that issue is. I'm not worried about it, personally.
