2nd gen Joying Head Unit Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben95, Feb 7, 2021.
  1. Jan 10, 2022 at 8:25 AM
    #481
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    Does your 2015 have the backup camera view in the mirror or in the HU?
  2. Jan 10, 2022 at 8:26 AM
    #482
    kcarlton831
    kcarlton831 Member
    Kurt
    It has the camera view in the head unit. Sorry I didn’t add that info in.
  3. Jan 10, 2022 at 9:19 AM
    #483
    fizik
    Minnesota
    OK, If you read back in this thread, you will find some posts about making the camera work when it the backup camera was already wire to the HU. I think there is a wiring harness you can get that will allow the connection without any splicing. I think it is this one https://www.amazon.com/PAC-CAMTY12-...gid=pla-570478023311&ref=&adgrpid=62412137260 but I am not sure.
  4. Jan 10, 2022 at 12:01 PM
    #484
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Killer launcher. That one is new to me. Bookmarking that one for sure.
    AdrenaliNate[QUOTED] likes this.
  5. Jan 10, 2022 at 12:37 PM
    #485
    fizik
    Minnesota
    I'm currently trying it out. It is pretty straightforward. It doesn't have all the different customization options that some of the other launchers have, but it looks factory and it is very easy to set up, and has enough customization that it should suit just about anyone.
  6. Jan 10, 2022 at 12:40 PM
    #486
    fizik
    Minnesota
    Bump... anyone else have knob "sensitivity" issues (innuendo not intended)? Beuller? Anyone... Beuller?
  7. Jan 10, 2022 at 8:51 PM
    #487
    AdrenaliNate
    AdrenaliNate Call me Nate
    Simi Valley, CA
    13 DCLB TRD Sport
    ICON Stage 3, 275/65-18 BFG T/A KO2, 18" KMC Monsters with custom caps, Access Lorado tonneau, Wet Okoles, AMP Research Powersteps, LED bed/hood/steplights, Fuseblock, ABS kill switch, Banks Pedal Monster
    It has a lot more customization than I first realized. It's nice to be able to change the theme colors (main and line color), but when you long press on each "button" it gives you the chance to rename, choose an app icon, and select an app to associate. Also, you can swipe one of the outer, smaller buttons to the center and it'll replace the clock/Toyota logo, etc.
  8. Jan 11, 2022 at 5:28 AM
    #488
    ItalynStylion
    Steven
    DFW, Tx.
    Yeah, from what I can tell it's basically a properly developed version of what I built by hand years ago. In the past, I was using an app that allowed you to build transparent widgets. So I'd build a rectangle over a static image/background and then you associate the widget with a specific app you want launched. It was tedious but worked great.
  9. Jan 11, 2022 at 12:58 PM
    #489
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    I'm saying that on the joying wire harness that connects to the Tacoma wire harness. One of those connectors has an attached yellow rca connector. That rca plugs into the joying headunit
  10. Jan 11, 2022 at 2:14 PM
    #490
    fizik
    Minnesota
    I think that one is the backup camera input (on my harness, it is labeled "camera in"). You plug the output from your backup camera into that. I think you need a special connector to convert to the Tacoma's backup camera to RCA. My camera is in the mirror, so I don't have that connection and can't say for sure what is required.
  11. Jan 11, 2022 at 5:05 PM
    #491
    scootter82
    Aurora, CO
    No special connector needed for my 2014 jbl with cam in head unit. It worked directly out of the joying box.
  12. Jan 11, 2022 at 6:39 PM
    #492
    fizik
    Minnesota
    Cool. I wasn't sure. The pictures I've seen of the JBL harness looks like it has a connector that plugs into the factory connector with the video line in it. But not having one, I wasn't sure.
    scootter82[QUOTED] likes this.
  13. Jan 12, 2022 at 3:37 PM
    #493
    Chrisinnirivera124
    Chrisinnirivera124 Member
    2015 Tacoma
    I need to upgrade soon
  14. Jan 13, 2022 at 11:34 AM
    #494
    fizik
    Minnesota
    Update on the knob issue... I can get it to happen quite often, enough that it has become very annoying. I contacted Joying about it and they have been quite responsive. They had me video it happening, had me check some settings and try a few other things. They are sending me a new "metal box" but not the display. From what they have had me try, I think that they think it has something to do with the steering wheel controls. Oddly, steering wheel controls work completely fine. <sarcasm on>No way it could be a dodgy knob... Noooooo...<sarcasm off> Well, I'll know if it is the "metal box" in a week or two when the new one arrives.
    Aside from the volume issue, I really like this HU. The user interface could have been better, but I've switched to AGAMA and like it. There are some other things I would like for it to do, but those are minor.
  15. Jan 13, 2022 at 3:43 PM
    #495
    hankbrob
    hankbrob New Member
    Chad
    2012 Tacoma DC Sport
    Just ordered a 9” no knob for my 2012.
    My backup camera is displayed on the rear view mirror. Is the general consensus that it’s worth connecting the camera to the head unit? Or is routing an HD camera like the one Joying sells a better option?
    I read through the sub and sounds like the stock camera is pretty low res/blurry on the HU but I didn’t see anyone mention whether the HD camera actually displayed as HD video on the screen.
  16. Jan 14, 2022 at 12:45 PM
    #496
    FishWolf
    FishWolf Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    So with the Joying unit, you are able to run Gaia GPS when no cell service is available? that was one of my main wish list items, does it use a satellite connection or do you download the entire map for that region on to internal storage, Thanks for all the awesome answers so far, Love this site
  17. Jan 14, 2022 at 1:33 PM
    #497
    fizik
    Minnesota
    I have not tried it, but I believe Gaia is supported. Here is a youtube review where he says he uses Gaia https://www.youtube.com/watch?v=SBSUbQyoQpE&t=95s You do have to download a map of the region. The Joying HU has it's own GPS antenna and doesn't require a cell connection so long as your GPS app supports offline maps.
  18. Jan 14, 2022 at 3:05 PM
    #498
    scootter82
    Aurora, CO
    With that launcher, were you able to set the phone? When I try, I can't find the phone app
  19. Jan 14, 2022 at 3:13 PM
    #499
    fizik
    Minnesota
    The phone app is called "Bluetooth" it allows you to set up bluetooth connections and has the phone dialer.
    Does anyone know if there is a way to control the volume of the phone ring? On my unit it sounds like it is playing at max volume. Almost made me drive off the road the first time someone called me.
  20. Jan 14, 2022 at 3:21 PM
    #500
    scootter82
    Aurora, CO
    Omg this! Phone rings are so loud no matter what my volume is set to
