2nd Gen LCA bolts
Discussion in 'Suspension' started by raycie, Jul 15, 2013.
  1. Jul 15, 2013 at 6:29 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Anyone know the torque specs for the 2 bolts that attach the LCA to the steering?
    Thanks!
  2. Jul 16, 2013 at 12:04 AM
    raycie
    Oahu, HI
    In need of $$$
    Gotta bump..
    Are the 2 bolts from the LCA that need to be removed..
    Lower control arm to swaybar end link: 51 ft-lbs...
    OR
    Lower ball joint to lower control arm: 112 ft-lbs...
    OR
    Some other bolts to different specs?
    Thanks.
  3. Jul 16, 2013 at 12:16 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Sounds like you're talking about the bolts that hold the LBJ on the spindle to the LCA, in which case it would be the 112lb/ft you came up with.
    A quick picture would help to be sure.
  4. Jul 16, 2013 at 12:23 AM
    raycie
    Oahu, HI
    In need of $$$
    Thanks in advance..
  5. Jul 16, 2013 at 12:28 AM
    RelentlessFab
    Eric
    Sparks, NV
    Those are LBJ to spindle/knuckle then
  6. Jul 16, 2013 at 12:32 AM
    RelentlessFab
    Eric
    Sparks, NV
  7. Jul 16, 2013 at 12:36 AM
    raycie
    Oahu, HI
    In need of $$$
    Thanks brother... Now I can do it with a lot more piece of mind!!!
  8. Jun 26, 2018 at 8:19 PM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    Bringing this back from the dead.... Who knows what size these bolts are? Ive searched for 30 Mins and can't find it.
  9. Jun 26, 2018 at 9:47 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    19mm
  10. Jun 27, 2018 at 5:01 AM
    Taylorbarton1
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    19x1.5? Thanks brother
