2nd gen LED roof light mount
Discussion in 'Lighting' started by Bobber Bill, May 26, 2012.
  1. May 26, 2012 at 12:34 PM
    Bobber Bill
    Bobber Bill [OP] Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    * SOLD OUT
    * NO LONGER AVAILABLE
    These bolt-on racks can hold any size LED bar, up to 47.5".
    2 of my custom tabs are included with every rack. They are meant to hold an LED bar at the best position in front of the rack, but can be positioned at any angle. You are responsible for getting the tabs positioned and welded in place.
    You are not limited to huge LED bars with this, you can mount anything that has provisions for tube. Tabs can be made for just about anything!
    100% bolt-on and reversible install other than a little trimming of your rubber rain channel strips, if you decide to run them. No drilling or other permanent alterations required (2005+ Double Cab models only)!
    Can also be adapted to Regular and Access cabs (require drilling).
    All shapes are CNC water-jetted. Side plates are 3/16" plate, light tabs are 1/8" plate and bar is .90 wall 1.00"
    tube. All sets include Zinc coated Class 12.9 hardware (min. Rockwell hardness of C37 & tensile strength of 174,000 psi) and 2 mounting tabs.
    Anthony250f tested and approved :thumbsup:
  2. May 26, 2012 at 12:36 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
  3. May 26, 2012 at 12:50 PM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Want.
    Subbed.
  4. May 26, 2012 at 12:57 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    sweet!!!!!
  5. May 26, 2012 at 1:00 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Looks awesome Will I wanted something like that as well.
  6. May 26, 2012 at 3:25 PM
    SamoTaco
    SamoTaco Active Member
    Santa Monica, CA
    08 4x4 access cab
    I would love to buy these if you're selling them!
  7. May 26, 2012 at 3:26 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    That's real nice
  8. May 26, 2012 at 5:26 PM
    Bobber Bill
    Los Angeles, CA
    Thanks guys. These mounts will be 100% bolt-on for 2nd gen double cabs. Access and single cabs will require drilling and installation of rivet nuts in the drip channels.
    Also, this mount system is one-off and made specifically for this light bar. The universal system will have a 1" OD tube going across. Mounting tabs will be welded to the tube to suit your light(s).
  9. May 26, 2012 at 6:05 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    How much. Thinking of buying a 40" bar.
  10. May 26, 2012 at 6:11 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Finally! :cool:
    The fact that know one has really made these in production yet amazes me, I'm excited!
  11. May 26, 2012 at 6:30 PM
    Bobber Bill
    Los Angeles, CA
    Probably $150
    3/16" thick. Fitted for each specific application.
    There are so many different LED light bars out there that I'll have to fit each one in person or according to measurements. I think $150 for a custom fit roof light mounting system is more than fair. Try getting your local fab shop to make you a one off for the price!
  12. May 26, 2012 at 6:35 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    I'm interested to see what the 1" bar looks like... I really like the clean look of just the brackets thats in the pictures.
  13. May 26, 2012 at 9:43 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Will...looks amazing. Didnt expect anything less from ya. Can't wait to get my bar now. Someone buy my 20" and 10" from me so i can buy a 42". Good luck with this product Will!
  14. May 26, 2012 at 9:47 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  15. May 26, 2012 at 9:48 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    That pretty dope man!! :thumbsup:
  16. May 26, 2012 at 9:53 PM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    That is def nice. How much does the light bar cost at 45"? That can't be cheap
  17. May 26, 2012 at 9:59 PM
    anthony250f
    Anthony
    San Diego, CA
  18. May 26, 2012 at 10:01 PM
    toughtaco
    ^^Thanks, that is not that bad of a price!!!!!
  19. May 26, 2012 at 10:14 PM
    toughtaco
    X1000000000000
  20. May 26, 2012 at 10:37 PM
    mogace
    mogace Well-Known Member
    Southaven MS
    I'm down, sub'd
