2nd Gen Lift Kit suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evantid6, Jun 16, 2019.
  1. Jun 16, 2019 at 6:33 AM
    evantid6
    evantid6 [OP] Member
    Evan
    Baton Rouge, Louisiana
    2015 White Tacoma
    raptor grill, 20” wheels, 6” RC lift, 34.5” gladiator x comp tires, flush mounted grill light bar and hood ditch lights, iPad in dash
    Looking for recommendations for lift kit for my 2nd Gen (2015) Tacoma. Size and brand. I drive a lot so want a good ride. Looking to fit 33” tires. 34” max. 285/60/20 or 285/65/20. Truck is just leveled atm still with stock tire size.
  2. Jun 16, 2019 at 6:40 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    To run the 285/65/20 you gonna need to run a 6” kit, for the 285/60/20 you’ll need a 4” kit.
    evantid6[OP] likes this.
  3. Jun 16, 2019 at 6:44 AM
    gotoman1969
    I have 2015. Running Toytec 3” coilovers, Jba hi caster uca’s , 2” in the rear, 285/70/17(32.7”) on 17x8.5 -10 offset wheels. Rides great!! No rubbing issues.
  4. Jun 16, 2019 at 6:58 AM
    Ren
    Ren Well-Known Member
    Denton, TX
    White 2012 Pre-Runner DCSB
    20" rims might keep you from getting the good ride you want. Of course, I've never had 20s so I can't speak from experience. But in general, more rim = less tire sidewall = harsher ride.
  5. Jun 16, 2019 at 7:18 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    You don't need 20s. Go with a 3" lift running Kings, FOXs, ADS, Icon or something else. I am running 285x70x17 on 17x8.5 with Kings. It's like driving on a cloud. Good luck and welcome to TW.
  6. Jun 16, 2019 at 7:21 AM
    evantid6
    Evan
    2015 White Tacoma
    I already have 20” rims. That’s why I’m staying with it
  7. Jun 16, 2019 at 7:42 AM
    Mully
    CA
    Good luck with that smooth ride your looking for.
  8. Jun 16, 2019 at 7:47 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Depends on your price range. My first lift/ suspension setup was a 3 inch lift with the Toytec coil spacer and a rear AAL. This setup was only around $300 online. I now run my new setup which gives me about 3.5 inches give or take with bilstein 5100s all around, eibach Toytec coils, and regular OME Dakar leaf springs. This costed me around $1000ish if I remember right, but it does ride a lot better and performs better offroad. If you’re gonna be a pavement princess then go with the cheap lift, but if you do plan on doing light off-roading, I would take my path. Also I would use the forum search tool in the top right of your screen. Tons of good info if ya look for a sec. And welcome to TW!
  9. Jun 16, 2019 at 7:55 AM
    gotoman1969
    If you not planning on running more than 3” of lift you will have to go to a 285/55/20 approx 32.4” diameter.
