2nd gen lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jso223, Dec 15, 2015.
  1. Dec 15, 2015 at 2:39 AM
    jso223
    jso223 [OP] Active Member
    I was looking to lift my truck because I'm getting ready to buy some new tires. I was looking at the Toytec 3 inch lifts one was with new coils and and a top plate spacer with the aal in the back. The other one was with bilstein 5100 and new coils and a aal in the back. Which one would be a better lift my truck has 95000 miles on it and I want to use the factory rims. It is a TRD Sport.
  2. Dec 15, 2015 at 2:41 AM
    jso223
    I also don't know which tire size to go with I don't want to be cutting into truck. Would 265 70 17 look good with a 3 inch lift?
  3. Dec 15, 2015 at 8:58 AM
    Pigpen
    Dan
    Northwest Montana
    That's the tire size you want.
    Any lift from the springs will be better than spacers. Search the lift threads for more info.
  4. Dec 15, 2015 at 10:32 AM
    jso223
    Will the 265's still look good with the lift?
  5. Dec 15, 2015 at 10:33 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Adding a AAL to a leaf pack with 95k on it might not be the best idea..
  6. Dec 15, 2015 at 10:35 AM
    jso223
    So you think I should get a new leaf pack? I think think my truck has sagged some I can tell when it is next to a newer Tacoma.
    HolyHandGrenade likes this.
  7. Dec 15, 2015 at 10:36 AM
    geekhouse23
    AAL will only be a band-aid..might as well get a new pack now. It will be better.
  8. Dec 15, 2015 at 10:41 AM
    jso223
    How much does a new leaf pack run?
  9. Dec 15, 2015 at 10:45 AM
    geekhouse23
  10. Dec 15, 2015 at 10:51 AM
    jso223
    Ok I will check it out.
  11. Dec 15, 2015 at 11:21 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    It's going to be 'sticker shock' compared to the cheap AAL.
    However, if you AAL to your current pack, I can guarantee you that you'll be sagging soon, and it'll be pronounced b/c your nose will be up higher. You'll end up just having to replace the packs pretty soon anyways. Recommend just doing it now.
    Let us know what you end up doing!
  12. Dec 15, 2015 at 12:35 PM
    jso223
    Do the leaf packs usually give out like that? The only thing I have had to do to mine as put new tabs in because they were squeaky.
  13. Dec 15, 2015 at 12:36 PM
    geekhouse23
    my brand new leaf packs with 5k on them lasted 3k with a single AAL in them..they're garbage
  14. Dec 15, 2015 at 3:19 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I've tried aal's on several trucks over the years. To be perfectly honest, I'd MUCH rather use blocks than aal's....Aal's kill leaf springs eventually. .A well designed leaf pack is the BEST option. A good friend of mine owns a shop where they custom build leaf springs for a company that fits aftermarket truck beds for new trucks coming off the assembly line (@ Louisville "Super Duty" plant) He's building me a complete set of rear springs that'll me going on my truck shortly after the 1st of the year. Especially if you plan on hauling anything in your Tacoma, better rear springs are a MUST.
    geekhouse23 likes this.
  15. Dec 15, 2015 at 9:13 PM
    jso223
    Will the icon progressive 3 leaf work good?
  16. Dec 16, 2015 at 3:06 AM
    geekhouse23
    Anything you add to the stock leaf pack will be a bandaid. They might be a longer lasting bandaid over the single AAL, but your best bet is to replace the leaf pack completely
  17. Dec 16, 2015 at 4:11 AM
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    ^^^^THIS^^^^
  18. Dec 16, 2015 at 10:08 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  19. Dec 17, 2015 at 7:04 AM
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    I run dakar leaf pack with icons all around, and I must say it rides pretty nice.
