2nd gen maintenance required light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4Runner, Oct 27, 2006.
  1. Mar 31, 2010 at 2:39 AM
    #61
    KRS1
    KRS1 Active Member
    Windham, ME
    07 Tacoma 4X4
    6" Pro Comp Susp. Lift 3" Body Lift 35 x 12.50 Cooper Tires CAI (home made) Doug Thorley Long Tubes Flowmaster (44 series) mufflers 150'x3/8 Blue Steel syn. wire rope Wet Okole neo. seat covers
    worked perfectly.... thanks...... so i got another light that is always on... the tire pressure light... since i put bigger tires on the truck i cant get that damn light to turn off... anyone know a little trick to clear that code... ????
  2. Mar 31, 2010 at 3:43 AM
    #62
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Thanks! Just did a oil change and didn't have time to look up in the manual to reset the warning light.
  3. Mar 31, 2010 at 9:06 AM
    #63
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you're original sensors aren't in your new tires, then that's the problem. Otherwise, the '07 has a sensor in the spare too. Check your spare. When everything's correct, the light will turn off on its own.
  4. Apr 7, 2010 at 5:16 PM
    #64
    jorgeocordero
    jorgeocordero Member
    07 Pre Runner TRD
    2nd, air filter removed,in cabin 110/ 400w mod.inverter.fog light any time mod.
    good , my warranty its, almost close to end and i do go to the dealer for the great "light" to be off and oil change. Thanks!!!
  5. Apr 27, 2010 at 7:09 PM
    #65
    christopherjayj
    christopherjayj New Member
    CT
    05 Tacoma TRD Off Road
    Does anyone know if the maintenace light can be programed to come on at 3000 miles? I worked for a Chrysler/Dodge/Jeep Dealer and we could change the service interval based on the owners needs. I'd like to change mine but the Toyota dealers in the area can never give me a straight ansewer.
  6. Apr 27, 2010 at 8:35 PM
    #66
    Desert Car Guy
    Desert Car Guy Member
    Palm Desert, CA
    06 Tacoma Pre Run TRD
    Thanks for the info. I could not find it in my owner manual where you said or anywhere else..F.K.
  7. Apr 28, 2010 at 8:58 AM
    #67
    05Moose
    Jim
    Yes. When you hold down the trip meter and go through the process, you'll see the number of dashes change. Each dash represents 1K miles. Release the trip meter when you reach the choice you want (3 dashes in your case).
  8. Apr 28, 2010 at 1:37 PM
    #68
    christopherjayj
    CT
    Thanks 05Moose. I'll try it when I get home.
  9. May 7, 2010 at 3:33 PM
    #69
    LarryRAguilar
    LarryRAguilar Member
    Larrry
    Yorba Linda, CA
    Toyota Tacoma TRD
    Awesome! Darn light has been driving me crazy! Any tips on the Air Pressure light?
  10. May 7, 2010 at 4:36 PM
    #70
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    Thanks, just used this. Rep for you sir.
  11. May 9, 2010 at 11:03 AM
    #71
    old dad
    old dad Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    great, this info is the main reason I looked up and found this forum, you guys are great.
    mark
  12. Jun 15, 2010 at 3:24 PM
    #72
    mattsowell
    mattsowell Ridiculously lazy member
    kamloops, bc
    2010 Tacoma TRD DC SB sport debadged
    no seatbelt chime, stubby antenna, 5100's front and back with AAL, offset rims with Dura-Trac rubber, weathertec mats, Image Dynamic sub with 5 channel Amp and Kenwood Deck with steering wheel control, PIA bulbs, K&N air filter, ARB Delux front bumper
    thanks meng! always something useful on this site
  13. Jun 25, 2010 at 6:59 AM
    #73
    Acill
    Acill Well-Known Member
    Paul
    Port Hueneme, Ca.
    2017 TRD Offroad
    I must have turned right past this in the manual. Mine jsut started doing this and it was driving me nuts. Shouldnt it reset on its own after an oil change? I guess i am due though when I think about it. Time to go get some mobile-1
  14. Jun 25, 2010 at 7:01 AM
    #74
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No- The truck doesn't know when you ACTUALLY changed the oil....It just knows that you need to by the time you roll 5K since the last reset.
    You can keep driving past the interval and reset the light if you wanted too....No oil change required.
  15. Jul 21, 2010 at 2:54 PM
    #75
    FFjDs
    FFjDs Member
    Josh
    South Florida
    05 PreRunner SR5 4dr
    Thanks alot for the tutorial on reset. Just did my 1st oil change and didnt know why the light was on.. Worked great! Thanks again
  16. Aug 15, 2010 at 3:35 PM
    #76
    seanmichaels
    seanmichaels Member
    Florida
    03 Tacoma TRD V6
    I changed oil back in April and used synthetic on my Tacoma TRD. Recently I put super unleaded into my engine. I noticed a difference in the power of the engine. I have only used super unleaded a few times recently then went back to regular unleaded. Could that have triggered my check engine light? I have about 50k on the Tacoma and my bro told me they set the light to come on as a maintenance reminder.
  17. Aug 15, 2010 at 4:05 PM
    #77
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the CEL and maint required lights are completely different. maint light is for oil changes and the CEL light is for when something is wrong and you actually need to check your engine. go to a local auto store and have them run the code to see what is wrong
  18. Aug 16, 2010 at 8:57 AM
    #78
    LarryRAguilar
    Larrry
    Yorba Linda, CA
    Toyota Tacoma TRD
    I notice a huge difference when I use regular-unleaded compared to super-unleaded. When I use regular, me truck engine knocks or pings, I lose gas mileage and power; is this all in my head, or does anyone else notice the same performance differences?
    Thanks!
  19. Aug 16, 2010 at 11:24 AM
    #79
    seanmichaels
    seanmichaels Member
    Florida
    03 Tacoma TRD V6
    Thanks! I went to Auto zone and they said it was o2 sensor. They tried selling me one but I did not buy it. I thought I already had that replaced a while back.
  20. Sep 22, 2010 at 9:29 AM
    #80
    Covington
    Covington Active Member
    Central Florida
    08 PreRunner V6
    Thanks BlueT!
