2nd gen maintenance required light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4Runner, Oct 27, 2006.
  1. Aug 4, 2014 at 12:34 PM
    #141
    CaliAsh
    CaliAsh Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
    Trip A worked for a 2012 Tacoma. You get a nice little bar countdown for holding the button as well :)
  2. Aug 11, 2014 at 9:34 PM
    #142
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Trip A worked for my 2014. Great info.
  3. Sep 22, 2014 at 3:06 PM
    #143
    cooldeng
    cooldeng Member
    Deng
    Ca
    17 Tacoma
    Great info
  4. Sep 23, 2014 at 5:49 PM
    #144
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    Yeah, I never knew till I saw it here, and it worked on my 2012
  5. Sep 25, 2014 at 7:40 AM
    #145
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Done a couple of oil changes on 2011 and I have never seen the light come on. 6000 miles now.
  6. Oct 23, 2014 at 4:02 PM
    #146
    Up4Tacos
    Up4Tacos Sunset - sit - sip - chill
    Dutch
    Dockside, Gulf Coast
    2015 Trd Offroad PM
    Ultraguage, 265/75/16, Leds interior. Tailgate security mod.Debadged, plasti dipped emblems.
    Trip A worked for our 2013. Thanks for the info.
  7. Nov 9, 2014 at 7:37 PM
    #147
    rotormotored
    rotormotored New Member
    Ed
    Coachella Valley, Ca.
    2006 Toyota Tacoma, 2-TR 2.7L
    Hi Everyone,
    I'm a newbee on this forum. I have a maint. required light that will NOT go out.
    I have a code scanner and it gives me a P0031. That means Oxygen sensor heater control circuit, Low Voltage (Bank 1, Sensor 1).
    I have changed both O2 sensors
    I have confirmed that the A/F Heater relay works
    The OBD fuse is good
    I went to my local Toyota dealership and talked them into printing a schematic for me and I was able to check continuity of the wires for sensor 1 (Air/Fuel Ratio Sensor ) … Wires are intact.
    I clear the code and it just comes back on after a few seconds.
    If anyone out there has ever experienced this and have a solution, PLEASE, BY ALL MEANS, let me in on it. Please can anyone help???:confused:
    Ed
  8. Nov 9, 2014 at 8:45 PM
    #148
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You're saying clearing this code makes the "Maint Req'd", as in it specifically says those words, light go out? Are you sure it's not the check engine light, an actual picture of an engine. the CEL light comes on when there are diagnostic trouble codes.
  9. Jan 20, 2015 at 8:34 AM
    #149
    00PowderSpecial
    00PowderSpecial Well-Known Member
    Chad
    Newfoundland, Canada
    09 TRD DC
    Did the 09's have the light? I've never seen it come on, and I change my oil every 10,000 kms with mobile 1 synthetic.
  10. Jan 20, 2015 at 8:39 AM
    #150
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    05+
  11. Jan 20, 2015 at 8:56 AM
    #151
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Only the American market trucks have the MAINT REQ idiot light , the Canadian trucks do not
  12. Jan 20, 2015 at 8:59 AM
    #152
    The_Hodge
    SC
    dumb americans...
  13. Jan 20, 2015 at 9:02 AM
    #153
    OZ-T
    Peter North
    British Columbia
    Just stating fact , read into it what you will ma'am
    If I had to guess , at some point somebody down there probably sued a vehicle manufacturer for them not knowing that they had to change their oil
  14. Jan 20, 2015 at 9:03 AM
    #154
    The_Hodge
    SC
    probably while they spilled coffee on their lap they didn't know was hot.
    same goes for the TPMS.
  15. Jan 20, 2015 at 9:39 AM
    #155
    Sandman614
    Tim
    '06 SR5 Off Road
    Shit, I knew coffee was hot but I have to change my air and put oil in my tires? Toyota sucks and I'm moving on to Doges.
  16. Feb 19, 2015 at 4:35 PM
    #156
    flyb75
    flyb75 New Member
    Tried this task, did not work for me on my 2007
    This is directly from the owners manual Section 1-6 "Operation of the Instruments and Controls" under "Service reminder indicators and warning buzzers" Subsection G "Engine Oil Replacement Reminder Light" page 150
    Clearing the "Maint Reqd" light on 2005 and up Tacoma's
    This light acts as a reminder to replace the engine oil.
    This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
    When you drive for about 7200 km (4500 miles) after the engine oil replacement this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to the "ON" position. The light will remain on thereafter.
    If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. IF the light comes on, replace it as soon as possible.
    The system must be reset after the engine oil replacement. Reset the system by the following procedure:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown (For details, see "Odometer and two trip meters" on page 143 in this Section.) (Note 2: 2011 + models may require using the TRIP A reading)
    2. Turn the ignition key to the "ON" position while holding down the trip meter knob.
    Hold the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off.
    If the system fails to reset, the light will continue flashing[/QUOTE]
  17. Mar 21, 2015 at 12:08 PM
    #157
    Racemedic
    Racemedic New Member
    Bubba
    Atlanta, GA
    '13 Prerunner Sport
    Just FYI, you DO have to use 'Trip A' to reset a 2013 model.
  18. Jun 16, 2015 at 10:43 PM
    #158
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    So this happened to me when I was around 4500 miles and I reset the light but now I'm at 14,500 miles and I see the flashing light again. Should I be concerned? I did get an oil change not to long ago, but this never happened on the last oil change I had received.
  19. Jun 16, 2015 at 10:48 PM
    #159
    Alfred
    Alfred
    California
    I get my oil change done at valvoline so you sit in the car while they do their thing. I'm just confused because it didn't come on the oil change prior. And the last time the maint reqd light came on was at 4500 miles and now it's back on at 14500 miles. That's a 10,000 mile difference I would have figured it would come on every 5k miles.
  20. Jun 17, 2015 at 7:14 AM
    #160
    spp
    spp OC, Kalifornia
    OC California
    Nope. It's the ODO on a Tacoma.
    My Rav-4 trip A is used.
