2nd gen maintenance required light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4Runner, Oct 27, 2006.
  1. Jun 17, 2015 at 9:09 AM
    #161
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Nope. Its the trip A on my 2012, just had to do it Sunday.
  2. Jun 17, 2015 at 5:17 PM
    #162
    spp
    spp OC, Kalifornia
    OC California
    Yep you are correct and I'm wrong. Just re-read the manual and my old eyes missed the change. My 3rd Gen 2 so I just skimmed it the first time through. Sorry Racemedic.
  3. Mar 8, 2016 at 4:30 AM
    #163
    Rattlejay65
    Rattlejay65 Well-Known Member
    J.R.
    2015 Tacoma TRD Off Road
    This is good information to have. Thanks. I had a 2010 RAV4 with the smart key and it took me forever to find out how to reset that maintenance light. With the smart keys, you have to have your foot on the brake for it to crank when you press the start button. Took me forever to find out how to get the "ignition" to come on without cranking, just keep the foot off the brake when you press the start button, lol. It was that simple. I cannot for the life of me remember if resetting the maintenance light was detailed in the owner's manual on my RAV4, but it is in my owner's manual for my 2015 Tacoma, on page 365. I'll see if I can get the photo to upload. image.jpg
  4. Jul 16, 2016 at 10:32 AM
    #164
    Ronniebuilt
    Ronniebuilt Ronniebuilt
    Ron
    West Virginia
    2014 Black Tacoma TRD Sport
    Fox2.0 front and rear. Timbren bump stops, Timbren U-bolt flip kit, Low Range 7/8" rear block,275/70 x17 Kuhmo AT51 tires on Charcoal FJ 8 hole wheels, vent-visors , Alum. skid plates, Total chaos bed stiffeners, n-fab led lightbar bumper, 30" LED light, rollup tonneau cover, bed mat, weather tech floor mats, aftermarket trd emblems.
    Thanks for the information.
    Had no idea how to get the light reset.
    Hopefully someday I'll be able to share some wisdom.
  5. Sep 5, 2016 at 8:52 PM
    #165
    GrantMrunner
    GrantMrunner Member
    Rocky Mountains
    2011 TRD OR quad cab
    mostly stock
    (Note 2: 2011 + models require using the TRIP A reading)
    I figured this out the hard way last night. My 2011 Owner's Manual says put it on "Odometer". Editing error. Should have looked here first.
    TRDSport10 likes this.
  6. Sep 5, 2016 at 11:18 PM
    #166
    Windstrings
    Windstrings Member
    2016 Toyota Tacoma 4x4 limited
    3/2 lift, oversized Copper tires
    *2016 Toyota Tacoma Reset maintenance Data = turn to accessory mode, (power on without foot on brake) then hold down trip Odometer needle and turn on car "without" foot on brake again. Will still be in accessory mode but should reset.
  7. Oct 16, 2016 at 1:06 PM
    #167
    mcmurray
    mcmurray New Member
    Art
    2017 Barcelona Red Tacoma TRD
    Thank you for posting the tip Mod.
    I take it you are suggesting I start using synthetic oil starting with my first oil change? Also, this is probably a dodo question but since this is a brand new truck with only 30 miles (Tacoma Access Cab w/V6 Auto Trans) on it and the one I had for over 20 years was an '89 Toyota 4x4 Hi-Lux, standard with a 22RE engine; I haven't looked yet to see if it has any grease nipples. Has it or are grease nipples a thing of the past with most vehicles??
    Thank you.
  8. Oct 16, 2016 at 1:36 PM
    #168
    Windstrings
    Windstrings Member
    Be sure you don't have free oil changes through your dealer... But yes, full synthetic only
  9. Oct 21, 2016 at 10:30 PM
    #169
    tacomonkey
    tacomonkey Well-Known Member
    I just had my 3rd Toyota care maintenence done about a month ago. The Maintenence light didn't come on until today. Is this normal? Does this mean the dealer didn't reset the system after doing the oil change?
  10. Nov 27, 2016 at 9:14 AM
    #170
    beachbunny
    beachbunny Active Member
    worked well on a 2010.make sure you hold the odo button down before turning on, turn on,watch the bars count down to all the zeros and gtg!
    thanks
  11. Dec 1, 2016 at 7:05 AM
    #171
    Oddeo'coma
    Oddeo'coma Well-Known Member
    Eric
    Central CT
    2012 Barc' Red DCLB Tacoma
    Just finished taking care of the major 60K maintenance items (plugs, filters, brake pads, engine & tranny fluids- I used fully synthetic MAG 1 products) on my "new to me" 2012 , so this tip was quite useful. Fast and easy, worked like a charm. Hearty thanks to the OP!
  12. Mar 21, 2017 at 6:56 AM
    #172
    RainRoad
    RainRoad New Member
    Pete
    Maryville, TN
    2010 Tacoma Double Cab 4X4 - Silver, 2002 BMW R1150RT motorcycle, 1959 MGA with MGB running gear.
    K&N air filter system, muffler change to straight through type (Too loud for my taste, will soon go back to stock style muffler). A/T style BF Goodrich tires.
  13. Mar 22, 2017 at 11:55 AM
    #173
    Rabicano
    Rabicano Member
    Napa, CA
    2007 TRD OR, DCSB
    Quick and easy. Thanks!
  14. Apr 7, 2017 at 3:00 PM
    #174
    47driver
    47driver Well-Known Member
    Brandon, MS
    Worked great on my 2012 thanks.
  15. Jun 11, 2017 at 9:16 PM
    #175
    ComaOrBust
    ComaOrBust Go Wings
    Thomas
    Louisville,Ky.
    06 TacomaEC 4x4
    3"/2" body lift, 17" icon wheels, nitro ridge grapplers
    What if the procedure doesn't make the light stop flashing? Also, my check engine light is on. Any ideas as to why?
  16. Jun 12, 2017 at 5:06 AM
    #176
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Go get your codes read. I doubt they're related.
  17. Feb 24, 2018 at 8:22 PM
    #177
    BowlingAddict
    BowlingAddict Member
    2013 Tacoma TRD
    Hello All!
    Just wondering if I should be worried that my maintenance required light is on. It flashes about 4 or 5 times when I start my truck and shuts off. I changed my oil around 73,000 miles, currently at 77,350. Maybe change oil? or maybe something else? Any input would be greatly appreciated.
  18. Feb 24, 2018 at 8:23 PM
    #178
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s a simple reminder light that comes on after a set period of miles, nothing to worry about. The procedure to reset it is in your manual.
  19. Feb 24, 2018 at 8:24 PM
    #179
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    It flashes about 500 miles before service is due. When service is due it comes on solid.
    Slashaar likes this.
  20. Feb 24, 2018 at 8:27 PM
    #180
    BowlingAddict
    2013 Tacoma TRD
    Thank you gents!
