2nd gen manual tacoma squeaking (not TOB)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zoocoma, Nov 22, 2020.
  1. Nov 22, 2020 at 10:34 AM
    Zoocoma
    Zoocoma [OP] Active Member
    PNW
    Fodofomohoes
    Whats up folks? Hope all is good during these funky times. Was hoping to get some insight on this little problem. I'm wondering if anyone had and fixed or is still battling the following issue: I had the throw out bearing chirp when I first bought the truck, replaced with a stock bearing but after it came back after 3k miles of normal driving, I swapped it with the clutch masters hydro bearing. All was good for a good while but recently I got a very similar chirp going. It only happens while moving in gear, at low speeds (10-45 mph), with the clutch engaged. Theres no sound at idle with clutch engaged which is why I ruled out the TOB. What do yall think?? All thoughts and advice are appreciated
  2. May 14, 2022 at 11:30 AM
    ruggednerd
    ruggednerd New Member
    2006 White Tacoma TRD
    Did you ever figure this out? I have the same issue.
