2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. May 23, 2020 at 10:58 AM
    #601
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
  2. May 23, 2020 at 11:07 AM
    #602
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Super cheap insurance for a critical part of your truck.
    Norton likes this.
  3. May 23, 2020 at 11:11 AM
    #603
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Definitely less money than the OE bolts. I should’ve gotten those. I bought 16 of those damned things during this whole debacle.
  4. May 23, 2020 at 1:46 PM
    #604
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That they are!
    One more time? :D
  5. May 23, 2020 at 1:51 PM
    #605
    BillDaCat8
    Jake
    PHX
    NO!
    Although, I bet I could do it pretty dang quickly now.
  6. May 23, 2020 at 5:28 PM
    #606
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I bet you had dreams of that task, after the fact. Nightmares even....Then, "Phew, only a dream."
    BillDaCat8 likes this.
  7. May 24, 2020 at 11:46 AM
    #607
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    You can definitely get the Toyota bolts for less than the ARP's online. That said, if you need to buy them twice, it's cheaper to get the ARP's, haha.
    Jeff
  8. May 29, 2020 at 1:32 PM
    #608
    Bradahboy808
    Bradahboy808 Member
    Koby
    Kauai as why
    2006 tacoma access cab 6speed
    3 in level kit, procomp wheels and all terrains (265/75/17)
    Anybody know of a discount code for clutch masters website? Looking to buy the throw out bearing
  9. Jun 10, 2020 at 8:04 PM
    #609
    SparkyIX
    SparkyIX Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    Anybody have any bearing noise after driving for a bit? Its been about 500miles since install and now I have noise in neutral
  10. Jun 11, 2020 at 8:46 AM
    #610
    Canadian_Shooter
    Canadian_Shooter Member
    Sol
    Alberta
    2014 DCSB 6spd
    Are you running the original pressure plate still?
  11. Jun 11, 2020 at 10:24 AM
    #611
    Bubbarut
    Bubbarut Well-Known Member
    2011 Super White Access Cab V6 4x4 6SPD Manual
    I had a little noise not long after install. It went away after a few days and hasnt been back. Not sure of how many miles I have put on it but its been at least 4,000 if not 5
  12. Jun 11, 2020 at 11:04 AM
    #612
    SparkyIX
    Anthony
    Tonopah, AZ
    I recently replaced my clutch master. Is it possible that I adjusted the pedal wrong so that when I press it, the bearing gets too much pressure and contacts the pressure plate? Sometimes when I shift it feels like grinding but not gears
  13. Jun 12, 2020 at 11:30 PM
    #613
    SparkyIX
    Anthony
    Tonopah, AZ
    When I installed the bearing I installed a new oem clutch / pressure plate and flywheel
  14. Jun 13, 2020 at 9:05 AM
    #614
    SparkyIX
    Anthony
    Tonopah, AZ
    Anybody in SoCal wanna help me figure out this damn hydro bearing noise.
  15. Jun 13, 2020 at 11:27 AM
    #615
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    did you recently post on a FB group on this?
    SparkyIX[QUOTED] likes this.
  16. Jun 13, 2020 at 1:32 PM
    #616
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    You try bleeding it some more? Might be having some trouble disengaging due to an air bubble.
  17. Jun 13, 2020 at 2:36 PM
    #617
    SparkyIX
    Anthony
    Tonopah, AZ
    Yup. M/T Tacoma’s I believe
  18. Jun 13, 2020 at 2:36 PM
    #618
    SparkyIX
    Anthony
    Tonopah, AZ
    It’s weird. It was running great, then about the time I swapped my clutch master cylinder out it started this.
  19. Jun 14, 2020 at 7:04 PM
    #619
    Canadian_Shooter
    Sol
    Alberta
    2014 DCSB 6spd
    Anyone else noticing their clutch pedal getting quite stiff after about a hour of driving? Have about 1000 miles since install. Brake fluid getting too hot??
  20. Jun 14, 2020 at 7:18 PM
    #620
    TacoTuesday1
    SD CA
    me: damn this whole squeak situation sucks
    TW: but wait, there's a fix!
    me: dang that's expensive. Fine. If it works, it works. I'm in. Sign me up for the Group Buy.
    TW: AcTuAlLy, *10 people report varying issues*
    me: FUCK
    ____________________________
    So brake fluid in calipers is air-cooled, and brakes are seldom driven hard enough to boil it. Especially when it's fresh and not contaminated with water.
    But a clutch system is different because it's hidden up close behind the engine, probably absorbing heat from the engine itself operating, and the exhaust being near the cats. With little airflow to cool it.
    And regular operation of the clutch during shifts with normal driving, probably has some heat too.
    So maybe it does have heat. I don't know if enough to boil it though, and if a laser/infrared thermometer can tell.
    Some performance brake fluids claim to offer higher boiling point but they usually cost way more per small container.
    lo2hi and BillDaCat8 like this.
