2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. Jun 14, 2020 at 7:33 PM
    #621
    Canadian_Shooter
    Canadian_Shooter Member
    Sol
    Alberta
    2014 DCSB 6spd
    If that is the case it can't just be me experiencing it.
    BillDaCat8 likes this.
  2. Jun 14, 2020 at 8:45 PM
    #622
    SparkyIX
    SparkyIX Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    Yup. That’s about how it went.
  3. Jun 15, 2020 at 6:34 AM
    #623
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Completely unrelated TOB on my truck. First start of the morning, and it was super light pressure to press it to the floor. Nearly no effort. After some time driving, it would become extremely stiff, requiring a LOT of leg effort and pressure. Changed line sizes, used heat shielding on the lines near the engine. Nothing corrected it. I called engineering at Tilton, and they had never heard of it. A strange anomaly.
    Glad-ish to see someone else having come across this issue. Even it is it on a different TOB. The physics are still doing something similar.
    BillDaCat8 and TodayWasTHeDaY like this.
  4. Jun 15, 2020 at 7:24 AM
    #624
    Canadian_Shooter
    Sol
    Alberta
    2014 DCSB 6spd
    Ya sounds to be the same issue. If it's not a fluid issue was thinking possibly aluminium parts expanding? Just throwing that out there.
  5. Jun 15, 2020 at 9:19 AM
    #625
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    maybe a master cylinder issue. maybe starting to bind as it warms up or from use? seems like to good place to start if everything else in new.
  6. Jun 15, 2020 at 9:25 AM
    #626
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Replace that as well.
    Again. For mine, I have a T56 transmission. Different TOB, but same issue.
    When I swapped from the Titlon to the GM TOB. Then it was even and smooth.
    The question is what are the differences.
    rheath08[QUOTED] likes this.
  7. Jun 15, 2020 at 9:34 AM
    #627
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    ugh, a month ago I was sold on this mod, now Im not so sure, there have been a fair amount of complaints of this 'fix'
    dnl_tacoma likes this.
  8. Jun 15, 2020 at 9:35 AM
    #628
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't change you mind yet. There have to be other people's input.
  9. Jun 15, 2020 at 10:02 AM
    #629
    rheath08
    Russell
    Bakersfield, CA
    i have had mine for 2k miles or so. i have no issues. @Camby if you were closer i would let you take it for a test drive.
  10. Jun 15, 2020 at 10:04 AM
    #630
    rheath08
    Russell
    Bakersfield, CA
    @Torspd how do you like that t56? is that in a different truck than the 4x4 on your insignia?
  11. Jun 15, 2020 at 10:05 AM
    #631
    Camby
    Brian
    Denver
    :) Im in the Los Angelas area for the next couple weeks....
  12. Jun 15, 2020 at 10:07 AM
    #632
    rheath08
    Russell
    Bakersfield, CA
    this weekend and part of next week ill be gone on vacation. but if your able to make it this way after that the offer still stands.
  13. Jun 15, 2020 at 10:16 AM
    #633
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In the insignia truck.
    It was amazing until I over torqued it. Lesson learned. Poly mounts on engine first. Didn't like the torsional stresses one bit. Great transmission. Needs a refresh.
  14. Jun 15, 2020 at 10:18 AM
    #634
    rheath08
    Russell
    Bakersfield, CA
    how did you mate it to a transfer case? i thought it only was for 2wd application?
  15. Jun 15, 2020 at 10:23 AM
    #635
    Camby
    Brian
    Denver
    I really appreciate it good sir!
  16. Jun 15, 2020 at 10:28 AM
    #636
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It isn't. Was intending to mate an AWD transfer case to it. Haven't gotten there yet.
  17. Jun 15, 2020 at 11:21 AM
    #637
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    I've had mine for 5k-ish miles of Houston traffic and havent had any issues with the TOB itself
  18. Jun 15, 2020 at 11:36 AM
    #638
    Canadian_Shooter
    Sol
    Alberta
    2014 DCSB 6spd
    Just heard back from Clutchmasters. They recommended bleeding it again. I had it installed at a shop and when chatting with them it sounded like it was bled thoroughly but I will confirm.
    Torspd likes this.
  19. Jun 15, 2020 at 12:17 PM
    #639
    garciav
    Houston, TX
    TRD SC,HPTuners
    did they vaccuum bleed it ?
    I thought i had bled mine good at first, but after putting a vac on it i got a lot more bubbles out..
    TodayWasTHeDaY and Torspd like this.
  20. Jun 15, 2020 at 2:42 PM
    #640
    Canadian_Shooter
    Sol
    Alberta
    2014 DCSB 6spd
    They did yes. He did mention he wished they had put the fitting at the 12 o'clock opposed to the the 10 for ease of bleeding. Hopefully that's all it is. I'll get them to bleed it again.
    Torspd likes this.
