2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. Sep 6, 2019 at 10:11 PM
    #61
    Tootall604
    Tootall604 [OP] Well-Known Member
    2015 Tacoma sb
    In if it hits 15.
  2. Sep 8, 2019 at 10:05 AM
    #62
    406cruiser
    406cruiser Well-Known Member
    Just an update for everyone. At the moment, between Facebook groups, this forum and the fjcruiserforum it's looking like we've got about 23 people interested in the group buy so the price will be $375 and everyone will get an oil cap! Going to let the group buy run just a few days more to see if we can get some more people on board.
    Tomorrow I'm going to touch base with Clutch Masters and see what they think they can do for pricing on a combo kit with a clutch included and report back with what the price would be on that setup.
  3. Sep 8, 2019 at 10:10 AM
    #63
    dfoy01
    dfoy01 Member
    DJ
    Ohio
    2008 Toyota Tacoma TRD off-road
    Toytec 3in lift Leer Topper 17x9 0 offset Fuel wheels 265/70/17 tires
    This is just good news for everyone!
    TodayWasTHeDaY likes this.
  4. Sep 8, 2019 at 11:27 AM
    #64
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    I'm interested.
  5. Sep 8, 2019 at 12:32 PM
    #65
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Stoked on this! Bonus to get a bitchen oil cap too
  6. Sep 9, 2019 at 4:43 PM
    #66
    406cruiser
    Another update on all this. I chatted with the guys at Clutch Masters today and because of all the interest they are going to give $100 off a clutch kit on top of the $100 off of the hydro release bearing.
    I should have a code for everyone shortly once we get this group buy all wrapped up and all the details sorted out with CM. I will PM everyone the code once everything is finalized here in the next day or so it sounds like!
    Bluebaron7, Norton, garciav and 2 others like this.
  7. Sep 9, 2019 at 4:50 PM
    #67
    406cruiser
    As a side note, I'm running the FX100 clutch and have been incredibly happy with how it's performed alongside the hydro release bearing! I think the FX100 should work well even for you guys that are supercharged since the OE clutch can usually take the extra power the supercharger puts out, the FX100 definitely will be able to handle it no problem.
  8. Sep 9, 2019 at 7:31 PM
    #68
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Am I the only one thinking of a dual disk setup?
    Butter smooth engagement, nice light pedal, above and beyond holding power, reduced rotational mass, etc...
  9. Sep 9, 2019 at 7:55 PM
    #69
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I have URD's Twin disk when they still had it for sale. the pedal is all sorts of light with it. only issue i have is its easier to stall when offroading even with a crawl box over stock..
  10. Sep 9, 2019 at 9:41 PM
    #70
    jhaykane
    jhaykane Local 8251
    JB
    Hawaii
    2006 Tacoma 4WD
    Non Stock
    I was looking at the FX-300, didn’t see the twin disk being available for our taco.
  11. Sep 10, 2019 at 8:44 AM
    #71
    Canadian_Shooter
    Canadian_Shooter Member
    Sol
    Alberta
    2014 DCSB 6spd
  12. Sep 10, 2019 at 10:43 AM
    #72
    Tootall604
    2015 Tacoma sb
    I am in, let’s do this!
  13. Sep 11, 2019 at 12:23 PM
    #73
    406cruiser
    Unless someone ends up making over 6-700whp out of the 1GR, then the single disk options are going to work just fine. But I know I was chatting with Clutch Masters about the possibility of a twin disk setup and they have the model file to machine the flywheel already done and ready to go if anyone is wanting a twin disk. They have it listed on their site now as well because I told them there was some interest for a twin disk. Here's a picture the engineer sent me of their twin disk flywheel and also the cover assembly. This would use their 10" twin disk, or the FX1000.
    Since this kit was designed specifically for the RA60/61 transmission and the hydraulic fluid capacity of that system, the housing and piston that make up the slave cylinder have the perfect amount of travel for a clutch with the OEM stack height (the overall height of the clutch when bolted to the flywheel). When we installed the release bearing in my rig we were very careful to make sure that the bearing wasn't overthrowing the clutch. We did have to adjust the clutch pedal and how it actuates the master cylinder to get the release point to my liking but that was an easy process.
    This isn't always the case with all of the hydro release bearings as some of the same housings and pistons are used in a lot similar applications but the stack height of the clutch differs so to prevent the bearing from overthrowing the clutch, sometimes a pedal stop is necessary. But that isn't the case for our application in the Tacoma/FJ.
    Sounds good I've got you added to the list.
    I should have the coupon code for everyone by the end of the day and I'll PM that code to everyone who's said they are interested!
    dfoy01 and garciav like this.
  14. Sep 11, 2019 at 1:01 PM
    #74
    StumpyJoe
    StumpyJoe New Member
    Tacoma, WA
    05 Speedway Blue TRD
    looks awesome!! I'm in. :)
  15. Sep 11, 2019 at 1:46 PM
    #75
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    @406cruiser , do you know if they offer an fx250 option for our tacos ? I didnt see it listed on their site
  16. Sep 11, 2019 at 2:40 PM
    #76
    wrmathis
    Bonaire, GA
    parts and stuff
    Does the steel braided lines just screw into the hardlines? I know one is for the actual fluid and the other is a bleed hose
  17. Sep 11, 2019 at 6:17 PM
    #77
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    @406cruiser thanks so much for putting this together!
  18. Sep 12, 2019 at 12:09 PM
    #78
    406cruiser
    The one braided line screws into the hardline that is on the frame rail, so you are correct. As you mentioned the second line is just for bleeding.
    Yes, I do believe they should be able to make the FX250 for the Tacoma. I'll let them know that they don't have it listed on their site and that someone is interested and I'm sure they can quickly add it to the site if it is possible to make. I'll let ya know for sure!
    Also, just an update, I do have the code for everyone but I've had a handful more people in the last couple days shoot me a PM looking to join the group buy. I need to go through and make sure that I've accounted for everyone who's PM'd me or said they are in on this thread. Since we have about 30 people now it looks like, it's going to take me just a little bit to get the code to everyone. Soo soon as I'm off work today I'll head home and start shooting that code over to everyone!
  19. Sep 12, 2019 at 12:39 PM
    #79
    PacTac
    PacTac Well-Known Member
    Ben
    Bellingham Washington
    3RDGENOR
    Just got this installed the other day! So far it’s a night and day difference. The truck is so quite now, I’m driving around with the windows down and no music and lovin’ every minute of it!
    dnl_tacoma, D-E-L-T-A, dfoy01 and 2 others like this.
  20. Sep 12, 2019 at 12:43 PM
    #80
    Canadian_Shooter
    Sol
    Alberta
    2014 DCSB 6spd
    Awesome. Good to hear. Can't wait to get it in. Did you do it yourself?
