2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. Jan 4, 2022 at 8:44 AM
    #961
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    my clutchmaster hydro kit crapped out on me after about a year and half. Truck is currently at the shop. the guys are going to see if it makes sense to try and fix what went wrong with the CM kit or they we're going back to stock set up. Im leaning more towards the stock and just living with the chirp again if I get it. :annoyed::frusty:
  2. Jan 4, 2022 at 2:06 PM
    #962
    TacoTuesday1
    SD CA
    maybe the passage of time will play a nice role in this
    if enough 3rd gens become common, old, manual, totaled and in junkyards
    with their RC62F's otherwise not being sought after to increase the value
    may make them easier to obtain for conversions in the future
    I hope just the rubber seal can be replaced to fix it, to my knowledge they only sell that and a shim kit (optional) available on it's own
  3. Jan 4, 2022 at 11:52 PM
    #963
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    they offer a seal kit, but that may be what you are referring to. other than that there is not much to the kit. i do know when i ordered a new seal kit, the seal, "not the dust wiper" was different. maybe that is a improvement?
    https://www.tacomaworld.com/threads/clutch-masters-hydro-bearing-failure.720672/
    also look at carpart.com
    maybe car pats.com
    it is a search engine for used parts over multiple junk yards ? recyclers
  4. Jan 5, 2022 at 12:18 AM
    #964
    TacoTuesday1
    SD CA
    looks like they're asking $1.4k-2k
  5. Jan 5, 2022 at 4:58 AM
    #965
    CountryDan
    Daniel
    Calhoun GA
    So now Im curious. how big of an undertaking is it to get this to fit and work on our second gens? This is something I wouldn't do because I dont have the tools, knowledge, or space, But would this be an unreasonable/unrealistic request for a good shop? (this might be something I research and keep in my back pocket for down the road if I ever have another big set back)
  6. Jan 5, 2022 at 6:31 AM
    #966
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    All the info you need is covered here.
    https://www.tacomaworld.com/threads/6-speed-shenanigans-ra60f-swap-to-rc62f.701237/
  7. Jan 5, 2022 at 7:14 AM
    #967
    rheath08
    Russell
    Bakersfield, CA
    I paid $2250 with shipping for mine.
  8. Jan 9, 2022 at 10:22 AM
    #968
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Well, after following threads regarding the throwout bearing issue for over 10 years, it looks like I'm finally in the club. 115k miles and I've recently started noticing a sporadic chirp in neutral that stops if I touch the clutch pedal.
    What's been concerning me more is that when engaging 1st from a stop I get the same noise, but louder. This only seems apparent in the morning when the air temp and truck are cold. This morning I was getting a loud giggling squeak when taking off, but nothing in neutral.
    I'm wondering what to do from here. I've always loved the truck and it was always my long-term plan to keep it, but it sounds like a hooptie right now and I don't know if this thing is going to take a dump soon. I've read countless options over the years from T56 and RC62F swaps to hydro bearings and sleeve kits. As of right now, here are the options I'm considering from least to most expensive:
    • Do nothing and wait for the weather to get warmer
    • Have the TOB (and clutch pad) replaced and hope for another good 115k miles
    • Get rid of the truck and get a 3rd gen.
  9. Jan 9, 2022 at 10:55 AM
    #969
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    All three of those options are very biased to personal preference. There are a couple options as to replacing your TOB and clutch, and we can all give you recommendations on that. Doing nothing or buying a turd gen, that's on you. :thumbsup:
    TACK likes this.
  10. Jan 9, 2022 at 11:01 AM
    #970
    TACK
    Nevada
    Recommendations for TOB and clutch replacements would be greatly appreciated! I would be having any work done at a shop, since I don't have the space or time to be tackling transmission repairs myself.
    Lol I don't really want to get a turd gen, mostly because I'm frugal and hate buying vehicles. Plus I really do love my truck.
    CountryDan likes this.
  11. Jan 9, 2022 at 11:27 AM
    #971
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Spec makes amazing clutches. I am running the 3+. You will need to either resurface your existing flywheel, or buy a new one. I have URD's lightweight flywheel, they also make a heavy one. Be sure to get the flywheel bolts as well, as it is highly recommended you replace those while you're in there. ARP makes the bolts. As for TOB, you can replace with stock, sleeve with URD, or go hydro with Clutchmasters. Its 50/50 on CM if you leak or run properly. Mine took about 5k miles, and a ridiculous amount of bleeding, to finally smooth out and work normally. Other dudes have them leak and fail. It's a toss up.
    BassAckwards and TACK[QUOTED] like this.
  12. Jan 9, 2022 at 3:36 PM
    #972
    TACK
    Nevada
    I've also read of slave cylinder modifications that result in more adequate pressure against the pressure plate fingers: replacing the slave cylinder, rebuilding it with a stronger spring, etc. There's even a youtube video where a guy fixes the chirp on his Subaru by taking a dremel to the slave cylinder mounting bolt holes and shifting it forward! o_O
  13. Mar 25, 2022 at 6:30 PM
    #973
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    How has your URD sleeve kit held up since you installed it? Smooth & quiet still?
  14. Mar 25, 2022 at 9:46 PM
    #974
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Mine seems to be, about 2yrs and 25k ish miles.
    GilbertOz[QUOTED] likes this.
  15. Mar 26, 2022 at 4:45 PM
    #975
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Mine started chirping again after like 20k miles but its roughly half as loud as it was previously. Doesn't really bother me much.
  16. Mar 27, 2022 at 2:03 PM
    #976
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Chirping began anew after installing the URD sleeve almost 20k later... little less than one year. I was very fortunate and found a listing on FB marketplace for a great deal. Seemingly less force to work the clutch, and quieted the chirp for awhile. I believe URD states it works ~80% of the time, every time.
    Slave Cyl rebuild kit just arrived, so I'll be playing with that and adjusting the pedal some time soon.
    Also, because of the old TOB wobbling on the shaft, hehe, there were some grooves worn. So, the sleeve was a great band-aid on what could've been a very expensive problem.
    Key-Rei and GilbertOz like this.
  17. Mar 27, 2022 at 3:31 PM
    #977
    TacoTuesday1
    SD CA
    every now and again I hear a little bit of chirping with my HydroTOB, idk why. Maybe because it’s designed as constant contact. It goes away if I do a quick kick to the clutch pedal.
    but I don’t worry about it because it’s nowhere near as bad as the stock part
    stock part if I would’ve hired someone to hang underneath the truck or hide inside the bed screaming while I drive around, is pretty much how it was
    and not in a good way
    Some car noises are good like a rumble V8 but that was not
    dborrer and Key-Rei like this.
  18. Mar 27, 2022 at 3:36 PM
    #978
    Key-Rei
    Key
    Florida
    If I have another issue with mine I'll be doing the RC62 swap.
    Still kinda planning on it anyways but hopefully not till it's time to do the clutch again and I have everything conveniently ready to go on the side already.
  19. Mar 27, 2022 at 4:35 PM
    #979
    TacoTuesday1
    SD CA
    are you gonna go URD torque-u heavyweight flywheel and stage 2 clutch kit?
  20. Mar 28, 2022 at 12:25 AM
    #980
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Dude, I thought it was just mine! It chirps super randomly during the beginning of engagement.
