2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. Mar 28, 2022 at 12:44 AM
    #981
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you swap to an RC62?
  2. Jul 6, 2022 at 1:30 PM
    #982
    TacoTuesday1
    SD CA
    found leak from bleeder screw (it was tight) smh. 15k on it
    tightened it some more, cleaned, and will recheck later
  3. Jul 11, 2022 at 12:25 AM
    #983
    TacoTuesday1
    SD CA
    removed transmission
    installed new URD Torque-U Heavy flywheel, Stage 2 clutch kit/pressure plate
    performed cleaning of bellhousing and CM hydrotob, applied light coating of rubber grease to seal mating area (without taking tob apart) and high temp grease at metal contact surfaces (such as to pressure plate fingers)
    began driving/initial break in
    pedal adjustment still moves a bit on it's own, but propshaft is out being serviced. Maybe it'll stop when I get it back in. Been driving in 4HI to turn on front diff and be FWD
    Became quiet again.
    230mi (mixed driving, trying mostly city) started chirping again
    urge to trade in grows
  4. Jul 11, 2022 at 4:03 AM
    #984
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I understand the urge to trade in. My wife was talking about getting some bigger and more family friendly. I cant believe I suggested selling my truck and taking her 4runner, but Im just tried of the issues with the tob/clutchmaster kit and worrying about when its going to fail "AGAIN".
  5. Aug 2, 2022 at 8:28 AM
    #985
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    This stopped for about 6 months and is now back. :angrygirl:
  6. Nov 1, 2023 at 1:22 PM
    #986
    Tacomarocker
    Tacomarocker Active Member
    Tony
    2005 Tacoma TRD
  7. Nov 1, 2023 at 1:29 PM
    #987
    Tacomarocker
    Tony
    2005 Tacoma TRD
    I bought one lasted almost 2 years almost 30 K mile the O-ring wore out had to purchase new upgraded one from clutch master I notice some wear scratches on shaft wear bearing rides took some 1000 grit sandpaper to smooth out working Kik new again probably should buy new if and the O-ring goes out again but it works when it’s new better shifting and quieter than junky OEM also did the accumulator delete was like driving a new truck!
  8. Nov 18, 2023 at 2:36 PM
    #988
    Tfs94gt
    Tfs94gt Well-Known Member
    2013 DCSB Trd OR 6 spd
    Was the new seal easy to install onto the bearing? Mine just let go today.
  9. Nov 18, 2023 at 2:47 PM
    #989
    Tacomarocker
    Tony
    2005 Tacoma TRD
    It’s not on the bearing it’s in the the hydraulic release behind the bearing, I left it connected to transmission housing using pick tool to remove old worn O-ring the new one is rounded like a normal O-Ring the original was like a rubber washer flat inner and outer works great so far .
    Tfs94gt likes this.
  10. Nov 18, 2023 at 3:14 PM
    #990
    Tfs94gt
    Thank you for the quick response. I’m gonna hit CM Monday morning and get seal on the way. I’m considering trading this thing in over it. An unreliable toyota is not something I’m used to.
  11. Nov 18, 2023 at 6:40 PM
    #991
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Worn seals on the CM is a sign of failure farther on. My bearing wore out and started shifting in the housing, causing the piston to sit unevenly and rub in the CM piston housing causing the bearing to fail. Scrap the CM all together. It's 100% trash.
    TodayWasTHeDaY likes this.
  12. Nov 18, 2023 at 6:46 PM
    #992
    Tfs94gt
    I’m looking at what it entails to run the kellam Tipton bearing setup. I can’t let it stay down too long though so I gotta make sonething
    Happen relatively quick. Thank you for the advice.
  13. Nov 18, 2023 at 9:36 PM
    #993
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Options are return to stock or go Tilton. I am gonna go the Tilton route because I loved how the hydro TOB felt. I bike to work 99% of the time so at least I can be down for longer.
    rheath08 and Tfs94gt like this.
  14. Nov 19, 2023 at 5:06 PM
    #994
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I scrapped my CM kit too when it lasted maybe a year- year and a half. Best and worst thing to happen.
    I ordered the conversion kit for the tilton and when I get extra money I'll pick up the rest of the parts for the tilton conversion.
  15. Nov 30, 2023 at 12:11 PM
    #995
    Alexander20
    Alexander20 Active Member
    2007 Tacoma TRD Off Road
    Just providing an update on my post from 2.5 year ago - The squeal has still not returned after the fix quoted above
  16. Jan 4, 2024 at 10:18 PM
    #996
    HillBillyRedNeck
    HillBillyRedNeck Well-Known Member
    JOSH
    Arlington, Wa
    2010 Tacoma SR5
    cheap spacer lift for now
    I've had the sleeve kit since 2012 and my pickup had 30k. The bearing blew to pieces at 155k. It had been chirping again for years, but it finally failed. I have driven the crap out of it. Frequent off roading, snow trips, lots of time in the woods, and towing. I replaced the clutch with all new toyota parts, I was hoping the bearing was updated by now. After two months with the factory bearing back in its chirping again.
  17. Aug 7, 2024 at 3:36 PM
    #997
    marito909
    marito909 Member
    Mario
    Do nothin, bought my 2011 Tacoma back in 2014 50k miles and in 2016 (80k miles) heard the chirping noise, I did nothing and I’m at 147k and trans still going strong, I rarely hear the chirping now and it seems to have gotten bette
    Littles likes this.
  18. Oct 22, 2024 at 7:26 PM
    #998
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Whew. OK, a lot going on here, but I am noticing some trends. My 2G has 199k on the original clutch, no chirps, tweets or slipping, but it gets very "bucky" starting from a stop fairly frequently. I'm hoping to not regret getting the 6MT after this, so here's what I am hoping is a best shot combination for a stock truck:
    - New OEM flyhweel (at least this one is easy)
    - New OEM PP/Disc, Aisin (I originally bought Luk before I discovered all the drama - it will be returned)
    - URD Sleeve, and they confirmed the OEM bearing they modify for it is the one for the Aisin clutches
    - The pointed set screws make my skin crawl..I would toss those down the laundry cute to hell, pretend I never saw them, and install with retaining compound
    - New OEM clutch master/slave (TSB) and soft/flex lines
    - Potentially modify or bypass the accumulator but that's more for curiosity; some people seem to think it makes a big difference but I'm pretty sure I can't even tell it's there to begin with (same on my former '22)
    Really I think the only thing in question is the URD sleeve setup. Truck is still in one piece so it's a mystery on the condition of the quill, but short of a botched installation, I'm not sure I can come up with a reason why it would hurt anything since it uses an OEM bearing now.
    kissymoose likes this.
  19. Nov 4, 2024 at 1:11 PM
    #999
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Any chance you put a list of part numbers together? I need to gather everything too
  20. Nov 4, 2024 at 5:26 PM
    #1000
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    I absolutely do but don't have the time to throw them up right now - bump this thread or DM me if I forget and don't do it in the next few days. It took a bit of legwork to get it all together so I definitely want to get it up for others' benefit if it helps.
