2nd gen manual transmission fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tootall604, Aug 13, 2019.
  1. Sep 13, 2019 at 12:32 PM
    #101
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does your hydro bearing remove the aluminum quill? Im wondering if this does as well
    Athlaos[QUOTED] likes this.
  2. Sep 13, 2019 at 12:33 PM
    #102
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Yeah, the quill is removed as part of that kit.
  3. Sep 13, 2019 at 12:37 PM
    #103
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    For the clutch master kit you don’t have to remove the quill. Look at the install pics it’s still there.
  4. Sep 13, 2019 at 12:55 PM
    #104
    406cruiser
    406cruiser Well-Known Member
    Well I didn't realize some of you supercharged guys are making that kind of power, that's awesome! Then yeah like garciav mentioned, if you want something in-between the FX100 and FX300, the FX250 is a good option. I'm sure if Clutch Masters hears from a few of you guys that are making significantly more power over stock they'll get those in between options added to their website. I'll also just follow up with Clutch Masters and let them know anyway that it might be something they just add to the website.
    The quill is retained with the Clutch Masters' kit. For those guys out there that have the URD hydro setup that have cut the quill, from everything I've shown Clutch Masters they are still confident their setup will work because there is just enough left of the quill to register the spacer around the center of the input shaft and then the bearing housing gets bolted to the case so everything is still held in there solid.
    For you guys who have the PDM steel sleeve kit, hopefully you put a little bit of grease in there and it should be no issue to slide off. I know it's a fairly tight fit but I didn't see anything about it being a fit so tight anyone needed to hammer it on or anything so hopefully with a little love it should slide off. Maybe need to get a little pry bar on it from the inspection hole on the side.
    BassAckwards and TodayWasTHeDaY like this.
  5. Sep 13, 2019 at 3:05 PM
    #105
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Do you know what mustang hydrobearing it is? I emailed gadget and he wanted 150 for a replacement
  6. Sep 13, 2019 at 4:04 PM
    #106
    wrmathis
    Bonaire, GA
    parts and stuff
    I was thinking of possible a 2/3 jaw puller if I could find one that reached.
    I know when I installed mine 6 years ago the instructions at the time said to hammer it on with a block of wood or something that doesnt our hammer face onto the sleeve itself
  7. Sep 16, 2019 at 4:36 PM
    #107
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ordering today. :D
    Dragons Taco likes this.
  8. Sep 16, 2019 at 6:03 PM
    #108
    wrmathis
    Bonaire, GA
    parts and stuff
    slow poke. get with the times.
  9. Sep 16, 2019 at 7:58 PM
    #109
    jhaykane
    jhaykane Local 8251
    JB
    Hawaii
    2006 Tacoma 4WD
    Non Stock
    Ordered mine today along with CM’s FX-250.
  10. Sep 16, 2019 at 8:07 PM
    #110
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Hey @406cruiser
    Who there at Cmasters have you been dealing with?
    I want to call and chat for a sec about the correct clutch for my setup then order.
    TodayWasTHeDaY likes this.
  11. Sep 16, 2019 at 8:31 PM
    #111
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Tried to order yesterday but their
    Keep me posted on what you decide. I'm going with the hydro bearing and thinking of a lightweight steel flywheel from them (not sure if they have one for our application) but probably going with a spec stage 2+ clutch. Had 3 seconds of nothing on a 3-4 shift WOT run going uphill on a backroad highway a few days ago so my stock clutches days are numbered.
    BassAckwards likes this.
  12. Sep 16, 2019 at 9:51 PM
    #112
    06RadiantTacoma
    06RadiantTacoma Well-Known Member
    Is it too late to get in on this group buy? My poor truck has been chirping so bad for the last year
  13. Sep 17, 2019 at 4:41 PM
    #113
    dfoy01
    dfoy01 Member
    DJ
    Ohio
    2008 Toyota Tacoma TRD off-road
    Toytec 3in lift Leer Topper 17x9 0 offset Fuel wheels 265/70/17 tires
    Ordered
  14. Sep 17, 2019 at 8:11 PM
    #114
    406cruiser
    Hey BillDaCat, Kevin or Luis are solid guys to chat with at Clutch Masters!
    I know they have made flywheels for the Tacoma in the past as that was something I asked them about possibly getting a new flywheel for my FJ when I installed the clutch. I was actually thinking something slightly heavier then factory since I've read that it helps with wheeling but in the end just decided to keep the factory flywheel.
    Definitely a lot of options for clutches out there, but I know Clutch Masters was offering a discount on the clutch setup as well with the purchase of the hydro bearing kit so that might be something to consider.
    It's not too late, I'll shoot you a PM now!
    Awesome!
    BillDaCat8[QUOTED] likes this.
  15. Sep 17, 2019 at 8:52 PM
    #115
    bruciep07
    bruciep07 Well-Known Member
    Bruce
    Central NJ
    2015 Sport
    Not sure how I missed this, have been kicking one of these around for a while now! Am I too late to get in on the action?
  16. Sep 17, 2019 at 8:57 PM
    #116
    406cruiser
    Not sure about the R155, but I know they do have a kit for the R154 transmissions, not sure how similar those two transmissions are though as I have no experience with the R155.
    http://www.clutchmasters.com/n16063-2h-toyota-r154/
    Just sent you a PM bruciep!
  17. Sep 18, 2019 at 6:09 AM
    #117
    BassAckwards
    Hoping they show us 5spd guys some love:popcorn:
  18. Sep 18, 2019 at 10:59 AM
    #118
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Can you send me the code too. Sent you a pm but must've been overlooked.
  19. Sep 18, 2019 at 1:49 PM
    #119
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    @406cruiser,
    Please PM me the code as well, in for the bearing
  20. Sep 18, 2019 at 9:19 PM
    #120
    406cruiser
    PMs sent! I definitely saw your PM @Chris(NJ) , you should have the info in your inbox!
    Blackout Z7 and k5driver[QUOTED] like this.
