2nd gen marlin gears
Discussion in 'Performance and Tuning' started by 06tacomakev, Oct 29, 2012.
  1. Oct 29, 2012 at 8:57 AM
    06tacomakev
    06tacomakev [OP] Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I have gone to the Marlin site and checked out the goods. Just awesome!
    Am a bit confused with the core charge and such.
    I am just looking for a gear reduction in the T-case. Would like to drop down to a 4:1 ratio. I am an 06 access cab. I am probably just missing something but has anyone else bought the gear set and put it in? Or have people just done the T-case swap?
  2. Oct 29, 2012 at 10:23 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'd like to know how difficult it is. New tcase gears would be great.
  3. Oct 29, 2012 at 10:36 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Can't change the gearing in a chain driven case
  4. Oct 29, 2012 at 10:36 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    You can not put lower gears in your existing transfercase.
    It is chain driven and does not allow for a reduction gear to be swapped.
    You have 2 options:
    Either adding a crawl box or going with the "lefty" hybrid case which is an older gear driven transfer case that has adapters to turn it into a drivers side drop.
    Time for you to start some reading.
  5. Oct 29, 2012 at 10:41 AM
    06tacomakev
    Kev
    Victoria BC
    :rolleyes:
    Great, more reading besides the hours of Solid Axle Conversion threads
    thx
  6. Oct 29, 2012 at 10:45 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    Read in the RockSolidToys forum and read everything that awsmdc has written
  7. Oct 29, 2012 at 10:48 AM
    06tacomakev
    Kev
    Victoria BC
    Thx for that too,
    Just looking at the Marlin site again I see the combo is only adaptable to the auto transmission from what I see anyway. I am the 6spd variety
    hmm
    I will check out Wyatts build though
  8. Oct 29, 2012 at 10:57 AM
    06tacomakev
    Kev
    Victoria BC
    Hey Wrmathis,
    Very nice build. I see where you are coming from. You went with the inchworm setup I see.
    It sounds like to get the crawl ratio I am looking for the chain drive has to go completely
  9. Oct 29, 2012 at 11:50 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    My tcase is still chain driven, I just put a crawl box in between the tcase and the transmission
  10. Oct 29, 2012 at 11:50 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    Also, I have a 6spd too. No auto here
  11. Oct 29, 2012 at 12:32 PM
    06tacomakev
    Kev
    Victoria BC
    Have you had any problems with the low ratio and existing t-case.
    Reason why I am asking is the Marlin site suggests possible problems. I could be reading it entirely wrong though lol
    Wouldn't be the first time
  12. Oct 29, 2012 at 12:59 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    No, did everything that Wyatt has done over and over again
  13. Nov 1, 2012 at 5:10 AM
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    You shouldn't have any issues with a marlin crawler in front of your chain case. I have run this setup on my truck for years and have put it on many others as well. Never had a issue.
  14. Nov 1, 2012 at 8:18 AM
    06tacomakev
    Kev
    Victoria BC
    thx for that.
    Was cruising the RST trip report you guys just did. Every single sas truck I have been drooling over was on that trip!
    That is quite a contingent of crawlers down your way
    Nice work
    When it comes time to do the work I may just do a drive down the coast and drop my truck off with you guys for a few weeks!
