2nd gen oil leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scotty54, Jan 5, 2025.
  1. Jan 5, 2025 at 4:48 PM
    Scotty54
    Scotty54 [OP] New Member
    Scott
    2009 White Tacoma Access Cab
    2009 Tacoma, 2.7 4 cylinder engine, 188,000 miles. Slight oil leak that burns on exhaust system. No leak on the ground. I replaced the valve cover gaskets and can still smell oil burning on the exhaust system. No visible leak. Any ideas where the leak could be?
    Thanks Scott
  2. Jan 5, 2025 at 4:49 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Its either residual, or you have a leak. Either find the leak, or clean it up.
  3. Jan 6, 2025 at 12:11 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Have you been able to look from below and find any oil or stains on the exhaust pipes?
    I'd recommend spraying down your exhaust with brake clean and insure the engine is clean.....then start the truck and look for a leak.
    Forgot to mention make sure the truck is good and cold when you spray the brake clean.... otherwise that might not go well
  4. Jan 7, 2025 at 8:55 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I would not rely on "smell" to diagnose an oil leak.
    I would refer to spots on the ground , smoke under the hood or low on the dipstick.
    ......easier to detect smoke in the dark in the rays of a flashlight beam
    Burning plastic can smell like oil, I have had plastic bags blowing around on the road get stuck to the exhaust
    ZColorado and kidthatsirish like this.
