2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Nov 5, 2013 at 7:54 PM
    #301
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yea 1 set did, the other set had nothing marked on it oddly. CS047.
  2. Nov 5, 2013 at 7:56 PM
    #302
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    No marking is not unusual
    They get a " + " , nothing , or a " - "
    + is above spec
    nothing is spec
    - is below spec
  3. Nov 5, 2013 at 7:59 PM
    #303
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Ah gotcha, thanks for the info.
  4. Nov 5, 2013 at 8:01 PM
    #304
    OZ-T
    Peter North
    British Columbia
    No problem
    Added you to the averages in the OP
  5. Nov 7, 2013 at 7:47 AM
    #305
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I'm working on 2.5 hours of sleep, so this may be a stupid question. Are you guys actually taking the tire off to measure at the center of the hub or are you measuring where the center of the hub would be with the tire still on?
  6. Nov 7, 2013 at 8:01 AM
    #306
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I have to wonder if what you get is completely random? Both of mine had the + on them. I would have expected only one to have a + to compensate for the driver's side lean.
  7. Nov 7, 2013 at 8:07 AM
    #307
    OZ-T
    Peter North
    British Columbia
    I'm not 100% sure
  8. Nov 7, 2013 at 8:09 AM
    #308
    Hairy Taco
    North of Hell
    08 TRD
    It doesn't bother me, but I am a good 1/2 inch higher on the passenger side.
  9. Nov 7, 2013 at 8:11 AM
    #309
    OZ-T
    Peter North
    British Columbia
    You can get flat axle shims that provide height without changing the pinion angle
    also , did you install a trim packer on the driver's side up front ?
  10. Nov 7, 2013 at 8:12 AM
    #310
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I called ARB USA about the side specific leafs and they said the A & B marking define driver or passenger sides.
  11. Nov 7, 2013 at 8:15 AM
    #311
    Hairy Taco
    North of Hell
    08 TRD
    Yep, the trim packer/spacer is in on the front drivers side.
    Didn't know about the flat axle shims, thanks for the info. Perhaps I will get to that one day. The lean doesn't really bother me, though if it gets worse I will definitely want to address it.
  12. Nov 7, 2013 at 8:34 AM
    #312
    OZ-T
    Peter North
    British Columbia
    That's a first gen thing , this is a 2nd gen thread
  13. Nov 7, 2013 at 8:36 AM
    #313
    OZ-T
    Peter North
    British Columbia
  14. Nov 7, 2013 at 8:45 AM
    #314
    cstallings
    Arkansas
    That is what I thought, but wanted to make sure I wasn't completely missing the boat!
  15. Nov 7, 2013 at 9:13 AM
    #315
    Hairy Taco
    North of Hell
    08 TRD
  16. Nov 8, 2013 at 7:47 AM
    #316
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I did my last round of measurements from the top lip of my rim to edge of fender..seems to work easier to compare left to right.
  17. Nov 16, 2013 at 11:31 AM
    #317
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Last week I installed my Dakars and as of now I'm sitting at 25'' on the rear right and 24'' on the rear left..... the front is suffering some serious taco lean so I'm waiting for the LP to settle a little more and the I'm going to see if I can level all 4 corner a bit by adjusting my coil-overs....
  18. Nov 19, 2013 at 9:12 PM
    #318
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Installed today. Hope they don't settle too much
    DCSB w/ long overload removed from the pack, a Snugtop XV, and optima 31 behind the rear d side passenger seat = 23.75D/24.25P with a full tank of gas. Average 24"
  19. Nov 19, 2013 at 9:14 PM
    #319
    OZ-T
    Peter North
    British Columbia
    By long overload , do you mean one of the two bottom overloads ?
  20. Nov 19, 2013 at 9:33 PM
    #320
    abarber11
    ATX
    2011 DCSB
    yes sorry, the top overload or the long overload, second to bottom
