2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Nov 19, 2013 at 9:12 PM
    #321
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Installed today. Hope they don't settle too much
    DCSB w/ long overload removed from the pack, a Snugtop XV, and optima 31 behind the rear d side passenger seat = 23.75D/24.25P with a full tank of gas. Average 24"
  2. Nov 19, 2013 at 9:14 PM
    #322
    OZ-T
    OZ-T [OP] You chose ... poorly
    Peter North
    British Columbia
    By long overload , do you mean one of the two bottom overloads ?
  3. Nov 19, 2013 at 9:33 PM
    #323
    abarber11
    ATX
    2011 DCSB
    yes sorry, the top overload or the long overload, second to bottom
  4. Nov 19, 2013 at 9:36 PM
    #324
    OZ-T
    Peter North
    British Columbia
    OK , added to the averages
    Thanks
  5. Nov 23, 2013 at 11:38 PM
    #325
    S4RSSS
    S4RSSS Well-Known Member
    NorCal
    4x4
    2006 AC V6 4x4
    Installed over 2 years ago (July 2011):
    OME CS047R "+" on both sides w/ D29XL AAL to the DS only
    Measurement today (November 2013) w/ 5/8th full tank
    DS: 24 7/8"
    PS: 24 1/2
    additional weight sitting above the dakars:
    CBI Bushmaster 2.0 bumper
    Leer aluminum contractor shell
    hannibal roof rack
    30lb of tools in toolbox (DS)
    hannibal awning (PS)
    hi-lift mounted (PS)
    ARB 50qt (PS)
    Rigid 40" light mounted to front of hannibal rack
  6. Nov 24, 2013 at 7:50 AM
    #326
    OZ-T
    Peter North
    British Columbia
    What's your passenger side height ?
  7. Nov 28, 2013 at 1:48 PM
    #327
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB pre runner
    Debadged, BHLM, AFE CAI, Magnaflow Cat Back, Method 301 16X8 w/285/75 BFG T/A KO 2's, King ex C/O's w/RR, King rears w/RR LR UCA's, Dakar leaf packs, Beefed narrow sliders
    Where dose the D29XL leaf go? top of the pack or bottom on top of the overload leafs?
  8. Nov 28, 2013 at 2:03 PM
    #328
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Not top or bottom. It has to be integrated into the pack. Looking for a photo.
  9. Nov 28, 2013 at 2:13 PM
    #329
    DoorDing
    Bodie, CA
    yes
    Where do I place an additional leaf (AAL) in my leaf pack?
    Old Man Emu additional leafs (OME D1XL, etc) are designed to fit in the pack according to their length. So when fitting in the pack, they will always go underneath a spring that is longer and above a spring that is shorter, keeping with the hierarchy of the spring pack. This applies to the normal active springs, not the short/thick overload leaves that are on the bottom layer of some heavy duty option springs such as the CS004R, etc. Likewise, the direction of the leaf in the pack should match the rest of the spring, i.e. the long side of the AAL (measured from either end to the spring pin hole) should match that of the existing leaves. The spring pin supplied by OME should be adequately long enough to add an additional leaf in most applications. If yours appears to have less than 1/4" of additional thread or has been cut/damage, please discuss a new pin at time of order.
    And from earlier in this thread. The loose AAL is on the bottom, Dakar spring in middle (D29XL not installed), OEM on top.
  10. Nov 28, 2013 at 2:31 PM
    #330
    OZ-T
    Peter North
    British Columbia
    It goes below the 3rd leaf down from the top
  11. Dec 2, 2013 at 6:34 PM
    #331
    SKULLY
    Dave
    San Diego
    06 DCSB pre runner
    Thanks for the info. Just got a used set with the top overload removed and trying to figure out if I want to order the D29XL leaf or not before I put them on. I have switched out my packs a few times and it sucks to get done and not have the numbers you are looking for.
  12. Dec 29, 2013 at 8:05 PM
    #332
    OZ-T
    Peter North
    British Columbia
    I see some new posts with people installing Daks
    Time to post up your numbers
  13. Dec 30, 2013 at 9:11 AM
    #333
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    2011 DCSB
    885's front
    Dakar rear
    Leer canopy
    Drivers - 24 1/2
    Passenger - 24 1/4.
  14. Dec 30, 2013 at 9:16 AM
    #334
    OZ-T
    Peter North
    British Columbia
    Added to the averages in the OP
    Thanks
  15. Dec 30, 2013 at 1:51 PM
    #335
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Question/request for the trd off road guys. What is the stock measurement from centerline of hub to wheelwell lip? I want to see if my lift has settled any and I never wrote down the stock numbers
  16. Jan 6, 2014 at 4:42 PM
    #336
    joeybags
    joeybags Well-Known Member
    joe
    pa
    2011 4x4 trd sport mgm
    dcsb driverside 24 3/4 passenger side 25 with a full tank of gas
  17. Jan 6, 2014 at 5:16 PM
    #337
    BostonBilly
    Easton
    Thanks
  18. Jan 6, 2014 at 5:20 PM
    #338
    OZ-T
    Peter North
    British Columbia
    Those aren't stock numbers
  19. Jan 7, 2014 at 3:31 AM
    #339
    BostonBilly
    Easton
    Oops. Ok thanks Oz. Still hoping for a stock number
  20. Jan 7, 2014 at 1:50 PM
    #340
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    Click build link in Sig >>
    lookin for some info here guys.
    what number from hub to fender in the rear would be level to 3" of lift up front? I THINK the hub to fender numbers for front are around 24.. correct me if im wrong.
    looking to replace my Icon 3 leaf pack (1.5" over stock) with something a little beefier as the Icons have already flattened out and are way too soft. just want to be level to 3" up front and not have them flatten out on me.
    Thanks ~ Moose
