2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Mar 18, 2014 at 6:25 PM
    #381
    HHogrider
    HHogrider Well-Known Member
    Mark
    Lexington, KY
    11 Tacoma Sport Pyrite Mica
    Tint, ARE Z-Series Cap, Yakima rack on cap, ROLA basket, SCS Stealth 6 Matte Gunmetal with full size spare, 285 Terra Grappler, OME lift (885's with Top Plate Spacers, full DAKARS, Carrier bearing drop, stainless extended rear brake lines, BORLA cat back exhaust, color matched All-Pro rear bumper
    FWIW, the before up front was:
    L: 19 3/4
    R: 20 1/2
    And I really like the after with spacers and trim packer:
    L: 24
    R: 24
    Yes, that is 24" on all 4 wells after full tank and loaded in the back 4 days after install. Not a geometry guy or engineer and a bit puzzled. Net gains were 4 1/4 LF, 3 1/2 LR, 3 1/2 RF and 3 RR. With the tires (285) everything is 40" from the ground except LR which is 39 1/2 and those gains are 5 1/2, 4 1/2, 5 and 4 respectively? It is what it is!!! At least it looks balanced
  2. Mar 20, 2014 at 4:04 PM
    #382
    Uncle Cliffy
    Uncle Cliffy Never tell me the odds.
    Clifford
    So. Oregon
    06 DCSB 4x4
    https://www.tacomaworld.com/threads/uncle-cliffys-build.327590/
    New Dakars on a 2006 DCSB 4x4. Top overload removed. Bed mat and a CBI rear bumper. stock spare...
    Driver ; 23.75
    Passenger; 24.25
  3. Mar 20, 2014 at 5:26 PM
    #383
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Added
    Thanks
  4. Mar 23, 2014 at 6:04 PM
    #384
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Setup:
    Full OME kit: 885 coils, dakars 1/4 top plate spacer, trim packer, LR UCAs. 265/70/17
    Before:
    After:
    Measurements:
    Before:
    Driver Side: Front 20 1/4", Rear 22"
    Pass Side: Front 20 1/2", Rear 22"
    After:
    Driver Side: Front 23 1/2", Rear 24 1/4"
    Pass Side: Front 23 1/2", Rear 24 1/4"
    Double Cab
  5. Mar 23, 2014 at 6:07 PM
    #385
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  6. Mar 31, 2014 at 1:05 PM
    #386
    blackoma
    blackoma Active Member
    Hendersonville, NC
    2011 AC V6 4x4 TRD Sport
    OME 885x coils, LR UCAs, OME shocks all around, Dakars w/ D29xl AAL, Leer Camper shell.
    Couple hundred miles on them.Both packs displayed a '+'.
    Access cab, V6, 4x4 with Leer fiberglass camper shell. 25 3/8".
  7. Mar 31, 2014 at 1:18 PM
    #387
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  8. Mar 31, 2014 at 8:02 PM
    #388
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    After a few thousand the + pack dropped to 24.75" and the 0 pack is still at 24.5"
  9. May 1, 2014 at 2:27 PM
    #389
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    DCSB 24 1/2
  10. May 1, 2014 at 2:34 PM
    #390
    OZ-T
    Peter North
    British Columbia
    Added
  11. May 1, 2014 at 3:34 PM
    #391
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
  12. May 1, 2014 at 4:20 PM
    #392
    OZ-T
    Peter North
    British Columbia
  13. May 1, 2014 at 6:02 PM
    #393
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    I'm putting a steel bed rack and rtt... Hopefully I won't sag much... but if I do I might do the aal to the Dakar LPs
  14. May 2, 2014 at 8:06 PM
    #394
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I have the D29XL's added to Dakars and Leer cap on my DCSB and it settled down after about a year to 25 5/8". I tow and load often.
  15. May 8, 2014 at 9:13 AM
    #395
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    After 350 miles.
    2011 DCSB 4x4
    Load in bed: Weatherguard toolbox with gear, estimated at 125 lbs.
    885x coils up front, no trim packer or spacers
    CS047R rear springs, no leaves added or removed
    Left side
    Front: 22 1/4"
    Rear: 24 1/2"
    Right side
    Front: 23"
    Rear: 24 1/2"
  16. May 8, 2014 at 12:02 PM
    #396
    OZ-T
    Peter North
    British Columbia
    added
    thanks
  17. May 15, 2014 at 6:37 PM
    #397
    CanadianTRDOffRd
    CanadianTRDOffRd Well-Known Member
    British Columbia
    07 Black TRD Off Road
    Painted black rear bumper Painted front grill Maxpider digital fit floor mats Black Tail Lights Black Depot headlights Full OME lift LR UCA's Relentless front Bumper Thule Rack System 285/70/17 KO2’s
    Access cab
    Driver Side: 25"
    Passenger Side: 25"
  18. May 15, 2014 at 6:39 PM
    #398
    OZ-T
    Peter North
    British Columbia
    added
  19. Jun 2, 2014 at 9:47 PM
    #399
    Yotski
    Yotski Well-Known Member
    Alex
    Hilo, Hawaii
    13 SSM Access Cab V6 6 Speed 4x4 TRD Off-Road
    Wet Okoles, Toytec BOSS 3in Kit, Allpro Standard Leaf pack, Ext Bilstein 5100, OEM Skid Plate(destroyed), Thule Racks, Method NV, KM2s, Rigid Grille & Light Bar
    Is there a thread like this for the allpro expos? want to compare
  20. Jun 2, 2014 at 9:53 PM
    #400
    OZ-T
    Peter North
    British Columbia
    Not that I am aware of
