2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Jun 10, 2014 at 7:11 PM
    #401
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    OZ, want to check with you before I install my D29XL, this should be the third leaf in the leaf pack yes?
    I only assume this because a distributor's site states to decrease spring rate and 15mm height, remove 3rd leaf
  2. Jun 10, 2014 at 7:25 PM
    #402
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    I believe it goes under the 3rd leaf down , becoming the 4th leaf down , it should be fairly obvious by the length though
  3. Jun 14, 2014 at 9:14 AM
    #403
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
  4. Jun 14, 2014 at 9:16 AM
    #404
    OZ-T
    Peter North
    British Columbia
  5. Jun 29, 2014 at 8:14 PM
    #405
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    I've got a 2012 4 cylinder AccessCab 4wd. OME 884x in the front and Dakar in the rear. OME Nitrocharger shocks all around, With a full tank of gas, I measured:
    Front: Left=22 3/4", Right=23"
    Rear: Left=24 1/8", Right=24 1/4"
    That measure is with around 500-ish pounds of added weight: skid plates, sliders, canopy/topper, bed platform, dogs.
    For reference, the Dakars have the "+" leaf on the driver side and "-" on the passenger side. Trim packer added under driver side front coil.
  6. Jul 20, 2014 at 2:11 PM
    #406
    ajwhlr04
    ajwhlr04 Well-Known Member
    Aaron
    Woodland Hills, CA
    2007 Tacoma 4x4 Double Cab 6MT
    07 DCSB, 4x4, 6-speed
    Went from non-tsb leafs to dakars (no AAL), + on both sides.
    885s in the front with 1/4" spacers. No armor, no bumper. Trim packer on driver side.
    Before-lift height (center of hub to fender):
    Driver side front: 20.0"
    Passenger front: 20.375"
    Driver rear: 21.125"
    Passenger rear: 21.375"
    Post-lift ride height (center of hub to fender):
    Driver side front: 24.0"
    Passenger front: 24.125"
    Driver rear: 24.875"
    Passenger rear: 24.875"
  7. Jul 20, 2014 at 2:19 PM
    #407
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  8. Jul 25, 2014 at 12:28 PM
    #408
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    DCSB with Snugtop
    Current setup TSB springs with spacer:
    Left 22.5
    Right 23
    With Dakars
    Left 24
    Right 24
  9. Jul 25, 2014 at 12:38 PM
    #409
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    OZ (or anyone with DCLB who often has a loaded bed) I'm looking at picking up a set of Dakars. Next time you have around 1000 lbs of weight in the back can you measure the height with that load so I can compare it to unloaded. I'm curious how much these springs would sag with my slide-in camper and a full load of gear.
    Right now the Timbren SES and my stock leaf pack is about level but probably not as good for ride quality and stability.
    Thanks
  10. Jul 25, 2014 at 12:40 PM
    #410
    OZ-T
    Peter North
    British Columbia
    Added , thanks
  11. Jul 25, 2014 at 12:40 PM
    #411
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    What are you running for shocks? OME?
  12. Jul 25, 2014 at 12:42 PM
    #412
    OZ-T
    Peter North
    British Columbia
    I had 1500lbs of timbers in the back plus my Leer cap and my rear came down approx 1 1/2 - 2"
    You should consider the OME d29xl AAL
  13. Jul 25, 2014 at 12:43 PM
    #413
    OZ-T
    Peter North
    British Columbia
    It's says trim packer on driver's side so I would presume OME shocks since the trim packer only works with OME shocks
  14. Jul 25, 2014 at 12:46 PM
    #414
    OZ-T
    Peter North
    British Columbia
  15. Jul 25, 2014 at 12:58 PM
    #415
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Thanks. I'm trying to find a non-air bag solution to having a level ride loaded, not not have my ass up in the air when the camper's out. Can't make up my mind. I don't want more than a couple inches of lift in the front and back, loaded or unloaded.
  16. Jul 26, 2014 at 5:09 AM
    #416
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I've got 25.5" on the driver's side, 26" on the passenger side.
    I'm using the 3 degree axle shims from Wheeler's which are a little thicker than the zinc ones from Toytec. I also used 40mil PVC liner between the leaves to stop squeaking.
    I'm guessing these two things are why I'm getting a little more lift than most people are reporting.
  17. Jul 26, 2014 at 8:01 AM
    #417
    ajwhlr04
    Aaron
    Woodland Hills, CA
    OME 90021 on the front, and OME 60091 on the back. I think all Nitrocharger, but not certain.
    I should add that I took the measurements immediately after installing everything. I jumped on the bumpers and then measured. It has settled significantly since then, so I'll probably edit my post soon after it's settled. I checked last night after installing longer brake lines and it was down to 23.5 front and 24.5-25.0 rear.
  18. Jul 27, 2014 at 4:10 PM
    #418
    Plannerman99
    So Cal
    I removed the shell last night and both sides went from 24" to 24.5"
  19. Jul 27, 2014 at 4:14 PM
    #419
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    25 on all four corners
  20. Jul 27, 2014 at 5:26 PM
    #420
    OZ-T
    Peter North
    British Columbia
    DCSB or DCLB ?
