2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Jul 31, 2015 at 6:02 PM
    #501
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I had same experience.. and it ended up being more shock related.. just something to check into
  2. Jul 31, 2015 at 6:14 PM
    #502
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    huh... Im in my shop with a level floor.
    I just checked it again after flexing it good and driving around for awhile. It has settled a bit. and now Its closer to a 1/2" lean with almost a full tank. That's more reasonable. But still I thought the Dakars would fix it. :(
    Heres my numbers, and I have my Canopy on.
    Both Dakars have a (+)
    right now im at DR: 24-1/4" DF: 23" I thought the front was worse, but it perty level
    PR: 24-3/4" PF: 23-1/8"
    So I figure with a 1/4 full tank my rear should only have about a 1/4" lean.. Not bad. I can live with that! :)
    Soo glad it settled a bit.
  3. Jul 31, 2015 at 6:22 PM
    #503
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    You could go with a rear trim packer like I linked earlier if it doesn't bed in any more
  4. Jul 31, 2015 at 6:25 PM
    #504
    Jeffvt0508
    Jeff
    Anderson, SC
    Hey oz are those new?.. didn't know they were available..
  5. Jul 31, 2015 at 6:27 PM
    #505
    OZ-T
    Peter North
    British Columbia
    Not new , I didn't know they existed till last year when Yotadan mentioned them though
  6. Jul 31, 2015 at 6:28 PM
    #506
    Jeffvt0508
    Jeff
    Anderson, SC
  7. Jul 31, 2015 at 6:36 PM
    #507
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    I'm wondering what the hub to fender measurements are, if your pass is 25 and driver 24". Maybe your bumper is crooked?? Post some pics from behind and underneath. Check your shackles too i put a bolt in backwards on the driver side and it got hung up pushing the driver side down
  8. Jul 31, 2015 at 6:38 PM
    #508
    OZ-T
    Peter North
    British Columbia
    So are these the numbers you're submitting for the OP ?
    24 1/2" average rear ?
  9. Jul 31, 2015 at 7:02 PM
    #509
    ETaco23
    Evan
    PNW
    ^^ sure..
  10. Jul 31, 2015 at 7:02 PM
    #510
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  11. Jul 31, 2015 at 8:55 PM
    #511
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I had the same lean in the rear, when you crank up the coilover or in your case put a bigger spacer on the driver front, it acts diagonally to lower the rear right.
  12. Jul 31, 2015 at 9:28 PM
    #512
    ETaco23
    Evan
    PNW
    I see what you mean... but my front is really close to level. And im hoping the rear settles and evens out. Thanks guys.
    I really like the ride of the dakars and sport shocks.
  13. Aug 6, 2015 at 4:18 PM
    #513
    bpayne97
    bpayne97 Well-Known Member
    McAllen, TX
    06 TRD OR 4x4 Debadged
    URD SS Kit and TRD shift knob, rearview mirror bracket, Fox 2.0 coilovers and smooth bodies
    I just had my Dakar springs installed on my DCSB
    Day of install 25 3/4 pass and 25 1/4 driver (1/4 tank of gas).
    After a week of running around 25 1/2 pass and 25 even on driver side (full tank of gas).
    I hope they settle in a bit more. I running Fox 2.0 coil overs up front set at 2" and there is quite a bit of rake. I am going to run them up to 2 1/2" when my spanner wrench arrives and hope the alignment will hold until I can get UCA's and run them on up closer to 3".
    First impressions are great! I was worried about a rough ride but it rides so much better than it did with my worn out factory leafs. I am running fox 2.0 rear shocks as well.
  14. Aug 7, 2015 at 4:59 PM
    #514
    Firsttaco
    Firsttaco Well-Known Member
    alberta
    2009 Tacoma TRD Sport
    Bilstein 5100 all around, front set at 0 with OME 887. Light racing UCA. Dakar full pack in back. aluminum running boards. Scangauge II. Painted flat black rims. Raider canopy.
    Installed my Dakars last weekend. Went from factory 3+1 with revtech 1.5 block to full pack. I love the new ride I'm getting. Feels better at all times.
    I Didnt take measurements before because of the blocks.
    After a week and with a Raider canopy,
    DCLB
    Driver side 24 1/4
    Passanger 24 5/8
  15. Aug 8, 2015 at 3:02 PM
    #515
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Attempting to measure from center of the hub to apex of the fender (i.e. vertical) I'm showing:
    25" - Passenger Side
    25" - Driver Side
    2015 DCLB with full Dakar and OME Nitrosport Shocks - empty bed. Installed one week ago.
  16. Aug 15, 2015 at 3:49 AM
    #516
    AJC84
    AJC84 Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    2011 DCLB 4X4
    I got the following measurements on level ground, full tank, no load at about 180 miles on the lift (highway).
    Rear Driver: 24.5
    Rear Passenger: 25.25
    My stock measurements were 21.5 both sides so I got 3in on the drivers side and 3 3/4in passenger.
    Is 3/4 height variance unusual between an over spec leaf pack and and on spec leaf pack? I asked my installer to put the + leaf on the passenger side and they didn't listen. Told me there was some torque related reason to put it on the passenger. I didn't come across anything about that in my research. May ask them to swap them only because I specifically asked them to do it opposite.
    Notable that my front end is level at 23.25 with no taco lean…yet. See after it settles. I wonder if I put the trim packer up front if it will help lower the back right.
    Why OME doesn't give you matching leaf packs spec wise I don't know. Just seems odd to me...
  17. Aug 15, 2015 at 9:37 AM
    #517
    OZ-T
    Peter North
    British Columbia
    Some packs come matching some don't , usually the higher spec pack goes on the drivers side
  18. Aug 15, 2015 at 10:25 AM
    #518
    AJC84
    Andy
    How much would it even out the rear if I had + pack moved to drivers side? Again, right now my passenger with + pack is sitting 3/4in higher.
  19. Aug 15, 2015 at 10:29 AM
    #519
    OZ-T
    Peter North
    British Columbia
    The + means means it is 5mm over spec , - is 5mm under spec IIRC
  20. Aug 15, 2015 at 8:21 PM
    #520
    AJC84
    Andy
    So I guess what I am wondering is if the difference between + and - dakars is about 10mm (.40 inches) how did I end up with a 3/4 in difference between a spec (0) dakar and a +? Again shop installed the + on my passenger even though I directed them to do otherwise.
    Any hope of this settling or will both dakars settle at the same rate?
    Worth swapping + dakar over to the drivers side or having shop do it since I asked them to in the first place?
    Or should I just leave it also since I don't seem to have the dreaded taco lean up front?…at leasts not yet
