2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Oct 12, 2015 at 11:26 AM
    #561
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Just noting that your before numbers and after numbers are about 1" lower than everybody else but OK
  2. Oct 12, 2015 at 11:31 AM
    #562
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  3. Oct 13, 2015 at 10:14 PM
    #563
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I have been running Dakar leafs with the upper overload removed. The Dakars have been on the truck for 200k miles and the upper overload has been removed for 50k miles.
    After an off road trip this past weekend that involved a good deal of articulation and also a lot of miles of hard running that used full suspension travel and a bit of desert mud, I found indications that the spring clamp that retains the spring pack to the lower overload had been in contact with the frame on both drivers and passenger side during full bump. The mud made it easy to see the indications of contact. On the passenger side, it had also contacted the Icon 2.5" remote reservoir body leaving a dent that will require a rebuild with a new reservoir body.
    If the upper overload had been in place, I believe the contact could not have occurred. I plan to straighten out the spring clamps, cut off 0.5" or so from the top and drill lower holes for the retainer bolt. I believe this will address the interference. I wish I had made this modification when the Dakars were installed.
    Thought this information might be useful to others running without the upper overload on Dakars.
    lynyrd3, DoorDing and ndcmack like this.
  4. Oct 14, 2015 at 8:15 AM
    #564
    OZ-T
    Peter North
    British Columbia
    Would extending the rear bump stops help ?
  5. Oct 14, 2015 at 8:29 AM
    #565
    qnyla
    NM
    Yes, but at the expense of up-travel. I think it is better to cut off the top of the clamp a length equivalent to the thickness of the missing upper overload. That would remove interference issues and not limit up-travel of the rear suspension.
  6. Oct 14, 2015 at 9:00 AM
    #566
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  7. Oct 14, 2015 at 9:13 AM
    #567
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    just a thought though, maybe the spring clamp making contact is what prevented your shock from bottoming out. with that clamp shortened it may allow damage to the shock next time
  8. Oct 14, 2015 at 10:17 AM
    #568
    qnyla
    NM
    Maybe, but I doubt it. The spring clamp is very light construction and IMHO would just deform in any contact without carrying any appreciable load. The shock still has a rubber bumper on the lower end (hidden buried in mud) that is 0.25" or so tall, so there is still additional travel available.
    The interference here seems to result from the clamp being closer to the top of the spring pack by removing the upper overload which was 0.5" or so thick. I think the contact here (resulting from VERY hard driving over rough terrain) occurs only in the last 0.25" or so of up-travel travel.
  9. Oct 14, 2015 at 10:35 AM
    #569
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    I've noticed evidence of small impacts on both sides of mine as well. Same locations on the frame but not bad like yours. I still have all the leaves installed including both overloads. At some point I plan to add some Timbren bump stops to stop it from happening in the future.
  10. Oct 14, 2015 at 7:58 PM
    #570
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Got the average before numbers 20.5 front ..21.5 rear.. After 23 front... 24.5 rear...
  11. Oct 15, 2015 at 6:21 PM
    #571
    Captain Nemo
    Captain Nemo Well-Known Member
    20K Under the Los Angeles Sea
    '10 Access Cab TRD Off-Road
    ARB bumper w/ TJM winch, All Pro rear bumper, BudBuilt skid plates, DeMello Hybrid sliders, IPAA spotlights, Icon Stage 2 Suspension Lift Kit, 285/85/16 BF Goodrich AT, FJ TRD Trail rims, Optima dual battery w/ Wrangler solenoid, Wet Okole seat covers, BakFlip CS-F1 tonneau
    2010 TRD Off-Road AC
    Icon 2.5 adjustable coil-overs w/ OME Dakars w/ AAL
    "+" on driver side and "0" on passenger side.
    Constant weight of ~200lbs in back with All-Pro bumper, bed mat, RotoPax, Hi-Lift, and misc gear.
    Hub to Fender
    FD 22 6/8 - FP 23
    RD 24 5/8 - RP 25
    Ground to Fender
    FD 38 - FP 38
    RD 40 1/8 - RP 40 1/2
    Now I'm wondering if my Icon rear shocks are long enough and if the OME U-bolt Kit was long enough?
    (Just installed today.)
  12. Oct 15, 2015 at 6:26 PM
    #572
    Jeffvt0508
    Jeff
    Anderson, SC
    I would say that's probably what they would yield with that much weight on them .. As far as the shocks .. I'm not good at calculating the lengths
  13. Oct 17, 2015 at 12:03 PM
    #573
    qnyla
    NM
    I am getting ready to work on the suspension on a 2016 3rd Gen, icluding install of Dakar leafs. To avoid the spring retainer clamp issues I showed that can occur at full bump when the upper overload is removed, I decided to modify the Dakars for the 2016 where I also am removing the upper overload.
    To start with I cut off the excess length of the spring clamp attached to the overload. I cut the clamp right at the lower edge of the existing bolt hole.
    I then drilled new bolt holes
    and reshaped the cut off upper edge and reinstalled bolt.
    a little paint on the bare metal and the Dakar pack will be ready for install.
  14. Oct 17, 2015 at 1:48 PM
    #574
    Jeffvt0508
    Jeff
    Anderson, SC
    Dakars fit the 16s.. Thought i read where they didnt
  15. Nov 5, 2015 at 2:44 PM
    #575
    uscengnr08
    uscengnr08 New Member
    Eric
    Nomad
    2009 TRD Sport DCSB 4X4 MGM
    FX-R 3.0 Bi-Xenon retrofit, URD MAF sensor calibrator, Leer 100XQ Shell, Bedrug carpet liner, FNWheels BFD 18" + Michelin LTX AT2 285/65R18, OME Dakar, Toytec 3" coils, Bilstein 5100, Satoshi Grill mod, slotted front discs
    DCSB with camper shell, extended length rear 5100s, toytec 2.5 coils + lean spacer + 5100s up front. I let the pack settle for a month before taking these measurements.
    TOP OVERLOAD REMOVED
    driver rear: 23.75
    passenger rear: 23.75
    Also, just put the top overload back in and took out the third leaf yesterday, will run around for another week before I post measurements.
  16. Nov 5, 2015 at 2:55 PM
    #576
    OZ-T
    Peter North
    British Columbia
    Added
    Thanks
  17. Dec 8, 2015 at 3:23 AM
    #577
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    2013 AC 6MT TRD Sport /91 Toyota Truck 4x4/08 Yaris 5MT lifted
    Oz, did you happen to make a 2nd gen OME front spring hub to fender measurement thread yet?....
  18. Dec 8, 2015 at 9:10 AM
    #578
    OZ-T
    Peter North
    British Columbia
    No , I don't intend to
    Go for it
  19. Dec 18, 2015 at 10:31 PM
    #579
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Rear Passenger: 25.5"
    Rear Driver: 25"
    Full Dakar Leaf Pack 2015 DCSB no weight in the rear
    Excuse the Walmart parking lot
    DoorDing likes this.
  20. Dec 23, 2015 at 1:52 PM
    #580
    GAtaco
    GAtaco Active Member
    Villa Rica GA/Pensacola FL
    2015 MT 4x4 TRD Sport
    OME 887 and Dakars w/ 3rd removed; SPC LR UCAs
    2015 DCSB with bed toolbox
    OME Dakars with 3rd removed:
    DS: 22 3/4"
    PS: 23"
