2nd Gen OME Dakar hub to fender measurements
Discussion in 'Suspension' started by OZ-T, Aug 21, 2011.
  1. Feb 10, 2012 at 10:15 PM
    #81
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Lol
    This thread is only for rear measurements with OME Dakar leaf springs
  2. Mar 5, 2012 at 2:32 PM
    #82
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Access Cab Hub to Fender with OME Dakar and ARE Topper=24 5/8" on left rear and 25" on right rear. Installed three days ago.
  3. Mar 5, 2012 at 2:34 PM
    #83
    OZ-T
    Peter North
    British Columbia
    I'll update the OP when I get home
  4. Mar 5, 2012 at 2:47 PM
    #84
    OZ-T
    Peter North
    British Columbia
    I just picked mine up too :)
  5. Mar 5, 2012 at 9:47 PM
    #85
    OZ-T
    Peter North
    British Columbia
    Still gathering bits and pieces
    Got the OME AAL , and Defined Engineering greaseable shackles , waiting on the Toytec 1/4" spacers and the Wheelers SuperBumps
  6. Mar 5, 2012 at 9:48 PM
    #86
    OZ-T
    Peter North
    British Columbia
    OP updated
  7. Mar 20, 2012 at 4:00 PM
    #87
    AK27
    AK27 Well-Known Member
    DCLB
    Rear driver side: 25"
    Rear passenger side:25 1/4"
  8. Apr 17, 2012 at 12:47 PM
    #88
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Forgot to post this data when installed last week...
    Front Driver: 22 1/2"
    Front Passenger: 23"
    Rear (both sides): 24 1/2"
  9. Apr 17, 2012 at 12:50 PM
    #89
    OZ-T
    Peter North
    British Columbia
    FYI , I don't care about front measurements , just Dakar measurements
    Thanks for the input , I'll update the OP when I get home .
  10. Apr 21, 2012 at 8:53 PM
    #90
    Shep
    Shep Active Member
    Clearwater, FL
    2011 Prerunner DCSB TRD Sport
    Leer Topper, OEM roof racks, OEM Bed divider, Scan Guage II, TRD cold air intake, OME 3" lift 885s and 1/2" spacer with Dakar leaf packs and LR UCAs, NFab steps
    2011 DCSB with Leer topper.
    Left rear - 24
    Right rear 24 1/4
    Just put it on. I'll update you if it changes after it's broken in.
  11. Apr 26, 2012 at 6:14 AM
    #91
    PICKSTACOMA
    PICKSTACOMA Well-Known Member
    Landon
    Penhook, Virginia
    06 Tacoma 4x4 dbl cab lb 4.0
    ARE MX Truck Cap, Flowmaster American Thunder Exhaust, K&N Cold Air Intake, Weather Tech( Digital Floor Mats,Bug And Side Window Deflectors), Scangauge II, Clearvision Solux Headlight/Foglight Bulbs, Redline Hood Struts, FJ Cruiser Foglight Switch, Illuminated 4x4 Switch, Rain X Latitude Wipers, Brighter Back Up Lights, Dome/Map LED's, Cup Holder LED's, Engine Bay Lights, Foglights On Anytime, Leather Seats With Front Heating Pads OME Lift With DAKAR Springs And LR UCA's, Rear Diff Breather Mod, A/C Drain Mod, Husky Mud Flaps, ECGS Bushing Kit
    2006 DCLB w/ A.R.E topper
    24 1/4 L&R
  12. Apr 26, 2012 at 6:06 PM
    #92
    OZ-T
    Peter North
    British Columbia
    OP updated
  13. May 8, 2012 at 6:32 AM
    #93
    ACE_Taco
    ACE_Taco Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    2008 DCSB Full OME setup w/Dakars. Installed April 2010...
    Rear Driver = 24-3/4"
    Rear Passenger = 25-1/8"
  14. May 8, 2012 at 7:28 AM
    #94
    OZ-T
    Peter North
    British Columbia
    Did your Dakars have an " + " or " - " marking on them ?
  15. May 8, 2012 at 9:21 AM
    #95
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Good question Oz....Not sure... WIll check when I get home. What do the - and + markings represent?
  16. May 8, 2012 at 9:32 AM
    #96
    OZ-T
    Peter North
    British Columbia
    " + " is a spring with a slightly higher arch than OME spec
    " - " is a spring with a slightly lower arch than spec
    Just wondering about the 3/8" side to side difference in your heights
    Do you have a front driver's side trim packet for taco lean or equivalent ?
    Were you on flat ground when you measured ?
  17. May 8, 2012 at 9:35 AM
    #97
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Yes. I used the 1/4" top spacer from Toytec. My front measurements are
    DS= 23-1/8"
    PS= 23-3/8"
  18. May 8, 2012 at 9:39 AM
    #98
    OZ-T
    Peter North
    British Columbia
    You have OME front shocks ?
  19. May 8, 2012 at 10:16 AM
    #99
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    yes I do. BTW, I just spoke to Scott at ARB. He mentioned that the gen2 Taco does not have side specific Dakars. He also stated that the - & + markings are not to differentiate pass or driver side, but are markings used in mfg notating tolerance measurements.
    Additionally, he said that I could add an OME trim packer to the driver's side strut, which would bring the opposite side of the rear down. Before getting to invasive, I am going to add weight to the passenger side in the bed. It could be that it may not be broken in like the driver's side.
    Pportera likes this.
  20. May 8, 2012 at 10:40 AM
    #100
    OZ-T
    Peter North
    British Columbia
    That's exactly what I just said , and yes , you're supposed to use the OME trim packer with OME shocks for taco lean , which is why I asked
