2nd Gen OR Second Battery Mount
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Iggy, Feb 29, 2016.
  1. Jan 1, 2020 at 12:09 PM
    #301
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I thought I had an old video but I can't find it. Everything looks great, those bolts just need to be trimmed flat with the top plate. They still serve a purpose in the hole to help keep the tray from moving laterally. Everything else looks good!
    Edit: The second mounting bolt is backwards too. flip it so the threads are facing up and the lock nut will keep it in place.
    Sacrifice likes this.
  2. Sep 14, 2020 at 11:16 AM
    #302
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Did you ever go this route? I was thinking the same thing. I don’t need dual batteries but this seems like a great way to take the weight off the core support while keeping the battery under the hood.
  3. Sep 14, 2020 at 4:27 PM
    #303
    ZeroExOne
    ZeroExOne Well-Known Member
    2020 Tacoma Off Road Cement
    Maybe I missed the post, were these ever tested to fit a 3rd Gen OR? I'm interested in it. I won't be putting a Bussman there though, was planning on putting a solar controller.
  4. Oct 3, 2020 at 6:48 PM
    #304
    inthebed
    inthebed Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    Hey guys, which cooper bussmann rtmr fits these? I'm assuming 15303-2-2-4
    Also which 80 amp breakers fit these?
    Specific part numbers would be awesome. I'm a little confused by the links posted by iggy, I already bought one breaker only to have it not fit.
  5. Jan 3, 2021 at 12:06 PM
    #305
    Explore_scenic
    Explore_scenic New Member
    David
    2020 Tacoma DCLB
    Prinsu Rack, Decked Drawer System, Canper Shell, Frame sliders
    @Iggy Do you have this set-up available for the 2020 OR? I would like to do something similar with group 27 size batteries.
  6. Jan 3, 2021 at 2:48 PM
    #306
    Iggy
    Northern CA
    Check out the build
    No these only work for a few specific 2nd Gen models to get a group 27 vs a smaller group 34. If you’re ok with a 34 Off-Grid Engineering makes a good kit.
  7. Jan 3, 2021 at 3:28 PM
    #307
    Explore_scenic
    David
    2020 Tacoma DCLB
    Thanks for the quick response and suggestion!
  8. Apr 22, 2021 at 8:23 AM
    #308
    JMP-SLC
    JMP-SLC Active Member
    2010 Gen2 Taco Access Cab 4.0L TRD-OR
    Has anybody been able to figure out a solution where two batteries are located on the passenger side? I'm wondering if it's possible to shoehorn two in there somehow, perhaps using a different group size with different geometry? I want to do this to move more weight to the passenger side. I wheel solo a lot and so without a passenger and the heavy awning I have on the driver side along with the battery, my truck leans to the left more than I like. Hoping that I can move the OEM battery to the other side somehow.
  9. Dec 30, 2024 at 3:36 PM
    #309
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    Hello Iggy,
    is this system still available and are you still in NorCal? Thanks. Scott.
  10. Dec 30, 2024 at 7:35 PM
    #310
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I havent seen Iggy on here in a awhile. Ill ping him on social media to see if he's alive
    Steves104x4 likes this.
  11. Dec 31, 2024 at 8:08 AM
    #311
    bootboiler
    Scott
    Santa Cruz
    cool thanks. His main website is neglected as well.
