2nd gen over heating
Discussion in 'New Members' started by Mrmister29, Sep 7, 2024.
  1. Sep 7, 2024 at 8:59 AM
    Mrmister29
    Mrmister29 [OP] New Member
    Case
    2013 tacoma
    Hey folks, 2013 tacoma. 265k miles.
    Recently did a radiator flush. Replaced thermostat. The truck over heats only if I've been in the freeway. I can drive around town all day and it's fine. When I get off the freeway it will go straight to over heating. Is it just an old water pump that needs replacing? Suggestions or ideas?
    buckhuntin-tacoma likes this.
  2. Sep 7, 2024 at 9:10 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    was it overheating before the flush
  3. Sep 7, 2024 at 10:00 AM
    Mrmister29
    Case
    2013 tacoma
    It did once, yes. Ran the engine pretty hard. That's what lead to the flush and thermostat replacement
  4. Sep 7, 2024 at 11:14 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    and how did the old coolant look
    have you tried cleaning the outside of the radiator
    in the end it is probably the water pump
  5. Sep 7, 2024 at 1:46 PM
    545 Well-Known Member
    2015 Access Cab
    How is your fan clutch?
    ridefreak and buckhuntin-tacoma like this.
  6. Sep 7, 2024 at 1:51 PM
    El Reymono
    El Reymono Well-Known Member
    Raymond
    East Providence, Rhode Island
    2010 2.7 regular cab manual Tacoma
    first and easiest thing to do is check your radiator cap. they can corrode but it's a seldom checked part.
  7. Sep 7, 2024 at 1:57 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    fan clutch would be opposite, plenty of air at freeway speed but not enough in stop and go
  8. Sep 7, 2024 at 2:36 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Kolter45 and Mrmister29[OP] like this.
  9. Sep 7, 2024 at 6:00 PM
    Mrmister29
    Case
    2013 tacoma
    Yeah outside of the radiator is fairly clean. Cap was clean, too. Old coolant came out surprisingly clean.
    One additional symptom is that the truck has a high pitched whistle while under load. For example, pedal to the floor while getting on the freeway.
    I'm thinking water pump too. Perhaps the impeller is worn..
  10. Sep 8, 2024 at 5:18 PM
    2015 Access Cab
    He says it overheats when getting off the highway
  11. Sep 8, 2024 at 5:20 PM
    2015 Access Cab
    I’d really look at or replace your fan clutch
    It’s sounds like it’s staying “unlocked” after sustained higher rpm
    What engine?
  12. Sep 8, 2024 at 8:50 PM
    Mrmister29
    Case
    2013 tacoma
    It's a 4 cylinder 2TR-FE engine. I'm the original owner. This truck has been great till recent
  13. Sep 8, 2024 at 8:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Basically all that is left is checking fan clutch and radiator.
    Wash the ever living crap out of the radiator, lots of mud can get trapped between it and the condenser.
    If you have a light bar or winch anything blocking the rad it can cause issues.
    The water pump is super unlikely, they are metal and dont fail like the plastic ones do.
    Once the fan and rad are confirmed it leaves headgasket failure which is hard to pinpoint.
  14. Sep 12, 2024 at 8:46 PM
    Mrmister29
    Case
    2013 tacoma
    Yeah I'll check out that fan and clutch and make sure those parts are good. I did do a compression test last week. Each cylinder was a consistent 120psi. Did it wet too and each cylinder went up about 20psi. So hoping the head gasket is good
  15. Sep 12, 2024 at 9:15 PM
    Bishop84
    Headgaskets usually dont show in compression tests unless its super fooked. I rarely use my compression gauge set anymore.
    The gasket lets combustion into the coolant and the engine rapidly overheats. Usually happens when there's rapid temp changes, or under load. So its hard to check.
    RustyGreen likes this.
  16. Sep 24, 2024 at 3:25 PM
    Mrmister29
    Case
    2013 tacoma
    So I check the fan clutch. After driving for about 20 min, once parked, the truck over heated. I turned off the engine and checked the fan . It moves pretty freely in either direction with little to no resistance. From what I can find online, the clutch may be worn. Sound about right?
