2nd gen Parking brake grabs uneven
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ubnpast, May 9, 2015.
  1. May 9, 2015 at 2:42 PM
    ubnpast
    ubnpast [OP] Well-Known Member
    Central Jersey
    Had my shoes squeek when letting off the brakes, I greased the back plate contact points for the shoes.
    The parking brake grabbed fine before, the problem was when I test fit the drum on the drivers side (without the 2 retaining pins/clips), I pulled the drum off and the shoes were stuck in the drums pretty good. Managed to get it off and reinstall. Did both sides but the parking brake now seems to mostly grab the passenger wheel. I tightened up the drivers star adjuster 10 clicks and tested the parking brake, the passenger side seems to lockup faster when driving. I then backed off the star adjuster 10 clicks. I've watched the shoes expand when I had someone use he parking brake, it seems as if the front shoe is the one that moved.
  2. May 10, 2015 at 8:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The correct way to adjust the brake shoes on the rear is to tighten the star adjuster until the wheel locks. Then back it off 18 clicks. Do this on both sides and they will be balanced.
    As per the service manual.
  3. May 10, 2015 at 8:37 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Please be sure that you did not move / bend / replace any parts under the drum / parking brake when you had the drums off and / or sticking / pulling on the drums to get them off the shoes. IF you still have issues I suggest a re check.
    Also, be careful of any grease/lube in the brake area. Besides the obvious issues with grease migrating to the shoes, any thing that can grab and hold the break dust / drum iron filings will be sure to goop up the brakes in short order ....
    Good luck and let us know if you do find anything ....
  4. Jun 9, 2015 at 9:54 AM
    ubnpast
    Central Jersey
    I didn't have much time to check, I did pull the drum off again everything looks normal and functional. Not sure what else I can check, is it possible a cable stretched?
    Why when I tighten the drivers side shoes does it seem as if the passenger side also seems to lockup sooner when testing the parking brake?
