2nd gen parking brake questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StreetTaco05, Aug 1, 2017.
  1. May 14, 2020 at 6:38 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’m dealing with this exact thing right now.
  2. May 14, 2020 at 7:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    15 clicks sounds like a lot. How I’ve done it is to adjust the star until I can just barely get the drum over the shoes, then adjust the cable slack from there.
    Alexely999[QUOTED] likes this.
  3. May 14, 2020 at 8:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The 15 clicks comes straight from the service manual.
  4. May 14, 2020 at 8:52 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I don't doubt that. But I always find those self adjusters just never seem to work right. I'd rather have the rear shoe drag a little in the beginning then to not have a good parking brake, especially with a manual transmission. I'm not saying that what I'm doing is correct, but I've found it gives a better parking brake performance (with the downside of a shorter rear shoe life). My truck is going on 10 years old and only has 55k, I've been through one set of shoes so for me it's worth it. I do the same thing with any vehicle that has the ebrake like this, or the ebrake shoes with rear disc brakes like my Chrysler 10.5 axle in the ford.
    Jimmyh[QUOTED] likes this.
  5. May 14, 2020 at 9:07 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    So might not match the toyota FSM, but here is what the Ford FSM states for how to adjust the brakes
    1. Raise and support the vehicle.
    2. Remove the wheel and tire assembly.
    3. Remove the brake adjusting hole cover from the backing plate.
    4. Turn the brake adjuster screw (2041) to expand the parking brake shoe and linings until they drag against the drum-in-hat rotor.
    5. Back off the brake adjuster screw until no drag is evident.
    This is how i've always done it, never counted the number of clicks. I've adjusted it until you can just barely get the drum on and then try to spin it. move as many clicks as needed until the drum no longer drags on the shoes.
    Jimmyh likes this.
  6. May 15, 2020 at 6:59 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Im going to try both ways. I always try to follow the FSM as close as possible. Right now my braking and my pedal feel normal.
    But my emergency brake will hold me from going in reverse, but not from going forward. So I know it’s trying to stop the truck but it’s just not enough.
  7. May 15, 2020 at 6:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Try this also:
    Toyota Field Service Manual for the Parking Brake Cable adjustment under the shift lever center console:
    ADJUST PARKING BRAKE PEDAL TRAVEL (for Automatic Transmission)
    (a) Confirm that the parking brake pedal is released.
    (b) Loosen the lock nut A and turn the adjusting nut B until the parking brake pedal travel is corrected to the specified value.
    (c) Tighten the lock nut. Torque: 13 N*m (127 kgf*cm, 9 ft.*lbf)
    (d) Check whether the parking brake drags or not.
    (e) When operating the parking brake pedal, check that the parking brake pedal indicator light comes on.
    ADJUST PARKING BRAKE LEVER TRAVEL (for Manual Transmission)
    (a) Confirm that the parking brake lever is released.
    (b) Loosen the lock nut A and turn the adjusting nut B until the parking brake lever travel is corrected to the specified value.
    (e) When operating the parking brake lever, check that the parking brake lever indicator light comes on.
    JGO and Alexely999[QUOTED] like this.
