2nd gen plug and play remote start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vicasey, Jan 24, 2019.
  1. Oct 4, 2020 at 4:33 PM
    #321
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    Thanks for the info @Accessorides I’m debating between kits for my 2010 with the Dot key currently so glad to see you all replied. I will keep an eye or for any specials on the 2way remote kit
  2. Oct 5, 2020 at 11:22 AM
    #322
    cee_gee_ess
    cee_gee_ess Member
    2010 Pyrite Mica TRD Sport Double Cab 4wd
    It will be tomorrow when I call. I have to hunt down order number, etc. Thanks for the response. FWIW, I have the Dot key 2010. I say that just to state it took me forever to figure out it was an actual dot, like a period or point, rather than DOT like Dept of Transportation. :homer::facepalm:
  3. Oct 5, 2020 at 11:32 AM
    #323
    cgs2k2
    cgs2k2 old man
    From what distance do these remotes work? The parking lot at my job is about 100 yards away from the entrance / my desk.
    *edit* I know the kit says 1000 / 2000 feet - but can people confirm this?
  4. Oct 5, 2020 at 12:06 PM
    #324
    GRNT4R
    NC - Triad
    TBD
    LOL--Nothing wrong with that. things are often lost in translation on here as I have the DOT as well
  5. Oct 15, 2020 at 6:02 AM
    #325
    Zerofrigs
    Zerofrigs New Member
    I’ve got a 2015 Tacoma G-key, I recently got a fortin evo and the t-harness. I followed their wiring diagram and Had the problem with truck cranking but not running. I enabled option 20.2 (tac less signal) with the fortin data link. Programmed the evo unit did not connect the can bus lines (grey wire and grey and black wire) and the truck started up and ran perfectly. Hopefully this helps if someone is having issues with the fortin kit.
  6. Oct 16, 2020 at 10:51 AM
    #326
    tbraumb11
    tbraumb11 Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    is there any issue with the accessorides working with aftermarket head unit and maestro units seeing this uses the OBD ports? I think I read there isnt here but wanted to make sure before I pull the plug.
    also what are most people running the 1 way or 2 way remote, not really sure if the 2 way is worth the extra money...
  7. Oct 16, 2020 at 11:00 AM
    #327
    TeXanTRD
    TeXanTRD Well-Known Member
    2013 TX TRD
    I have the 12V kit, but I’d imagine they function similarly regarding the ODB port. I have no problems with my head unit that reads out of the ODB port with the remote start installed.
    2-way is worth it for sure. Doesn’t matter so much in your driveway where you can visually see the vehicle starting. It does become useful when you’re in a store/building and don’t have line of sight to the vehicle. That feedback that your vehicle started is nice.
    Not sure about the Accessorides, but with my 12V the factory beeping that the truck does is disabled. Another argument for the 2-way is that you get feedback to confirm your vehicle locked/unlocked.
    tbraumb11[QUOTED] likes this.
  8. Oct 17, 2020 at 12:47 PM
    #328
    DJSpeed
    DJSpeed Well-Known Member
    remote start wont work when i have my maestro unit piggybacked on the harness of the accesorides
  9. Oct 17, 2020 at 9:47 PM
    #329
    Timinatorx92
    Timinatorx92 Well-Known Member
    2006 Black Tacoma AC TRD Offroad
    3" toytec lift Method 16x8 Grid Coopers at3 xlt 295/75/16
    man, winter is approaching and i don't know what to do. My 12 volt solution remote start worked perfectly for one season. but now, out of the blue, it just doesn't crank the truck anymore... when i try to start it with the remote or app, the light on the dash will come on but it won't crank the truck. the door lock/unlock function works fine. if i manually start the truck, i can still use the function to leave it running and take the keys out. thats about it.
  10. Oct 17, 2020 at 9:59 PM
    #330
    TeXanTRD
    2013 TX TRD
    That’s scary to hear. Have you hit up their support yet?
  11. Oct 18, 2020 at 2:38 AM
    #331
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Could be the reciever/antenna...try unplugging it, leave it for a mins and plug back in again.
  12. Oct 18, 2020 at 10:39 AM
    #332
    GRNT4R
    NC - Triad
    TBD
    Hopefully they will reply with a solution.
  13. Oct 18, 2020 at 11:44 AM
    #333
    tbraumb11
    nanaimo
    what are those?
    can you explain what you mean by this? sorry.
  14. Oct 18, 2020 at 12:47 PM
    #334
    DJSpeed
    When both the alarm and maestro are plugged into the one port
  15. Oct 19, 2020 at 1:25 PM
    #335
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Time to order. @12voltSolutions https://www.12volt.solutions/collections/remote-start
    First snow if the year yesterday, with more today. Ordering 12 Volt Solutions now.
    15% off. $10 flat rate Shipping. $307.50 total (includes Long Range 2-way remotes). Ordered 1 minute before their 3:30 PM deadline. Just received my shipping notice. Impressive.
  16. Oct 22, 2020 at 6:52 PM
    #336
    JimIowa
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    Where did you mount the long range antenna unit? On the windshield or inside the A pillar? Thanks.
  17. Oct 23, 2020 at 6:43 AM
    #337
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    I mounted the long range at the top up the A-pillar after I removed the trim. I can see it blink thru the plastic at the top of the windshield at night.
  18. Oct 23, 2020 at 7:20 AM
    #338
    JimIowa
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    Great. Thanks for responding here. Do you see any issues with range? I don't need 1 mile, but I do want transmission through buildings and maybe 500 feet. I appreciate your help here. The remote kit arrives today. Can't wait to install.
  19. Oct 23, 2020 at 7:32 AM
    #339
    jbaker1976
    East TN
    2015 DCSB OR
    I wasn't concerned much about range either. I did think the range would be longer than it is. I can totally live with it, just thought it would be farther. I do like the 2 way remote feedback to let me know if it started. I have been using the heck outta the pitstop feature.
    GRNT4R and JimIowa[QUOTED] like this.
  20. Oct 23, 2020 at 8:28 AM
    #340
    TegoTaco
    Ontario, Canada
    I put mine on the windshield, top left obviously...really love the range of the remote, sometimes it impresses me lol!
    JimIowa[QUOTED] likes this.
