2nd Gen Power Steering Fluid Recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajaracer, Jun 12, 2011.
  1. Jun 12, 2011 at 10:44 AM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Ive recently noticed my power steering fluid is a bit on the low side. The manuel and cap on the reservoir calls for Dexron type ATF. My question is, What type of fluid are you guys using on your Taco? So many options available I dont want to add some crappy fluid that could mess things up. Also, have any of you ever drain/replaced your power steering fluid? Was it hard to do? Thanks guys.
  2. Jun 12, 2011 at 12:22 PM
    bajaracer
    Charly
    Chandler
    Bump...
  3. Jun 12, 2011 at 12:51 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    repclace fluid.YES..........take a turkey baster and suck out all the old fluid and replace with whatever you decide. i also do this with my brake master about once a year.
    O'DubhGhaill likes this.
  4. Jun 12, 2011 at 2:32 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I changed mine out to mobil 1 ATF when I installed the magnefine @ 20k miles. At almost 47k it's still looking good, no issues to report.
  5. Jun 12, 2011 at 2:44 PM
    MassTaco
    Massachusetts
    V6 4x4 SR5 DC AT5
    Also, I use the following method for a change:
    1) Suck out the fluid in the reservoir (turkey baster or other fluid pump)
    2) Disconnect the return line to the reservoir (it's the one that's higher on the reservoir, feeding into the side)
    3) Close off the return line hose barb on the reservoir, then top it off with the new ATF of your choice.
    4) Jack up the front wheels
    5) With the engine off! - place a container under the return line, then rotate the steering wheel from one side to the other, each full cycle will force about 8-10 ounces of fluid out, so be sure you have a big enough container.
    6) Repeat the top off / steering cycle until you have new clean fluid coming out of the return line, and the level of the reservoir is BELOW the return line input.
    7) Reconnect the return line - still with the engine off, top off the reservoir, then cycle the steering, top off the reservoir, cycle the steering .... do this until the level is correct.
    8) Let the vehicle down off the jack, double-check all of your hose connections then start it up.
    9) With the engine running cycle the steering a couple more times then shut it down.
    10) re-check the level in the reservoir and top up if necessary.
    11) You're done!
  6. Jun 12, 2011 at 11:22 PM
    bajaracer
    Charly
    Chandler
    Would the Toyota type 4 ATF work?
  7. Jun 13, 2011 at 12:54 PM
    MassTaco
    Massachusetts
    V6 4x4 SR5 DC AT5
    I would think that would be fine if that's what you have laying around.
  8. Jun 13, 2011 at 8:24 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    There's a "how to flush your powersteering fluid" around here somewhere. I used some extra AMSoil synthetic ATF that I had. Toyota T-IV and Dextron II/III are compatible, at least in transmission applications, not 100% sure about in PS applications.
  9. Jun 13, 2011 at 9:04 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Doesn't anyone rtfm anymore?
    igno1tus and Lester Lugnut like this.
  10. Jun 13, 2011 at 9:47 PM
    bajaracer
    Charly
    Chandler
    True true, If they Toyota T IV and Dextron III/IV are compatible then they should it should be fine in the power steering system,,, I hope. (Anyone ever try this)? And yes i saw the PS flush thread....Thanks.
  11. Dec 14, 2012 at 11:33 AM
    Ocean's
    Ocean's Well-Known Member
    MassTaco: That was a great Write up as I just completed my Power Steering Fluid Change on my 2008 2nd Gen Tacoma TRD Off Road.
    I would like to add to your write up the following:
    1. The Turkey Baster head was not long enough so I had to add a piece of 1/4" inside Dia x 4" long clear tubing to reach the bottom of the reservoir. (It was too tight to fit so a few seconds above the stove fire made it pliable for it to fit over turkey baster head.)
    2. I used a 1/2" Rubber Cap I got at NAPA Auto Parts to close the return line hose barb on the reservoir.
    3. I used a 2 liter plastic soda bottle for the ruturn line, and it fit perfectly standing straight up on the Tacoma's frame right next to Power Steering Reservoir.
    4. I bought 2 Quarts of ATF DEXRON lll, and I used 1 full Quart of Dexron lll to do entire fluid exchange.
    If you think any of the added info is worth adding to your Directions, take what you want and included it into a new sticky...
    Pzzzzz from Cali'
    CowboyTaco and lynyrd3 like this.
  12. Dec 14, 2012 at 12:44 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    used mobil 1 ATF in mine and it has been good the last 30k miles or so
    lynyrd3 likes this.
  13. Dec 14, 2012 at 1:08 PM
    Madmax702
    Madmax702 Well-Known Member
    Las Vegas, NV
    2020 Tacoma OR
    yea i did Mobil 1 synthetic ATF in my WRX about every 25-30k! about $10 a bottle. you should be fine with 1 bottle unless you do a complete flush and fill
  14. Jan 6, 2013 at 2:22 PM
    cwagly
    cwagly Active Member
    I read through most of this thread and did go through some others and I may have missed it but I have a question....so this may have been asked for the 07 Tacomas, the Power steering fluid in mine is amber or yellow and the Toyota Parts dealer sold me red ATF DEXRON lll fluid. Dealer said its ok to top up and mix them. The red is only a dye and he thinks the amber or yellow is the fluid used in Japan. So, is it wise to mix it or just change it all together? I can't see it hurting anything. Maybe I am wrong but just like to be sure.
  15. Jan 6, 2013 at 2:36 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I had an 84 Corolla diesel and the reservoir called for ATF. I got some Casterol ATF and replaced it. Within two days I could hardly turn the wheel. I went to K-Mart and bought the cheapest crap power steering fluid on the shelf. Replaced the fluid again and 5 minutes later was back in business.
  16. Dec 27, 2016 at 1:57 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I need to do this
  17. Dec 27, 2016 at 2:13 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use the turkey baster method once a year. I use Dextron III ATF I got from Wallys World
  18. Dec 27, 2016 at 8:58 PM
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    On my 97 4runner I changed it ONCE in 250k miles before I sold it. I used the cheap stuff from malwart. Same thing on my 2005 325xi. My BMW doesn't like synthetic
    ATF for some reason. Turkey baster over multiple weeks with no work at all.
  19. Dec 28, 2016 at 1:07 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I used Max life because I had a extra quart after servicing the transmission. The steering actually felt smoother after that, which was when my truck had 50k miles.
  20. Nov 21, 2017 at 7:32 AM
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    MY taco is leaking power steering fluid from the return line..Anyone replaced this themselves the stealership want a few hundred to replace it any input would be GREAT
