2nd Gen Power Steering Fluid Recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajaracer, Jun 12, 2011.
  1. Nov 21, 2017 at 7:35 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    BG power steering fluid in mine
  2. Nov 21, 2017 at 7:40 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I use Lucas oil power steering fluid with sealer. It stopped a minor seal leak in my 08 Taco.
    Fiesta346 likes this.
  3. Nov 21, 2017 at 7:45 AM
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    Thanks man my leak is also very minor I may give your method a shot instead of paying the stealership a few $100..They confirmed it was the return line but could not confirm seal or actual line.
    NAAC3TACO[QUOTED] likes this.
  4. Nov 21, 2017 at 8:20 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    This issue has come up many times here and on other Toyota forums.
    Toyota owners manual say to use Dex_II or Dex-III; Dex-II is gone, BUT to many, the fluid that comes in the vehicle is colored the same way as traditional power steering fluid, so some of them use regular P/S fluid. Research indicates Toyota buys uncolored Dex-III in bulk to save a few pennies(has no dye in it).
    For what it's worth, I have gone both ways in the Toyota's I've owned/own. I see no difference in performance using either Dex-II or traditional power steering fluid. I called all of the local Toyota dealership parts depts. in my area a year or so ago and asked what they use in the shop. All said that traditional power steering fluid was used.
    So...to my way of thinking, you can use either Dex-III or traditional power steering fluid. If switching from Dex-III to P/S, I would do a complete flush first. Just my 2 cents.
  5. Nov 21, 2017 at 8:30 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    If it’s the seal, it may work, but if it’s the line it will need to be replaced. My leak was at the rack leaking into the boot.
    lowtidejoe likes this.
  6. Nov 22, 2017 at 5:42 AM
    Fiesta346
    PA
    Can anyone confirm the power steering return line is 3/8 diameter?
  7. Nov 22, 2017 at 9:54 AM
    Lester Lugnut
  8. Aug 17, 2020 at 3:09 PM
    sco
    sco Member
    2002 tacoma 4wd dc trd
    none
    Just to put some numbers on this, I used the turkey baster drain and fill route on my 2001 DC 3.4L. Fluid looked worse than the picture at the top of this thread, was the original clear Toyota fluid with about 160K on it. Pull out 125ml, replace with new red DexMerc Dextron III ATF, repeat. Each time i started the truck and moved wheel from rack to rack twice. Mixing seemed very effective and the cloudiness decreased every drain. Took 16 drain/fills to get fluid clear enough to see the bottom of my plastic measuring cup. Was still a little cloudier than the fresh stuff. Still thats about half a gallon of fluid or about $8, plus the time, maybe an hour.
  9. Oct 1, 2020 at 6:58 AM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Hmm. My power steering fluid is damn near black... And probably 100k miles on it. Think it's time?
    Haha.
    I'm thinking about doing the turkey baster method for my power steering fluid AND brake fluid master. Obviously a full flush would be better but a little refresher won't hurt, right?
    O'DubhGhaill likes this.
  10. Oct 1, 2020 at 7:16 AM
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    I bought a couple of boxes of Dex -III bottles (plastic) from Malwart a very long time ago. Still good and still haven't used it up yet. Turkey baster method works fine. I change the fluid everytime I change the oil.
    xguntherc likes this.
  11. Oct 1, 2020 at 4:27 PM
    Lester Lugnut
    Your avatar indicates you have a Tundra - not a Tacoma.
    Go to -> www.rockauto.com
    Provide your year/make/model/engine and look up -> power steering return line.
    You might also be able to simply replace the hose on the return line and install new clamps.
  12. Oct 2, 2020 at 5:31 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I just had mine drained and filled with Valoline max life atf fluid , working great ! I had a slight leak before and this stopped it
  13. Oct 6, 2020 at 8:36 AM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    Do you guys use the turkey baster method for quickly swapping your brake fluid also? Or just the power steering
  14. Oct 6, 2020 at 9:28 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I did, just suck it out, refill with new, and use a plastic 32 oz container with clear hose to finish pumping out the old fluid in the lines as you keep topping off.
    xguntherc[QUOTED] likes this.
  15. Jul 23, 2022 at 8:18 AM
    #35
    dwilliams81
    dwilliams81 Well-Known Member
    2012 2.7L Tacoma 4x4
  16. Jul 23, 2022 at 8:46 AM
    #36
    NAAC3TACO
    2014 SR5 DCLB 4x4
    That should work fine
  17. Aug 24, 2023 at 10:47 PM
    #37
    TacoTuesday1
    SD CA
    used syn Mobil 1 ATF since I got it.
    Anyone notice it's disappeared off the shelves?
  18. Aug 25, 2023 at 1:56 PM
    #38
    RCast436
    RCast436 Active Member
    Rip
    SoCal
    06 Tacoma Access Cab 4WD TRD Offroad
    I would use actual power steering fluid rather than ATF. Advice from an actual Toyota technician. You can buy from Toyota dealer but you have to specifically ask for it. Otherwise, guy at the counter will give you ATF. I’ve used that and also Lucas power steering fluid. Never had any issues.
  19. Aug 25, 2023 at 3:34 PM
    #39
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Spec is Dex-III, use something compatible. Flushing is easy and cheap, do it when you service the diffs or more often and things stay happy. PS fluid is probably fine but depending what you read it might attack the seals; K.I.S.S. method says why risk it unless you think chasing leaks is fun? It ain’t rocket surgery. o_O
  20. Aug 25, 2023 at 8:00 PM
    #40
    TacoTuesday1
    SD CA
    Already flushed it along time ago.
    Picked up a quart of red container Valvoline maxlife ATF dexron2/3 to refill when I replace the return line and add my magnefine filter while I’m in there.
    Since nobody seems to carry the M1 syn ATF I used before
    rack has a slow leak from the ends but I think it’s an age and miles thing.
    on German cars I’m used to using Pentosin CHF202 but don’t know if that’d work in a Tacoma.
