2nd Gen RCD/Bilstein 5100 Shocks
Discussion in 'Downsouth Motorsports' started by Downsouth Motorsports, Jan 27, 2012.
  1. Mar 24, 2013 at 6:10 AM
    #201
    applebmw
    applebmw Active Member
    Lonnie
    Greenville, Ohio
    09 PreRunner
    I have 09 CrewCab....without the three leafs in rear, I set my 5100 on first setting .85 I think, the truck ended up level. If you go with second setting, your front end will be higher,,,,,,,bought a camper shell, set on the truck, and front is about 1/2 inch higher than rear.....this is on first setting....FYI
  2. Mar 26, 2013 at 10:26 AM
    #202
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Mission Valley, San Diego
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 285 x 70 x 17 Toyo Tires on 17" x 8" ICON Wheels
    Okeetee, I agree with ChamYota.. Any time you change a suspension component I would recommend getting an alignment.
    Micah
  3. Mar 27, 2013 at 6:59 AM
    #203
    NinjaT1985
    NinjaT1985 Well-Known Member
    '17 Tacoma
    links from first post do not work...
  4. Mar 27, 2013 at 7:02 AM
    #204
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
  5. Mar 27, 2013 at 7:27 AM
    #205
    NinjaT1985
    '17 Tacoma
  6. Mar 27, 2013 at 7:47 AM
    #206
    Toyotacrawler
    Cusseta/Opelika AL
    You're welcome! :thumbsup:
  7. Mar 27, 2013 at 8:19 AM
    #207
  8. Mar 27, 2013 at 8:26 AM
    #208
    NinjaT1985
    '17 Tacoma
    Do you guys sell a 2" rear block kit by chance?
  9. Mar 27, 2013 at 8:45 AM
    #209
    bzzr2
    bzzr2 Well-Known Member
  10. Mar 28, 2013 at 10:21 AM
    #210
    We offer a 1" from ICON. Its 155.$ plus shipping
    Micah
  11. Mar 28, 2013 at 10:39 AM
    #211
    Sure do:D
    Rear shock Part #24-214667 will work with a 2" or 2.5".
    Bilstein 5125 series 24-214667 Dimensions:Note(90 day warranty on 5125 series from original date of purchase)
    Valving: 170/60
    Extended Length: 25.98"
    Collapsed Length: 16.14"
    Micah
  12. Apr 2, 2013 at 12:19 PM
    #212
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    i have a 06 double cab prerunner and im looking to pull the trigger on the 5100's for $309 is there anything else i need to buy to install them?
  13. Apr 2, 2013 at 12:50 PM
    #213
    PM sent
  14. Apr 2, 2013 at 5:22 PM
    #214
    sstauffer7
    sstauffer7 Active Member
    Mesa, Arizona
    06 PreRunner SR5
    I'm in the same boat as 1nonlygarcia. I want to buy all 4 shocks and install them. What else do I need?
  15. Apr 3, 2013 at 7:32 AM
    #215
    This kit is straight forward, you do not need any other parts. You will need a wall mounted spring compressor in order to remove the coils off the stock strut assembly, then insert the new 5100. Or have a shop that has the equipment and has this tool do it for you, other than that, it is 3 bolts on top of the strut and on at the bottom. As far as parts, you are good to go with just the 4 shocks. Set the fronts at the desired lift height you are looking to obtain and install the rears.
    Any other question please let me know.:typing:
    Micah
  16. Apr 5, 2013 at 7:04 PM
    #216
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Came home last night from LA..and guess what it was yes my 5100's and i just ordered them on tuesday. thanks Micah
  17. Apr 9, 2013 at 6:33 AM
    #217
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Can I has the working link for all 4 5100s?.....and not the extended rear 5100s.
  18. Apr 9, 2013 at 6:36 AM
    #218
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  19. Apr 9, 2013 at 6:43 AM
    #219
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  20. Apr 9, 2013 at 6:59 AM
    #220
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I know there is sometimes the slightly more expensive "bilstien 5100s".......and slightly cheaper "rcd bilstien 5100s"......but other than that, there isn't a discount I know of.
    Dsm doesn't offer a discount anymore, explained in this thread
    http://www.tacomaworld.com/forum/do...9702-dsm-no-longer-offering-coupon-codes.html
