2nd Gen RCD/Bilstein 5100 Shocks
Discussion in 'Downsouth Motorsports' started by Downsouth Motorsports, Jan 27, 2012.
  1. Jul 22, 2013 at 4:28 PM
    #281
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Dakar spring i remember you said they were back ordered.
  2. Jul 22, 2013 at 4:37 PM
    #282
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    We got a few, but they are gone again! I would place an order and put your name on a set.
  3. Jul 27, 2013 at 3:17 PM
    #283
    jjbbing
    jjbbing Member
    Jack
    Vermont
    '01 Taco SR5 4X4 6 cyl.
    32" tires, aluminum cap, deck plate, slidders
    PMed - 2001 stock ride height 5100's. -Thanks
  4. Sep 16, 2013 at 2:25 PM
    #284
    mytac
    mytac Well-Known Member
    T
    FV
    05 4X4 TRD
    TRD Intake, 2011 front grille
    No coupon code required.....simply visit this link & order:
    http://downsouthmotorsports.com/i-8...ma-pre-runner-4wd-ride-height-adjustable.html
    Price is $299.99 for the set of '4' shocks, and you will have the option to select the rear shocks as standard 5100, or the longer "B110" 5100s. Shipping is free via UPS Ground to anywhere in the lower 48 States.
    Hi,
    Are these still at this price because your website says $309.99 now. I'm ready to put in an order. Thanks.
    [​IMG][/QUOTE]
  5. Sep 16, 2013 at 3:01 PM
    #285
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    tagged for later viewing.
  6. Sep 16, 2013 at 3:21 PM
    #286
    Lakeside, Ca. 92040
    [/QUOTE]
    Price is 309.99
    http://downsouthmotorsports.com/i-1...stein-5100-ride-height-adjustable-shocks.html
  7. Oct 27, 2013 at 3:31 PM
    #287
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    Ready to pull the trigger on the bilsteins...I have the eibach springs and i plan on setting them at .85 and getting a 2 inch aal (non-tsb tacoma)...just wondering since i dont have the TSB if im still good to go to get the 24-214667 rear shocks?
  8. Oct 28, 2013 at 7:15 AM
    #288
    Lakeside, Ca. 92040
    Yes if you are running a 2" AAL, I would recommend that you go with the 24-214667 2-2.5" inch lift rear shock.
  9. Nov 11, 2013 at 9:24 AM
    #289
    eye one
    eye one Well-Known Member
    I just placed my order, 2 up front and 2 for the rear. I have my truck scheduled for some major maintenance on Monday, including an alignment, and hoping they arrive this week. At 150,000 miles on the stock set up I think it's time to have them replaced.
    Can't wait and thanks for the awesome deal on these shocks.
  10. Nov 17, 2013 at 12:56 PM
    #290
    craigb
    craigb Well-Known Member
    Craig
    Pa
    2013 TRD Sport
    Leer Cap Bilstein Shocks under bed lighting all weather mats window rain guards bed mat
    I have a 2013 tacoma DC long bed. I was wondering what rear shocks should I order if I get the front adjustable 5100? I want to level the truck.
  11. Nov 18, 2013 at 7:22 AM
    #291
    Lakeside, Ca. 92040
    The rear shocks is decided by how much lift you have in the rear.. For example, if you have 1"inch of rear lift, you would order the shock that allows for 0-1.5"inches of lift. If you have anywhere between 2-2.5"inches of lift, you would order the shock that allows for 2-2.5"inches of lift and so on.
    If you have any other question shoot me a call.
  12. Nov 19, 2013 at 6:39 AM
    #292
    Fury 17
    Fury 17 Member
    Marcus
    11 tacoma
    Will adjustable shocks work if i already have 3 inch lift blocks on my truck
  13. Nov 19, 2013 at 7:20 AM
    #293
    Lakeside, Ca. 92040
    Only the fronts are adjustable. When you say you have a 3" block, are you referring to the rear block, or a strut spacer up front?
  14. Nov 19, 2013 at 10:53 AM
    #294
    craigb
    Craig
    Pa
    2013 TRD Sport
    My truck is stock. 2 months old. Where do I measure from. I was going to put the front 5100's on set at 1.75,
    Thanks,
    Craig
  15. Nov 19, 2013 at 11:13 AM
    #295
    Lakeside, Ca. 92040
  16. Nov 19, 2013 at 8:20 PM
    #296
    craigb
    Craig
    Pa
    2013 TRD Sport
  17. Nov 20, 2013 at 7:01 AM
    #297
    craigb
    Craig
    Pa
    2013 TRD Sport
    Have a question, The shop putting on my front 5100 wanted to know if the stock brake lining will still be long enough and will they have trouble with the front end alignment. Also they were wondering if the stock coils are ok to use or do I need to change them out. They couldn't figure out how the shocks are going to lift the vehicle. He thought the coils would have to be changed to lift it. I'm new at this so bare with me.
    Thanks,
    Craig
  18. Nov 20, 2013 at 7:11 AM
    #298
    Lakeside, Ca. 92040
    Bilstein has instructions listed under the part number, I would suggest you print them out for this shop.
    Bilstein recommends that you retain your factory coil. Brake lines nor alignment will be an issue.
  19. Nov 20, 2013 at 9:05 PM
    #299
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
  20. Nov 21, 2013 at 7:12 AM
    #300
    Fury 17
    Fury 17 Member
    Marcus
    11 tacoma
    Yes it is a spacer
