2nd gen rear end and axle housing in 1st gen???
Discussion in '5 Lug' started by 00black5lug, Mar 23, 2018.
  1. Mar 23, 2018 at 10:35 AM
    00black5lug
    00black5lug [OP] DCSSM18
    Dalton
    2018 DC Sr5
    So I posted this question in an older thread, but I was wondering if I were to find the complete rear end (diff,axles, brakes, etc.) from a 2nd gen would I be able to install that into my first gen? I know the 2nd gen 5 lugs have a stock gearing option in the 8.4” 5 lug rear diff that is what I’m looking for (3.73) and this is why I’m asking.
  2. Mar 23, 2018 at 11:33 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  3. Mar 23, 2018 at 11:38 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    As long as it didn’t have an elocker but first gen trd models only came with a 8”, not sure about 2nd gens
  4. Mar 23, 2018 at 12:30 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Well my 5 lug has the 7.5” rear. The gears from the second gen I don’t believe will fit my stock carrier. So I was going to try and find a junk yard complete rear I could install from a second gen
  5. Mar 23, 2018 at 1:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ah okey, i was lucky and my truck came with an 8.4. But any 8.4 should fit under your truck in thoery. I dont see why toyota would alter the distance for the mounts on the axel for the same truck but different axel. If i was you I would measure your axel from the center pin to center pin the got find a 2nd 5lug with a 8.4 at a junk yard and measure that and its the same then take it.
  6. Mar 23, 2018 at 1:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What size tire do you run that you need 3.73?
  7. Mar 23, 2018 at 9:23 PM
    00black5lug
    Dalton
    2018 DC Sr5
    I’m at a 235/75/15 but would like to go to a 30x9.50
  8. Mar 23, 2018 at 9:23 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Btw sick truck man.
    Sperrunner likes this.
  9. Mar 23, 2018 at 9:36 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hmm i guess the ratio on a 7.4 is way different then the 8.4 from the factory. I have 30x9.5 and i need 3.55, and thanks
  10. Mar 23, 2018 at 9:40 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also idk if the end of the drive shaft on a 7.4 is any different then the end on a 8.4 and or if the 8.4 sits farther back then the 7.4. you might want to look into that. If so you would need to get the second drive shaft custom made.
  11. Mar 23, 2018 at 10:02 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Yeah that’s what I’ve seen on a few different threads in reference to second gen guys and trd models being used for their swaps. But I’m going to try and find a 2nd gen 5lugger and measure from pin to pin and see what it looks like.
  12. Mar 23, 2018 at 11:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean you could always just cut of the spring perches and weld them where needed. But if it does fit you will want to mock it up first and see if the drive shaft will fit if not your gunna need to custom order one
    00black5lug[OP] likes this.
  13. Mar 25, 2018 at 7:15 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Good point sir.
